LS2 FAST 102 install (with pics)
Old Nov 16, 2013 | 05:47 PM
  #121
CSexy06VY's Avatar
CSexy06VY
Originally Posted by taken19
If you can't get a wrench back there, you should be able to get very close based on the feel from torquing the other bolts. That's what I have don't in the past.
oh ok thanks, I did tighten them with a ratchet, just wasn't sure how critical they had to be. I used a ft pound torque wrench set on 5.5 ft lbs.
how bad is it to drive it without an optimized tune? I took it around the block so far, the low end is pretty sweet!
Old Nov 16, 2013 | 06:01 PM
  #122
taken19's Avatar
taken19
Track Junky
I would be very careful about running wide open at high rpm until you get the tune adjusted.
Old Nov 16, 2013 | 06:34 PM
  #123
CSexy06VY's Avatar
CSexy06VY
Oh ok cool, I'm more into the off the line power, probably not going to take it on the highway until I tune it,
Thinking about getting hp tuners soon
Old Mar 24, 2014 | 12:06 AM
  #124
MikeDost's Avatar
MikeDost
question tryn to do simple/small bolts ons. if i were to get the fast 102 do i have to do anything to the engine block or to the intake itself?
Old Mar 24, 2014 | 10:53 PM
  #125
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What year car do you have??????
You MUST rep;ace the OEM valley cover bolts and install the button head valley cover bolts!!!!!
If you have a 97-2000 you have to eliminate the steam tube crossover pipe and block off the rear steam vents.
I used Two 2001+ cross over pipes and retained the rear cross over pipe.
You have to use a harness converter to use the 90mm TB
You should tune the PCM to take advantage of the added air flow.
BC
