My Blown 2008 C6 Diffrential!
Old Sep 23, 2010 | 08:35 AM
  #41
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Originally Posted by Streetk14
Well, the way I see it is this. I added 82 rwhp and 64 rwtq to my car since I bought it (I have baseline and after-mod dyno sheets). That is a substantial power increase, and my car is now making more power and torque than most C6 Z06s do on the same dyno.
With that said, I should be upgrading the diff. If GM felt that a stronger diff was needed for the 505 hp Z06 (which they did), then I/we should probably do the same when we mod for 500+ flywheel HP.
Would it have been nice to get the stronger Z06 diff as standard on the regular C6 models? Sure, but it all comes down to cost. 99.9% of LS3 Vette owners will never have a problem with the standard diff. I'm sure it is something GM has investigated in their cost-analysis of the C6. It's one of the reasons you get so much for your $$$ with the C6.
And I'm not sure what would happen if you added an extra 100 hp and torque to a Ferrari and installed R-compounds. I could see something breaking as well. Just aren't a lot of guys modding Ferraris like Corvettes.
I'm looking at having my diff done as well, but mainly for the gear change. I'd rather have it done before it blows and takes out my transmission. Good luck and let us know what you choose to do.
Andy
Well said, Andy.
Also, I'm not sure why we're not seeing any GS breaking rears or transmissions; they've been around since about 7/09, over a year since the '10 models came out. Maybe they're not racing...
Old Sep 23, 2010 | 03:14 PM
  #42
WHITE_SHARK's Avatar
WHITE_SHARK
Originally Posted by EATURAW
Wow - this is DEF a big fear for me. I ALSO own a 2008 Z51 M6.
My car makes 614rwhp. I run Toyo R888 305/30/19 in the rear. I launch my car on the street and on the track, honestly.. I beat on it pretty much any way you can think of. Nothing has broken yet, but I can hear "things" clunking under the car when I go over small bumps - or when I'm shifting normally and the car jolts slightly. I'm just waiting for the day. Maybe I should have it looked at before something breaks -
supercharged ? nice gain.
I think you should consider an upgraded diff + a diff brace asap
for the GS, never seen one here in Gulf region and don't see many racing with it yet, even if they did with the stock tires, they will not break the diff
I think the rear end /cltuch/etc will face a failure or issues when the tires get a real grip but for the stock tires, any stock corvette ls3 can spin a lot from dif or 40km roll ( in most of the streets)
Old Sep 23, 2010 | 03:40 PM
  #43
HC Mechanic's Avatar
HC Mechanic
I'm planning to upgrade mine as well...I was hoping to go with a Z06 diff, but I guess it's not going to mate to the C6 trans.
Now what do ya do? Is there just some internals that need upgrading, that you could swap out?
Old Sep 23, 2010 | 04:52 PM
  #44
2006c6keller's Avatar
2006c6keller
Default ???
They have some supports for the case to prevent breaking, I've not reviewed the whole thread, but there is a vendor (DTE) who supplies these types of mod parts. Maybe someone will chime in with more details. Thanks!
Old Sep 24, 2010 | 03:25 PM
  #45
JDBlack7's Avatar
JDBlack7
I just had a DTE (Phil) perform a stage II transmission rebuild and stage II rear diff. rebuild just about three weeks ago. Luckily Fort Wayne isn't that far from Louisville KY so I trailered the vette up there and had them perform all of the work. It was all over my head anyway.
I just finished my engine build on my `05 Z51, heads(TEA stage II), cam, tune (Jeff Creech), CAI...already had complete exhaust. Just after about three weeks after the build, still in break in period, I broke something in the drive train. Researched this forum and found out about the nightmares associated with the `05 rear diffs. Well, it turns out I broke the transmission output shaft so I had to have a tranny rebuild too. I did go with the Z06 30 spline output shaft, and since the diff was getting rebuilt as well I had them install the 3.73 polished gears along with the Z06 output shafts (part of the stage II build). What made this rebuild cost more than typical is that I also had DTE change out the casing to a `07, side covers and adapter plate. These guys know drivetrains and rear differenials. With the engine HP increased it was only a matter of time before I thrashed the rear diff anyhow being a `05 car. GM should have recall this car for the weak *** rear diff., but that's another discussion.
I just recently finished my drivetrain break in period and I'm finally getting to really have some fun with this car. I'm blown away with the acceleration of this car. Hands down the fastest car I've ever owned or driven for that matter.
Heading to the dyno soon to get my final tune and see what this engine puts out.
ps...sorry to hear about your luck...drivetrains aren't cheap by any measure. With the engine build & complete drivetrain I'm around the 10 grand mark....but worth it!
Old Sep 24, 2010 | 08:47 PM
  #46
Streetk14's Avatar
Streetk14
Originally Posted by AORoads
Well said, Andy.
I'm not sure.....
I guess I can't say I've seen too many GS models that were highly modified yet. Since they have only been out a year, probably a lot of owners are still keeping them stock. I think it will become more of a problem in a few years when prices on used 2010 GSs come down and people start buying used with performance and mods in mind (like me and my '08 Z51).
Old Sep 24, 2010 | 08:58 PM
  #47
saplumr's Avatar
saplumr
I seriously don't think that brace will be much help.
Old Sep 24, 2010 | 11:05 PM
  #48
Fastlane14's Avatar
Fastlane14
my blown diff in my 05 looked the same, except it ended up sitting on top of the rear end housing, I was also already in 2nd gear on a full throttle pull, 443 rwhp c6 6 speed
Old Sep 25, 2010 | 01:36 PM
  #49
HC Mechanic
Does anyone know what's breaking on these differentials? And what was upgraded from '05 to '06?
I have an '06, but I'm a little unsure if I should trust it taking my planned 500 rwhp. So I've been kind of holding off on the H/C mod until I get some more information on these drive train issues.
Maybe for now I'll just do my clutch upgrade, and do the diff. mods when I go to bigger wheels and tires. Right now I'm only running NT05 275/35/19, so maybe that's not enough traction to cause any issues??
Old Sep 25, 2010 | 04:32 PM
  #50
LBear's Avatar
LBear
GM changed the design in 2006 or 2007 because the 2005 & some 2006's were breaking under normal use. As usual, GM went with a "cheaper" design to save money but soon found out that the 400HP of the LS2 was no match for the differential. So Getrag came out with a stronger design for GM, I believe it was referred to as the "3-series, second-design"
GM learned its lesson, so when they came out with the Z06, they put in an even heavier duty differential to protect themselves from warranty claims.
Visit Dynotech :
http://www.dynotech-eng.com/dte_c6_diff.htm
Old Sep 25, 2010 | 04:55 PM
  #51
WHITE_SHARK
what do you think of adding the diff brace + PFADT engine & tranny mounts to be more on safe side or atleast you will feel more confortable?
Pfadt C6 Engine Mount Kit
Engineered in house and tested on our vehicles, these Engine mounts reduce the massive powertrain shake (sometimes mistaken as wheel hop) that is common in the C6.
An excellent solution for high horsepower or high performance Corvettes, we've approached these mounts as a complete system to limit unnecessary movement. The soft stock mounts allow power-robbing movement that shakes the car and can break parts. Constructed with 6061 T6 aluminum and anodized for durability, pair these engine mounts with our C6 Transmission mounts for an unbeatable package.
We tested our mounts on our C6 Z06 and took some great 'before and after' video. In the first half of the video with the stock rubber engine mounts you'll notice the engine shake and move considerably during acceleration. In the second half with the Pfadt Polyurethane Engine Mount, the engine barely moves. Check it out (it's worth the click):
http://www.youtube.com/watch?v=Lczzh...layer_embedded
does it really help that much?
btw, im buying a used 08 z06 diff + tranny
I will let you with the progress later.
Thank you all for adding value to the thread.
Old Sep 28, 2010 | 05:32 PM
  #52
WHITE_SHARK
ttt
electric pump
Old Oct 10, 2010 | 03:11 PM
  #53
WHITE_SHARK
I have successfully installed a 08 z06 differntial and tranny into my c6.
the torque tube of the c6 fits perfectly the tranny of z06. I only need some z06 cooler hoses to be purchased and complete the whole story.
here are some new pcitures for the blown diff and the z06 diff:
hope everything will run smooth on this used z06 tranny. it has only 6k miles.
Thanks all
Old Oct 10, 2010 | 03:35 PM
  #54
hungryhippo's Avatar
hungryhippo
Thanks for the pics and info. That's what I'll be doing when mine goes out. If you reused your torque tube, does that mean you didn't have to swap the transmission? The Z06 rear end is a direct replacement?
Old Oct 11, 2010 | 11:11 AM
  #55
WHITE_SHARK
Yes I have reused the c6 torque tube with the z06 transmission, no problem at this side.
BUT I'm not sure if the z06 differential alone will fit to the c6 tranny, I really doubt that.
but for me, I installed the z06 "diif + tranny" combo and it fit perfectly with c6 torque tube.
I onle need to buy two pipes for the tranny/diff cooler to complete the install and run the car.
missing GM parts No:
part#10346305
part#15254972
Old Oct 12, 2010 | 12:49 PM
  #56
Crow Hunter's Avatar
Crow Hunter
This illustrates the folly of building differential cases out of aluminum. They should be built of cast iron, which is over 2x stronger, and much cheaper. True, there'd be a weight penalty, but it would be at the rear. I know the engineers want to eliminate every pound they can, but sometimes it comes at a cost, as in the failure of this differential case. The '05s apparently suffered case failures, so they beefed them up for '06, but still used aluminum. Aluminum is OK for econo box cars, but "iffy" in HP cars such as Vettes and Vipers when used in high-stress components.
Old Oct 15, 2010 | 01:17 PM
  #57
HC Mechanic
I don't think the engineers had much drag racing in mind for our cars, it's a balanced car for really good all around use
Road Racing is where the Corvette is usually doing it's best work
To My Blown 2008 C6 Diffrential!
Old Oct 15, 2010 | 02:37 PM
  #58
TrenAman's Avatar
TrenAman
rarely see a diff blow up like this in a 08+..
good luck!
Old Oct 17, 2010 | 03:17 AM
  #59
C6-LS2-MN6's Avatar
C6-LS2-MN6
I like the look of that exhaust, who makes it?
Old Oct 17, 2010 | 09:36 AM
  #60
EuroRod's Avatar
EuroRod
A DTE tranny/differential brace will, in no way, help reinforce the differential case. All it does is prevent a differential failure from damaging the tranny.
The cases in the '05 C6's are especially prone to failure. Just like GM to put an additional 50 hp and torque into the C6, then save $5 in material by designing the cases thinner. GM realized they had an issue in the 11th hour of the introduction of the C6. They fixed the problem is a software modification called "torque management". All 6mn 2005's had this software change. I'm not sure about newer models, as GM did begin using better differentials in 2006.
All torque management did was retard timing and change the fuel mapping so that the 2005's only made about 330 hp in 1st and 2nd gears.
What a load of GM Bull$h!t.
