battery life
off.Voltage is electrical pressure.Amps are electron current.You need to do a load test on your battery.
1. Fully charge the battery. When the engine is COLD, measure the battery voltage with a multimeter. Have someone start the engine. Watch the battery voltage during the cranking process. If the voltage drops below 10 VDC,, you batter can no longer provide the correct cold cranking amperage. Voltage is inversely proportional to current. When you apply a LARGE LOAD on the battery, if the battery plates are sulfated or damaged, they will NOT be able to output the required voltage. All the modules in the car have a LOW VOLTAGE SHUT OFF. If the voltage drops very low, modules will drop off line until the voltage returns to normal.
2. Take your battery to AutoZone or Advance an have it fully tested.
When the OEM battery in my 06 Coupe was three years, it would start the car fine BUT I would get random DTCs and weird dash IPC problems. I did the crank test and during cranking the voltage would drop as low as 9.0 VDC.
New Wal-Mart battery solved that issue!
BC
BC
