something to prevent hydrolocking??
Old Jul 16, 2011 | 12:11 PM
Randy_medion's Avatar
Randy_medion
Default something to prevent hydrolocking??
Hi,
I just ordered a Vararam Snake Chamber intake but after reading all the horror story's about hydrolocking I'm really concerned about installing the intake (as it rains a lot here) But isn't there a temporarily (only when driving in rain) solution for it? For example, when it rains, can't I just put a sponge into the intake hole and when the sky clears up pull it out??
Old Jul 16, 2011 | 01:17 PM
Justasheet's Avatar
Justasheet
Stay out of super deep puddles. It rains a lot here too and I haven't had a problem with mine. Of course I just jinxed myself now. Think of the vararam as a snorkel to the cool air. Would you put a sponge on top of your snorkel?
Jeff
Old Jul 16, 2011 | 01:21 PM
Randy_medion
yeah but sometimes when theres a puddle on the freeway for example you can't just slam on the brakes....
Old Jul 16, 2011 | 01:43 PM
Deftly's Avatar
Deftly
I am not being flip - cancel the order while you can.
Old Jul 16, 2011 | 01:47 PM
HOXXOH's Avatar
HOXXOH
I have the solution, the testing is done, and am in process to produce them in quantity. You'll just have to wait a couple more weeks.
Old Jul 16, 2011 | 01:50 PM
sallen619's Avatar
sallen619
I've driven in some pretty bad storms with mine.
Old Jul 16, 2011 | 08:07 PM
06z06_427's Avatar
06z06_427
I would go a different route as well. My old car would overheat on the road course due to the radiator being partially blocked. Also, in my opinion, the quality isn't the best.
Old Jul 16, 2011 | 08:55 PM
LS1LT1's Avatar
LS1LT1
Same here.
True.
But in my experience, any unavoidable puddle deep/wide enough to allow that much water to enter your Vararam (or any cold air intake for that matter) is going to be SO BAD that you'll likely have far bigger problems to deal with (hydoplaning, loss of vision, electical shorting etc.). Water splashing up from another car going through a deep puddle in front of you might be a concern as well but again the above could still apply.
If it's truly that bad, even the stock airbox can still take in enough water to hurt you.
If one's fear is really that bad there are ONLY two choices....retain the stock air intake set up and/or don't ever drive when there's even a remote threat of rain/puddling.
Originally Posted by CK 6
I am not being flip
Umm, yeah, ya kinda are.
Old Jul 16, 2011 | 09:14 PM
AU N EGL's Avatar
AU N EGL
In high performance driving schools we teach students too LOOK UP THE ROAD. too avoid any things on the road / track. same with puddles. LOOK UP THE ROAD and watch were your driving
Old Jul 17, 2011 | 03:13 AM
CMY SIX's Avatar
CMY SIX
use a better intake
Old Jul 17, 2011 | 03:30 AM
LS1LT1's Avatar
LS1LT1
Originally Posted by CMY SIX
use a better intake
Oh, because with other intakes you can drive your C6 directly into a lake and your motor will still remain perfectly unharmed, right?
Old Jul 17, 2011 | 09:09 AM
6Speeder's Avatar
6Speeder
You're taking things to the ridiculous level, as usual. No matter how many emoticons you use you can't escape the fact that this design has quality and hydrolocking problems that other CAI designs minimize.
Old Jul 17, 2011 | 09:51 AM
dennis50nj's Avatar
dennis50nj
can you just show me an accurate percentage% of how many C6 corvettes with the vararam have actually hydro-locked, and proven to not have in the same exact situation with any other CAI
Old Jul 17, 2011 | 10:34 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
ok, in this one thread you've read the "recommendations" incl. a possible fix by HOX. the choice is up to you. I do recall years ago AEM made a quik disconnect near the maf for some imports; can't imagine why others haven't followed this example.
maybe em/pm HO and ask what he's doing, specifically. good luck.
Old Jul 17, 2011 | 11:48 AM
Randy_medion
but...there's gotta be a solution for the water/puddle problem lol:P maybe a plastic bag in front of it?? Will that work?
Old Jul 17, 2011 | 12:10 PM
dennis50nj's Avatar
dennis50nj
Listen, i have had the vararam over 5 years on my 05C6, i drive in the rain, heavy rain, i hit puddles on purpose to clean the bottom of the car, i drive in the winter year round in the snow, with a vararam and ccw drag pack with drag radials and skinnies, if you don't try and cross deep puddles like streams you wont have a problem. you can drill a couple holes in the lower half right before the filter and put two cap plugs in it, and pop them out if you will be driving in rain, ever try drinking a soda with a hole in the straw, or siphon gas with a hole in the hose, or hydro locking your C6 with a vararam with leaking seals
6Speeder's Avatar
6Speeder
Can't be done and you should know that. The fact is that this design is prone to the problem, while the factory and most other CAI designs have taken steps to minimize the problem. Namely, don't provide a direct path with no other escape route for water entering the intake, and providing a splash barrier to reroute the water away from the filter area.
To something to prevent hydrolocking??
Old Jul 17, 2011 | 12:21 PM
dennis50nj's Avatar
dennis50nj
the ford ranger & bronco 2 4X4 recommended not driving in water deeper then 8" and so did many other manufactures, with the stock breather, i also read wear a C6 with stock breather hydrolocked from washing his car
Old Jul 17, 2011 | 12:50 PM
DSOMC6's Avatar
DSOMC6
Why would you install a bottom feeder air intake when you live where it rains a lot?
Are the extra "few" hp worth risking the cost of a new engine?
Old Jul 17, 2011 | 01:26 PM
LS1LT1's Avatar
LS1LT1
Maybe.
And the fact is they also don't provide a direct path of cold air either, ultimately costing one the maximum performance gains that they desire in the process.
Ya can't have it both ways.
Once again, I bought a Corvette to race/drive/corner quickly with, stop well and look good but it's a VERY poor design for hauling a family of five and/or off roading/rock climbing.
That still doesn't make it poorly designed vehicle by any means.
It's a series of gives & takes and there are ALWAYS some sacrifices/compromises in the name of speed.
Long tube headers/high flow cats/X-pipes are, going by the letter of the law, illegal in EVERY single state and can get your car impounded if the officer/spot check inspector is keen/well versed enough. Yet we still do them because we want that big power gain. Why is that (potentially costly) risk acceptable but this one isn't?
People need to prioritize and figure out exactly what 'performance to safety' ratio they're looking for.
EVERY air intake system (even the factory unit) is susceptible to permitting water in (yes, some more than others), if the puddle is big enough then NONE are truly immuned to hydrolocking.
