How to replace a fuel pump
Chuck CoW
So, yeah, just depends. I've had it go both ways..
the o-rings or spacers shoot across the room.... Or you pull the crossover tube and it yanks the guts
out of the tube or the tank.... and plastic parts break or go flying....
I keep 5 or 6 hose assemblies, o-rings, cross over tubes, and other parts here in bulk as we do LOTS of these
not just for superchargers but for simple repairs or leaks....etc.
ANOTHER thing for people to consider is it depends on how big or bulky you are.....
If you're a big dude, you can almost forget it with the trans in the car....
OR, you can just accept all the new ARM TATTOOS scratches, cuts, and scrapes that go along with trying to
keep the trans in the car...... 2 Hours of extra work saves lots of broken parts and cuts and scars!
Wanna know how many times I jump in a car to tune it and any one of a number of employees messed
up the job over the years...... and I gotta fix it???
It's happened more than once. From here on in, the guys take the trans out....
And I do the tank work..... Not something I like doing..... or re-doing.
Chuck CoW
But yeah, I've pretty much had most of those happen. Once it's apart once it at least usually comes back apart easier the second time. First time I took mine off on a 10 year old car with 150K miles on it..yeah, didn't go so well.
Man, you took all of the emotion and "feeling" out of my post.
Yes, it is a pretty smurfy job... I keep lots of extra parts around for those jobs.....
Chuck CoW
RH
-You'll need to remove the fuel sending unit wire leads from the old connector and plug them into your new fuel pump's connector. The two smaller gauge wires on the left are the ones that have to come out. In the center of the back of that connector is a hole. Inserting a small jeweler's screwdriver allows you to release a lock which then allows the front of that wire connector shell to come off. From the front you insert that jeweler's screwdriver into the shell and release the tang holding those two wires in. The fuel sending unit wires then simply plug into the bottom of the new fuel pump connector. Double check to make sure they are secure. If not, you'll be doing this all over again for a "no gas gauge" problem.
Kudos to Motorhead-47 and others who contributed, I replaced a drivers fuel pump today in a 2011 auto and it was not as bad as it could have been. It took me and a friend around 4hrs or so on jack stands, sorry no pics of my own to add. I was lucky that the lines in the crossover to tank pulled out easy. A few details I find is a must on a auto ( Remove mid pipe and drivers side axle over, shifter must be in S for clearance to remove axle over muffler), the crossover disconnect and connect is a one hand use only while working mostly blind with the help of a friend eyes looking from the cavity where the muffler was removed ( a good location to see but to far of a reach to do anything). A few notes on the black locking tab, clockwise rotation first to release pressure on black safety locking tab when disconnecting and then release it ( view pic arrow in red, tab is recessed under tank flange and pressure forced locked by locking collar ring). On install once crossover collar is locked to tank by rotating clockwise, place black locking tab ring back and make sure it is under the wedge of the tank flange and rotate counterclockwise for the collar ring to keep pressure on the black safety tab.
Just drop the tanks. I can literally have the rear drivetrain down out of the way in like 2 hours, so worst case, it isn't THAT bad to get to if it comes to that. Not worth hacking your car up over, that's for sure.
I got my drivers side tank out last night - and snapped the fuel return lines inside the tank.
I already have the replacement parts coming from Amazon.
I had a question on the plastic sleeve gasket.
The smaller one is still in the cross over tube - and is on top.
The larger one one bottom is loose - and looks like it might have a rubber o-ring grove formed into it.
I looked around and did not see any random loose o-rings on the floor, in the tank, or on the car.
Did I lose an O-ring on that sleeve?
Directions per the factory service manual
Fuel Tank Replacement - Left Side
Tools Required
J 37088-A Fuel Line Disconnect tool
Removal Procedure
1. Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection in Engine Electrical.
2. Drain the fuel tank. Refer to Fuel Tank Draining .
3. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
4. Remove the left rear tire. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
5. Remove the left rear wheelhouse panel. Refer to Wheelhouse Panel Replacement in Body Rear End.
6. Remove both mufflers. (A6 only) Refer to Exhaust Muffler Replacement - Left Side and Exhaust Muffler Replacement - Right Side in Engine Exhaust.
7. Remove the driveline support assembly. (A6 only) Refer to Driveline Support Assembly Replacement in Propeller Shaft.
8. Disconnect the fuel fill hose and recirc line from the fill pipe.
9. Disconnect the fuel pump jumper harness connector.
10. Disconnect the fuel feed pipe (4) at the rear of the left fuel tank. Refer to Plastic Collar Quick Connect Fitting Service .
11. Cap the fuel pipes to prevent fuel system contamination.
12. Loosen the fuel tank strap in order to drop the tank approximately one inch.
13. Disengage the crossover tube connector position assurance (CPA) retainer by pulling the tab (1) outward and rotate.
Important: The crossover tube CPA is released when the latch disengages from the tank connection groove.
14. Rotate crossover tube collar counterclockwise to disengage.
15. Disconnect the crossover tube from the left fuel tank by pulling straight out.
Important: Take care not to disturb the internal O-rings in the fuel tank connections.
16. Disconnect the evaporative emission (EVAP) crossover pipe quick connect fitting at the left fuel tank.
17. Cap the evaporative emission (EVAP) pipe to prevent system contamination.
18. Remove the fuel tank strap mount bolts.
19. Remove the fuel tank strap from the vehicle.
20. Remove the fuel tank.
Installation Procedure
Install the fuel tank.
21. Install the fuel tank strap to the vehicle.
22. Install the fuel tank strap bolts loosely leaving the tank hanging approximately one inch.
23. Remove the cap from the EVAP pipe.
24. Connect the EVAP crossover pipe quick connect fitting at the left fuel tank.
25. Lubricate the crossover tube to fuel tank connection O-rings with GM P/N 1051717 (Canadian P/N 5728223) rubber lubricant.
Important: Note the location of the T-shaped alignment feature (5) between the jet pump feed/return pipes connector.
26. Lubricate the crossover tube O-ring mating surfaces with GM P/N 1051717 (Canadian P/N 5728223) rubber lubricant.
Important: Note the T-shaped alignment feature on the crossover tube.
Important: The crossover tube will not fully seat into the fuel tank if the jet pump lines are misaligned.
27. Connect the crossover tube to the left fuel tank using the features previously noted.
Important: The crossover tube collar tangs will not latch if misalignment exists.
28. Rotate the crossover tube collar clockwise to engage the tangs.
29. Rotate the crossover tube CPA retainer counterclockwise past the collar latching tang and push the tab (1) into the locked position.
Important: If the CPA retainer is locked into position, the crossover tube collar will not rotate.
30. Test the crossover tube to fuel tank connection by attempting to rotate the crossover tube collar counterclockwise.
Tighten the fuel tank strap bolts.
Tighten
Tighten the bolts to 25 N•m (18 lb in).
31. Remove the cap from the fuel pipes.
32. Connect the fuel feed pipe at the rear of the left fuel tank. Refer to Plastic Collar Quick Connect Fitting Service .
33. Connect the fuel pump jumper harness connector.
34. Connect the fuel fill hose and recirc line to the fill tube.
Tighten
Tighten the clamp to 4 N•m (35 lb in).
35. Install the driveline support assembly. (A6 only) Refer to Driveline Support Assembly Replacement in Propeller Shaft.
36. Install both mufflers. Refer to Exhaust Muffler Replacement - Left Side and Exhaust Muffler Replacement - Right Side in Engine Exhaust.
37. Install the left rear wheelhouse panel. Refer to Wheelhouse Panel Replacement in Body Rear End.
38. Install the Left rear tire. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
39. Lower the vehicle.
40. Refuel the fuel tank.
41. Connect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection in Engine Electrical.
42. Perform the following procedure in order to test for leaks:
Turn ON the Ignition switch, for 2 seconds.
Turn OFF the ignition, for 10 seconds.
Turn ON the ignition.
Inspect for fuel leaks.
Ken,
Thanks for the great post on replacing the fuel pump. It was incredibly informative and helpful. I 'm nervous I'm missing an o-ring on my crossover tube. There is a yellow o-ring on the lower tube, but no o-ring on the upper tube (see picture). Is this correct or am I missing an o-ring? I had a very hard time separating the crossover tube so maybe it fell off wrestling the crossover tube off the tank? The plastic piece that holds the fuel lines in place at the top of the gas tank broke so I ordered new in tank fuel lines that come with the broken holder piece.
My vehicle is a 2006 convertible with APS twin turbos with MDS BAP. My new fuel pump is a unit from Racetronix that is a drop in replacement, requires no BAP, and can support 800 RWH. They just came out with the new pump a month ago. I have been speaking with the manager Jack. I'm also installing their beefed up wiring harness's that run directly off the alternator.
Thank you for your input and you post!
Sincerely,
Rick Voss
I have purchased a Racetronix fuel pump for my 2006 vert with APS twin turbo's. I have the tank out and have replaced the in tank lines. I'm having a very hard time trying to get the in tank lines connected to the fuel pump. I have tried your trick with the safety wire, read the factory shop manual, but still having trouble. First I tried not clipping in the fuel lines where they meet the crossover tube but kept getting snagged on fuel sending unit. Now I have clipped in the lines in the top of the tank. Was this a mistake, should have left them floating and unclipped. Still feel like I'm forcing to much and can't get my fingers on the lines. Any other suggestions?
Thanks for your help!
Rick Voss
