Auto transmission.
Old Jan 2, 2011 | 11:30 AM
timd38's Avatar
timd38
Originally Posted by HOXXOH
Given that GM only recently extended their warranties to 100K doesn't mean that the cars suddenly got a lot better, but that they had faith in what they were producing.
Warranty is a function of marketing.
Old Jan 2, 2011 | 11:37 AM
Ketchum's Avatar
Ketchum
Hate it no dipstick to even look at the fliud or condition.The no dipstick thing bugs the heck out of me.I bought car from the largest Corvette dealer in the U.S. It had just had oil change month before.I also bought a 24/24 Gmpp Major Guard protection plan only reason I bought a 06.Went looking for 07 and 08s because of warranty and such.Car and GMPP plan were a really decent buy so I went with this car.Dealer really wanted to sell a car.
Old Jan 2, 2011 | 12:57 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Originally Posted by glass slipper
... Using Amsoil ATL in your '07-'11 Corvette A6 will void your warranty with GM leaving Amsoil as your only recourse to pay for repairs. Amsoil may say it meets the specs but it is not licensed by GM and GM is the one that determines warranty repairs.
I'd like to know where in the owner's manual that is states you must use a that is licensed by GM. All my GM owner's manuals state you must use a fluid meeting the spec (for whatever the applicable fluid).
By your line of reasoning, use of many major oil companies oil will void the warranty of the 11's which require a Dexos1 oil. I just don't see that happening.
Chevron, Citgo pass on Dexos
ByByBMW - thanks, been on leave this week. We'll see how much time I can spend online next week when I'm back to work.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jan 2, 2011 | 01:29 PM
Ketchum's Avatar
Ketchum
A lot of folks think because a oil dosen't have the API certified stamp logo that it is not qualified for use or dwell on that issue.The API stamp is very exspensive from what I have read and many of the boutique oil company's like Amsoil,Royal Purple and Redline etc.just won't fork over the bucks for it on certain products.It could be argued in a court of law as it does state such in the owners manual I think.More then likely in the OIL section. That API thing is brought up on many forum's over and over. I'm sure there are really cheap products out there that don't have that stamp and can cause damage.But the company's I mention has products superior then the common over the counter stuff.I dealt with many failed components in my day.Some covered by factory warranty,factory service contracts and aftermarket service contracts.Lots sent adjusters out.Some were real butts to deal with.That question was never ever brought up to me.Just proof of maintance as per the owners manual and sometimes not even that.Just the condition of the fliud and the vehicle.
Old Jan 2, 2011 | 02:19 PM
Gering's Avatar
Gering
Tolero Apto Victum
With only 19K on the car, it's real unlikely to have any problems caused by fluid issues. With no service documentation, my opinion would be to just change the oil/filter and nothing else. Given that GM only recently extended their warranties to 100K doesn't mean that the cars suddenly got a lot better, but that they had faith in what they were producing.
Thousands upon thousands of the cars will never have the A6 fluid changed prior to the factory service suggestions, without failures. By far, many of those may go twice the miles or even never and still survive, if they are not driven abusively.
I personally fully (12.75 qt) changed mine at 71K, due to putting in a high stall converter to improve my times at the drags. I doubt the A6 gets more abuse than racing and also that any particular brand of proper fluid will cause the transmission to fail.
If fear of the unknown is the reason to change the fluid, then you should never buy a used car. If you do change it, do it 3 or more times in the next 1000 miles to get a much higher percentage of that nasty old fluid removed. Consider draining/flushing/changing the power steering, windshield washer, coolant, differential, and brake fluids too.
True, that is why I bought mine new with 2 miles on it. I know what has been done to it. If I were to buy a used car I would do the following as well. It is a cheep please of mind IMO.
Old Jan 2, 2011 | 02:41 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by Ketchum
Usually what I do on low mileage vehicles going to Amsoil I do the exchange.Anything in the filter or pan stays there as the exchange is using the vehicles own power to exchange the fliud,There is no back flush or even a flush.Its done by the vehicles own trans pumping.Then in about 3k to 5k I do a pan drop and filter using more Amsoil ATF.In fact I have done it this way in the past not even using Amsoil fliud.If high mileage I do the whole thing at same time.You waste several qts of fliud as you do pan/filter top off using up to 6 qts of atf and then hook up exchange machine with another 17 qts of fliud.
That system/combo should definitely cover most of it.
And if I do buy used I just assume the worst (a little paranoid I know LOL) going into it and take it from there.
Same here.
Old Jan 3, 2011 | 12:38 AM
glass slipper's Avatar
glass slipper
Do you know what's in the dexos1™ specification and why it came about? Do you know what's in the GM4718M specification and why it came about? How about the Dexron® VI spec and why it came about?
I have a contact that got me a copy of the GM4718M spec and hopefully will have the dexos1™ and Dexron®VI specs before long.
While you ponder those questions, here's the answer to your question from the 2011 Corvette owner's manual:
http://www.chevrolet.com/assets/pdf/...ner_Manual.pdf
Page 11-6 says:
"The engine requires engine oil approved to the dexos specification. Oils
meeting this specification can be identified with the dexos certification
mark. Look for and use only an engine oil that displays the dexos
certification mark
of the proper viscosity grade."
It doesn't say it has to meet the spec, it says its required to be approved to the spec as in it has to be on GM's list of licensed oils. This applies to all 2011 GM vehicles.
Same thing for the 6L80 transmission...page 11-7 says:
"DEXRON®-VI Automatic Transmission Fluid."
If you have an engine failure, what if GM asks what oil was used? Are you going to tell them you used an unapproved oil and risk a warranty denial? As much as you "just don't see that happening", let me know how that works for you. Of course you could always lie, who'll know the difference right? In the meantime, keep on telling your customers to void their 5 year/100k mile warranty.
Old Jan 3, 2011 | 01:57 AM
Rebel 1's Avatar
Rebel 1
Page 11-6 says:
certification mark
I use only the fluids required and licensed. Try to out-think the engineers? Not me.
Old Jan 3, 2011 | 06:28 AM
Ketchum's Avatar
Ketchum
Amsoil addresses both fliuds on their web site.They state that their oil and auto trans fliud meets and exceeds all GM specs. Any time I brought up Amsoil to a factory rep or a mechanical adjuster they always had a comment like 'OH thats real top of the line fliuds." I remember several stating they used Amsoil gear oils.
Old Jan 3, 2011 | 01:44 PM
HOXXOH's Avatar
HOXXOH
Would you think anyone would ever advertise that their products don't meet the minimum specs?
Obviously, the OEM fluids that are used also meet or exceed their own specs.
Having testing done and creating specification levels by a responsible independent source, such as SAE or ATSM, is the only way the consumer can be assured of the performance. However, what may be the highest performing fluid for one vehicle and the conditions in which it's operated, may well be just the opposite for a different vehicle/conditions.
I can only assume that the OEM fluids have been through more testing for my vehicle than any other fluids and therefore fit the OEM standards they publish. I tend to modify slightly toward the generally accepted fluids that the racing community uses, due to the racing I do. People whose identical cars have never seen 4000 RPM shouldn't bother making any change from OEM.
Old Jan 3, 2011 | 06:31 PM
Ketchum's Avatar
Ketchum
The only issue I have with OEM is that the auto manufacture can and does change suppliers with out any notification to the purchaser.The OE fliuds I have never seen any wording that says exceeds OE specs.Sometimes but I will say not always you get what you pay for.I have a little more confidence in Amsoil(and a few others) that their products are on the higher end then the ones supplying to OE.
Old Jan 3, 2011 | 08:17 PM
C66 Racing's Avatar
C66 Racing
Glass Slipper - thanks for the quote of the 2011 owner's manual. The addition of the word "approved" is new (at least for all my other GM owner's manual's (02, 03, 07, 08).
You state the same for the tranny fluid, but don't quote anything other than the fluid. Does the same wording (e.g. approved) appear anywhere other than the oil section in the 2011 owner's manual?
Despite the above, I still feel 100% comfortable recommending any fluid that AMSOIL recommends for a given car (and they do recommend the ATL for the OP of this thread) given that AMSOIL's warranty cover's their recommendations:
AMSOIL Corporate Warranty
But - I totally understand those that are uncomfortable going against the owner's manual recommendation. To each his own.
Old Jan 4, 2011 | 06:51 AM
  #33
glass slipper
Dexron VI is a registered trademark as indicated in the owner's manual so any company using the "Dexron VI" label has already had their fluid submitted to the licensing process and approved to be on GM's list. GM's requirement to use Dexron VI implies the fluid has to be approved. I'm writing this from my cell phone so I'm not able to enter the proper "registered" symbol which is done by holding the "alt" key while typing "0174" on the number keypad on the right side of your keyboard. I'm getting underway on a DDG 51 class ship today (pulling away from the pier as I type) for INSURV preps and won't be back until late tonight. My job starts when they do their full power run...if they can't get the rated 100,000 HP to the water, I have to figure out where the problem is (electrical calibration/electronic engine control, engine, or controllable pitch propeller) and provide guidance for repairs. This is the part I love about my job...being a "subdriver", I'm sure you understand.
Old Jan 4, 2011 | 08:09 PM
  #34
C66 Racing's Avatar
C66 Racing
Good luck to both you and them out there. I spent a day on a DDG51 out of Pearl several years ago. Very neat, fast ships. Much prefer looking at them out of the periscope to actually being on one though.
Old Jan 6, 2011 | 10:05 AM
  #35
Street Rat's Avatar
Street Rat
Originally Posted by Street Rat
2008 just hit 30,000 and is about to have filter changed and Amsoil put back in.
Did it myself yesterday in my garage. Shifts much much smoother and quicker.
Old Jan 6, 2011 | 01:51 PM
  #36
Ketchum's Avatar
Ketchum
How much fliud did it take?
Old Jan 6, 2011 | 04:16 PM
  #37
Street Rat's Avatar
Street Rat
I put 7 quarts back in. It drained about 1/4 quart of overfill. So all in all it took about 6 3/4 quarts total with the filter change and pan off.
To Auto transmission.
Old Jan 6, 2011 | 07:28 PM
  #38
Ketchum's Avatar
Ketchum
Thank you.That is less fliud then I used on a lady friends 06 Colbalt.It took almost 8. Wonder what the deal is.You'd think the v8 vette would take the larger amount.
Old Jan 6, 2011 | 08:11 PM
  #39
C66 Racing's Avatar
C66 Racing
Pan might be shallower due to low ground clearance. FYI, AMSOIL's online application guide, which is a pretty good reference, states the drain and fill capacity of the 06 Cobalt as 6.9 quarts and that of an 06 Vette as 6.6 quarts.
Old Jan 7, 2011 | 08:18 AM
  #40
Ketchum's Avatar
Ketchum
Had a Chevy tech tell on the Cobat he uses the better part of 8 qts.Thats what I found when I did her Colbalt.
