Diff gear change
Old May 9, 2011 | 04:17 PM
jmoody66's Avatar
jmoody66
Default Diff gear change
Does anyone have suggestions on where to send my auto diff that's working fine.....to have it turned into a 3:42 for a reasonable fee? Not racing it, don't need hardened halfshafts....just a simple gear swap. It's the undesirable 05 diff. I'm in DFW Tx in case someone knows a local place as well.
Old May 9, 2011 | 04:40 PM
cranky's Avatar
cranky
in diff's you get what you pay for. RPM TRANSMISSIONS has done many diff's in my area and not one has been a problem. if you are going to do it, upgrade to 06 and above and be done with it. not cheap, but quality is always costly. i race mine all the time also. good luck
Old May 9, 2011 | 04:53 PM
jmoody66's Avatar
jmoody66
Default Agree
I don't mind paying for quality at all but this is for my stock Cadillac XlR and all I want is to not be stock and have a little edge. At best I will change the converter to a 4k setup, 3:42 gears, a tune and intake. Want to maintain the integrity of the stock engine....I do only serious mods to my Z
Old May 9, 2011 | 05:13 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Is there anyone that does ONLY gear swaps in your stock case?
Old May 9, 2011 | 05:17 PM
timd38's Avatar
timd38
I am looking also. I was thinking of contacting a 4x4 shop since they do a lot of gear changes in trucks, and I am not convinced that it is that much different.
Old May 9, 2011 | 05:21 PM
jmoody66's Avatar
jmoody66
Default Yes
If man can make it....man can modify it! Lol.
On the serious side....yes you can do gear swaps on them. At least this way you know where the diff has been and how it's been used.
Old May 9, 2011 | 11:24 PM
cranky's Avatar
cranky
RPM TRANSMISSIONS will do a gear swap. talk to tj. the corvette diff is WAY DIFFRENT than a 4X4. believe me, i built diffs for 28 years. the vette uses special tools that are completely for this diff.
Old May 10, 2011 | 02:28 AM
10silver6's Avatar
10silver6
You can just change the ring and pinon, It cost around $400 for the gear set and your seals and such, and another $500 to $600 to put it in, lucky for me im right down the road from Hinson Supercars
Old May 10, 2011 | 04:21 AM
timd38's Avatar
timd38
Thanks! I live near Corvette Sports, so I sent them an email last night.
To Diff gear change
