Trick flow install underway
Old May 27, 2010 | 03:30 AM
  #281
PRE-Z06's Avatar
PRE-Z06
Originally Posted by Joe_G
Instead of unhooking the fuel rail and dealing with gas, just put a towel on the windshield, pop the injectors out of the manifold, then flip the rail with the injectors intact back on the windshield.
No dealing with gas this way.
I agree, that's how I've done it...like the idea of hooking the hose up before installation, thanks
  #282
PRE-Z06's Avatar
PRE-Z06
I agree, that's how I've done it...like the idea of hooking the hose up before installation, thanks for sharing
Old May 27, 2010 | 07:17 AM
  #283
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Default Will the 102 (PORTED )outshine the 92 ( PORTED) ?
Any thoughts as to weather the 92 will outperform the 102. Here is one of the pulls as we were struggling to get the low end torque in early.
The torque does not get to 400 before 3800 RPM. The 102 has longer runners and
may gain some low end torque. would like to see the low end of the curve lifted as opposed to picking up some HP at peak. You all have seen the Pics of the port mismatch with the 92 at the bottom of the runner. The sides of the Head runner
were cleaned up just to remove the shoulders and the 102 is a near natural port match
with no shoulder at the bottom of the runner and Im strictly talking about using the TF's
Old May 27, 2010 | 08:30 AM
  #284
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
This is the dyno from the 92?
Old May 27, 2010 | 08:44 AM
  #285
LSCHLEM's Avatar
LSCHLEM
Yes the dyno test was from the 92 with all its portmatch problems. Both
TRICK FLOW and my TUNER assure me that the bottom of the runner mismatch is but little consequence on making power. The 102 broke during install ans we got a new one coming in then out for agressive porting.
Old May 27, 2010 | 10:21 PM
  #286
glenB's Avatar
glenB
I was making sure I hadn't missed something. Will be interesting to see a back to back on the same dyno, not done by a vendor.
Old May 28, 2010 | 07:12 AM
  #287
LSCHLEM's Avatar
LSCHLEM
Default A real test ?
The fact of the matter is I got nothing to sell. By doing the test and I dont know of anyone who did it. Most people who have 90/92 manifolds are not going to just through them away with the promise of maybe 10
rwhp from the 102. The tests I did see were not A/B tests. I originally
felt the 92 was damaged from overporting and felt I lost potential power
from that and I felt movitated to get a new 102. I see those LS2's making the same HP/TQ running the 102 as those who ran the 92. The only difference is we have a few 525 RWHP LS2 H&C Cars out there running the 92 , DYNOJET TESTED and backed up by 130 mph + Track runs. Now that I will have two PORTED Manifolds I can do the test
and sell the lesser of the two and buy something else that will help the
Car perform a little better.
Old May 28, 2010 | 01:13 PM
  #288
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
I'm anxiously waiting on updated results
Old May 30, 2010 | 06:31 AM
  #289
LSCHLEM's Avatar
LSCHLEM
Default FAST 102 to be LEAK CHECKED
I have a test jig that I made to leak check the Fast before putting it on the Car. I should have it up and operational in the next day or so. It will test the entire body of the manifold before ever putting it on the car. The only thing it wont test is the seal you got after installation on the CAR.
Old May 30, 2010 | 11:25 AM
  #290
NOT2MELO's Avatar
NOT2MELO
Great thread looking forward to more updates!
Old Jun 1, 2010 | 12:36 PM
  #291
LSCHLEM's Avatar
LSCHLEM
Default Should the Fast Manifold be tested prior to install.?
Whether it's a FAST 92 or one of the newer FAST 102's out there I believe its a good idea to test & check the manifold prior to installing it on our
Cars. I used a new 102 that I got from COMP because of all the problems that manifest from leaks cant easily be found and really once its on the car we rely on the fuel trims for the indication of a leak. Some may
spray alcohol or soap solution which is a good idea to spray around the mating surfaces and watch for a change on the scan tool or even a vac gauge. What I did was made this inexpensive test jig with a Fitting, 4"
Metal plate and some duct tape. Of course I had A VAC Punp that I used
in Air conditioning work.
A quick look at the manifold the way it comes from the Factory shows that
its bolted together at the front and rear of the Manifold and appears to be
warped in the middle as shown in pic #1 . This time I put the rest of the bolts in and tightened them by hand and the upper shell and lower shell should be pretty much flush together as to not get a .010" Feeler gauge
between the upper and lower shell all the way around.
Old Jun 1, 2010 | 01:07 PM
  #292
LSCHLEM's Avatar
LSCHLEM
Default Test of the entire manifold.
The next step after bolting the Manifold together is to plug all the ports
with VAC Caps. Then I put Gorilla Tape over the runner exits and plugged the injector holes. At this point the manifold is ready to be leak tested.
If you look at pics #2 & 3 you can see the plate is sucked against the throttle body opening and does not need any screws to hold the plate on.
I set the Vac pressure to 15" HG then I can go around and check the entire body, mating surfaces with alcohol. If there is a slight leak the gauge will bounce immediately or even whistle. The plastic body underside will flex under 15" of VAC and if there are any cracks they will show up. After a few minutes the duct tape will start to cave in and form leaks around the runner exits and you can see what a small leak will do and if it
happens when installed on the Car you will pretty much know you did not get a good seat on the runner O RINGS or a sloppy MAP SENSOR hole,
Purge vent lines, Brake hose in rear but will be much easier to find. Here
are the pics of the Jig.
Old Jun 2, 2010 | 07:56 AM
  #293
LSCHLEM's Avatar
LSCHLEM
I forgot to mention the Jig can be made for about $ 15.00 worth of Parts. The trick is to get a hold of A Pump.
Old Jun 2, 2010 | 12:02 PM
  #294
NOT2MELO's Avatar
NOT2MELO
Great idea to leak check that intake before put on the car, one less thing to worry about.
Old Jun 2, 2010 | 12:36 PM
  #295
LSCHLEM's Avatar
LSCHLEM
Its not a expensive thing to do. In the future you will see used manifolds being sold that were modified especially the firewall mod. when that manifold is on the Car there are many places you cant check and when you have a lean condition its not something you can tune out and it can drive you nuts.
Old Jun 2, 2010 | 12:52 PM
  #296
NOT2MELO's Avatar
NOT2MELO
I agree would save lots of headaches with used intakes
