Trans Cooler install help
Old Jul 14, 2011 | 07:01 PM
timd38's Avatar
timd38
Originally Posted by el es tu
had the same idea, the z06 oil cooler being used as a trans cooler would look more like it came from the factory but it turned out to be an expensive option (300 something bucks for the cooler alone) compared to the universal kits (less than 100).
I bought one from Breathless for $300 with lines. I want it as a engine cooler since it is bigger than the Z51 cooler, but you could sell the lines and keep the cooler.
Old Jul 14, 2011 | 07:10 PM
el es tu's Avatar
el es tu
I think Im going to get 2 universal coolers that will fit side to side and exit on their sides.
Mount them against the radiator. Bypass the trans cooler in the radiator and just run the external cooler.
then
Use the Z06 oil adapter/lines cut it at the the rubber section run a double sided barb on each hose to the hose going to the external oil cooler. Then possibly do the same for a power steering cooler using a small sized cooler stacked in the center above the other two.
Hopefully that would alleviate any and all heat issues...
Old Feb 13, 2012 | 10:06 PM
ZBADESTZ@Straightline's Avatar
Can you guys post pics of where and how it's mounted?
Also if you have an intercooler where did you mount it then?
Old Feb 14, 2012 | 07:43 AM
el es tu's Avatar
el es tu
they mount in the front bumper area against the radiator. you can either do what the factory does by bolting the cooler to the sides of the radiator shroud, or just attached the cooler directly to the front of the radiator otherwise you can tap into the hard lines at the rear of the car and do a rear mount trans cooler
just do a search for oil cooler or transmission cooler
here's one filled with pics:
http://forums.corvetteforum.com/c6-t...oil-lines.html
