Installing Headers
Old Oct 19, 2010 | 07:05 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Default Installing Headers
How difficult is a DIY installation of a set of headers with one set of hands and using race ramps instead of a lift? Tips anyone? Installation on standard C6 LS2 manual.
Old Oct 19, 2010 | 07:14 PM
cooldog's Avatar
cooldog
I'm interested in the responses too, since I'll be doing this same thing later this week.
Any hints? What are the gotchas?
Old Oct 19, 2010 | 07:43 PM
glennhl's Avatar
glennhl
Very easy install. Hardest part is routing the wiring for the rear O2 sensors. Of course if you tune out the codes, then you don't even need rear O2's. I did not do it on ramps, I got the car as high as I could using jack stands. I really don't think ramps would have had the car high enough to get the headers in.
Old Oct 19, 2010 | 07:51 PM
cooldog's Avatar
cooldog
Yes, I'll be on jack stands.
Old Oct 19, 2010 | 08:05 PM
FUNTRUN's Avatar
FUNTRUN
Default header install
I installed my LG headers using race ramps and jack stands. It's not as easy as using a lift I'm sure but it can be done fairly easy. Loosen all the clamps on the factory exhaust system first so you can move everything back and forth as needed during the install. When your done get another dyno tune and enjoy the newfound torque and horsepower.
Old Oct 19, 2010 | 09:55 PM
Ginny C6's Avatar
Ginny C6
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
The problem with ramps is the height. I used a lift a friend had, and I'd really try to find someone with one. You may also want to install a tunnel plate while you are under there.
Old Oct 19, 2010 | 10:49 PM
Whisky's Avatar
Whisky
Easy, easy, easy!
Old Oct 20, 2010 | 07:33 AM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Race Ramps go up 10" but jack stands are an option. Do you need to put up the rear on jack stands also? What's the difficulty with O2 wiring?
Old Oct 20, 2010 | 07:35 AM
timd38's Avatar
timd38
I did it with help on jack stands and it was easier than I thought. The tunnel plate add is a good move to do at the same time.
Old Oct 20, 2010 | 02:05 PM
BluV's Avatar
BluV
St. Jude Donor '09-'10
Did mine in the garage by myself. On jack stands. Well, really - the wife helped at one point for the headers - she held the header from above by a cotton twine/string until I could crawl back out from under to align the bolt holes. Everything else was on my own. Very simple process, and do the tunnel plate while you are there.
Don't tighten anything back down until you have all the pipes connected. For me, the only difficult part of any of it was getting the pipes aligned to slide back into each other. (I did full headers/xpipe/zo6 muffler at once, so more pieces to tweak into alignment )
Old Oct 20, 2010 | 02:27 PM
tomiboy's Avatar
tomiboy
I did it with ramps in front jack stands in back. I'm 58 with a bad back.
Old Oct 20, 2010 | 02:41 PM
TysonJones's Avatar
TysonJones
Where do you get the tunnel plate and what are the advantages of having one? Sorry if this is a stupid question. I put headers on my ls1 ta, how hard is it compared to that?
Old Oct 20, 2010 | 03:28 PM
cooldog's Avatar
cooldog
An aftermarket tunnel plate is thicker, and sometimes insulated, which improves chassis rigidity, and keeps some of the heat out of the cockpit. Elite Engineering makes a popular one, and others can also usually be found on eBay as well.
I have the EE one waiting to go on during this effort this weekend.
Old Oct 20, 2010 | 03:32 PM
cooldog's Avatar
cooldog
If I need help like that, I think I can do it by placing a 2x4 across the front fenders, and then using cord to support the headers from the 2x4.
I'll be installing the EE tunnel plate, OBX headers and the Z51 oil-cooler lines all at the same time.
Old Oct 20, 2010 | 03:35 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Go to eliteengineeringusa.com. You will find tunnel plate information and sales there.
Old Oct 20, 2010 | 03:43 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
The 2 x 4 idea is a pretty good one
Old Oct 21, 2010 | 07:57 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
What is the method of routing the O2 wiring that was previously mentioned as a problem?
To Installing Headers
Old Oct 21, 2010 | 08:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Did mine in the driveway on jack stands. EASY! I can do one in 4 hrs now.
Old Oct 22, 2010 | 12:12 AM
glennhl's Avatar
glennhl
Yes, you have to jack up the back also. I didn't take off the tunnel plate, so I ran the wiring using p-clamps to hold the wiring and then covered up the connectors with insulation tape. It just took a while.
Old Oct 22, 2010 | 10:43 AM
j_digi454's Avatar
j_digi454
Talon90, a Forum Vendor has these as well as an explanation as to the advantages. He also outlines the instructions. Check out the following link:
http://www.theredlion.us/Etunnel.htm
