First day at AUTOCROSS
My car is a 2 week old GS with F55, Auto and everything stock for now.
My first few runs I found out I was not as good of a driver as I thought I was
. I started out in auto with traction control. after about my third run I was 14 sec. behind leader. So I took some rides with the leader and that was a great learning exp. This car was set up for this, to bad it was a Mutang
. After this I started using the hand shifter, I was able to cut my times by ten sec. I was very happy but I still had all the nannies on. So I was feeling pretty good, I thought I would turn off the nanny
. All of a sudden I sucked again
. It felt like I was driving on ice
I stayed with it and never did figure it out. It looked like I was going on the track to do donuts
. I was spining out all over and my times went real bad.
So my big ??????????? Is do I learn to drive with nanny off or keep it on? What mode should I drive in? I am going to Seabring in a few weeks and the way I ended I am scared I am going to destroy my car if I leave the nanny off? Just looking for some FRIENDLY advice.
Thank you to all men and women who serve in the USAF
OK, you asked for friendly advice and I hope you take the following in a good way as that's the way it's given...I'm more concerned with you destroying yourself than your car. If you haven't learned to control your car yet, you should consider skipping Sebring. I've been on Sebring several times and it's a very fast track with some unforgiving "walls". Get some more autocrosses under your belt and attend a racing school before advancing to the "big leagues". If you really want to go just for the experience (and I can't blame you), leave the nanny controls on and don't drive so aggressive. We've all been where you are and welcome to the thrill of amateur racing...there are plenty of people willing to help, all you have to do is ask.
Another question???
My tires were @ 39lbs to start I put them down to 33lbs, Where should I set my tire pre?
The front end was pushing through the turns.Do tires really make a big diff?
I say to turn off the Nanny and start out out slow and then up the pace as you learn. And, as others have said, you will most likely learn at a faster rate by getting some professional lessons.
What is AH?
I wasn't able to make it to Brooksville this month. Glad to hear you had fun.
Another question???
Tire pressure is a whole other topic and really at your level doesn't make a whole lot of difference. You need to let air out of the fronts to correct a "push" but you can only go down so far. The problem is two-fold...1) the factory alignment results in terminal understeer and 2) tire pressure changes are for "fine tuning". You don't have enough range in tire pressure to correct the terminal understeer. Understeer is the safest for a beginner with patience but from your description of your first event it doesn't sound like you have much in the way of patience when trying to get your car to turn. A lack of patience results in the terminal understeer snapping to oversteer and a quick "spin".
You're going to need to get the alignment set up for handling if you really want to get serious about this. More negative camber front and rear, move front toe towards toe-out, and move rear toe towards toe-in...how much all depends on how serious you are and what type of speeds you're running. Lower speeds will tolerate more front toe-out to assist turn-in but the same toe setting will result in spins at high speeds. There are plenty of sites on the internet as well as an "Autocrossing/Roadracing" section on this forum you can visit to get recommendations. I do my own alignments and set it to my driving style which is something you need to keep in mind...alignments are not "one size fits all". Take recommendations for just that and then tweak it from there. I have high speed and low speed alignments depending on the course...the last thing I want to be doing is chasing my tail at Sebring due to too much front toe-out.
Once you get your alignment where you want it, then you can fine tune the handling with tire pressure. And yes, tires make a big difference as well as alignment...sticky tires and a really good alignment can take an easy 5 seconds off a 60 second course.
One other thing, join a local NCCC club and you'll find a lot of fellow racers.
http://www.ncccsouth.com/
There's a really good one for you in Tampa:
http://www.floridacorvetteracing.com/
And they put on a lot of events at Brooksville.
http://www.ncccsouth.com/html/2010_sch.html
The club I belong to puts on a lot of events in St Augustine and then we're at Roebling Road Thanksgiving weekend.
Thank you very much, It is funny that you picked up on my lack of patience. Where is Roebling Road? We are looking for something to do over Thanksgiving weekend
Roebling Road is outside of Savannah, GA.
http://www.roeblingroad.com/trackphoto.html
You'll need a high speed license to run there with NCCC but you may be able to squeeze in under the wire if you run some more events between now and Thanksgiving. It's a much safer track than Sebring as the only places you can really get in trouble are the first and last turns. If you carry too much speed on either turn, you'll run into a bunch of tires off the first turn or spin off the last turn into the concrete wall that appears as a white stripe on the straightaway in the link above. Either one will ruin your day. You can ruin your day on other parts of the track but you have to get really, really stupid. Rain complicates things (especially for the fools that don't slow down enough) but it isn't that bad.
Another question???
As for Sebring. Are you just going to drive the course in some sort of open track or you going to have an instructor in the car with you? If you are just going to go out by yourself I would forget about it. If you are going to be in a car with an instructor then it probably is something you can do without putting you, your instructor or the car into any significant danger. Schools set up with instructors are designed to help the novice move from the terrified level to a comfortable level in a matter of a few track hours. Listen to the instructor as they will focus you on the safety aspects of the track like flag stations and run off areas. Then they will focus you on driving the course with emphasis on the driving line, proper braking points, corner entry, apex and corner exit so you can get the most enjoyment out of your time. The difference between an autocross and a high speed event is at the high speed event your instructor has time to see a potential issue far enough ahead to tell you about it so you can make a correction before it becomes more than a potential issue.
Bill
It's fun to horse the car around but if you really want good times, you have to be smooth. Jerking the car upsets the chassis...a good analogy is when you upset your wife, she's more likely to bite you in the azz than reward you with a good time.
For more great advice like the post from Bill above, make sure you visit the "Autocross/Roadracing" section of the forum regularly as you develop your skills.
Bill
Thank you for the great advice, I am set up to be with an instructor
I know I need to slow down but it is so fun going fast. I think the bigest problem I hav is that I used to drive a TAFC at 250mph and now 120 feels slow. But then them dammm corners come up.
. I was only tought to go fast in a straigt line.
I really thank you all for the great advise. Please keep it comming. And do not forget to thank a VET
I use all of these for road racing and even more. Just some things to consider if you want to progress.
Unless you autocross alot put the car in comp mode and leave it there until running the cones becomes second nature. Until you know what you are going to do at least a turn ahead of where you are you will be faster.
Walk the course, then walk it a few more times. Understand where you can be agressive and where you need to back off. One thing I will tell you is you can always run the slalom faster than you think possible.
Don't worry much about shifting. Get into 2nd gear and leave it there until you get more time under your belt. It is part of the smooth is fast thinking.
Last but not least is smooth is fast but at the same time smooth is slow. You need to be agressive as possible but at the same time be smooth. If your tires a making noise you are over the edge. But if you don't hear the tires every now and then you are slow.
