Stroker motor numbers
Old Aug 7, 2011 | 01:44 AM
  #81
robz's Avatar
robz
Originally Posted by CTD
This thread has been so far off track, is this relavant....I'm very respectful of who you are. Maybe explain how your post & the original topic relate?
I feel it's relevant to the discussion because:
1) Accurate information is always the most useful and beneficial.
2) I wouldn't want someone to plan, design, and build an entire setup based around a 224 cam and think that it will run mid 10's.
3) It takes away from the guys/gals who have dedicated so much time, money, and effort toward running some of those record passes.
What might not be important to you may have importance to many others.
Old Aug 7, 2011 | 10:48 AM
  #82
CTD's Avatar
CTD
Makes sense now....Tx's, hopefully you caught the respectful part!
Old Aug 7, 2011 | 11:02 AM
  #83
SpinMonster's Avatar
SpinMonster
That above doesn't seem accurate.
Yeah, actually its been done with a 204 cam....10.61. Don't want to take anything away from the people who put in that time, money...ect
Cartek's cams have always been small. The 2x cam back then was based on 224/228 lobes that they gave all the lift specs for. Later these became known as XER lobes. A 228 at the time was the 3x cam. I dont want to be kill the point here but didn't Cartek get a car to go 10.61 ET with a stock LS2 cam? Getting ET down involves quite a bit with suspension and Cartek has demonstrated a mastery with this in the past. Its possible the 10.53 run was the 3x cam but if thats all you came away with from my post, you missed a lot. People today build such cam cars with lame compression while Dave Busch indicated 11.7:1 CR for the 3x cam. The area under the curve it gained was staggering. Today's C6 crowd running big peak hp cams on stock 10.7:1 CR isnt quite the same.
Tony Mamo himself using the early AFR 205's, acheived 480rwhp on his 5.7L with a 224/228 114LSA cam and I was an advocate at the time of how people dismiss the contribution of all the little add-ons from UDP to Crane gold rockers, Elec Water pumps, all of which when added together made significant changes.
Here is a post by Tony Mamo who showed a dynojet result of 480rwhp. It doesnt have the graph anymonre but there are people that comment on how it made 480. Tony lists the entire list of parts to get there which includes 3.90 gears which lower the reading a bit.
http://forums.corvetteforum.com/c5-t...yno-graph.html
Old Aug 7, 2011 | 11:13 AM
  #84
Crowhater's Avatar
Crowhater
Originally Posted by Crowhater
I am curious about this thread because I am having an engine built right now and I wonder what it will make for hp & torque. With any luck I will be installing it in two weeks.
416 LS3 stroker 416 LS3 w/Callies forged rotating assy, ARP bolts, XHP Cam, LS7 lifters, MLS head gaskets, Hardened pushrods, LS Oil pump, CNC LS3 performance heads w/dual .650lift springs, Ported oil pump, Nitrous rings, 11 compression. (235 / 259 @50 625 lift 113sep )
Does anyone have any thoughts or feedback on my question? I also bought a zo6 rear end with the 3.42 gear.
Old Aug 7, 2011 | 11:14 AM
  #85
SpinMonster
Holy.....what a nice turn around in this thread, some very good information that is very difficult to gather other than hands on
Some clarity regarding less than stellar output from the stroker builds!
I really believe mine is over cammed & I will deal & dealt with it accordingly, this thread & the last several posts have helped confirmed my thoughts.
To those who have had cam spec'd as I have the suggestion's & recommendations are that only. We/I still have the responsibility in the end to educate ourselves & make sure the end result is where we want to be.
To be frank, the vast majority of cars are overcammed with worse track results that they would have had if they had a cam that maximized area under the curve. I lost count how many cams have a flat spot up to 4000rpms they take off like you hit a 75 shot. This isnt going to match a cam that makes 15HP less at peak but more from idle to 4500rpm.
Small intake durations close the intake valve sooner increasing dynamic compression. This almost always pays a benefit down low especialyy in cam only builds and all the builds where people wont run the compression needed to have even the same dcr as the stock cam. A 224 cam at sea level with a 114+1 LSA in a 5.7L would work great with 11.4:1 and a 228 cam on a 114lsa would work with 11.7:1.
When you see huge cams in the mid 230's running 11:1 compression, they left a lot of area under the curve on the table.
A dcr calculator is something fun to play with if you have a cam card or two handy. It will tell you just how soft some builds are. At sea level with 93 octane, an 8.7 dcr is common. Meth allows more.
Old Aug 7, 2011 | 11:32 AM
  #86
SpinMonster
Certainly the cam designer can or should be able to tell you what it does in practice cant he? Hasnt he used it before?
What I see:
24 degree split
21 degrees overlap
narrow LSA
The narrow LSA closes the intake valve earlier so it brings up TQ. A 235 on a 113 peaks about right for a 6.8 liter around 6200-6250rpm. The wide split holds high rpm power out past the HP peak while adding 9 degrees overlap over a 6 degree split.
You have ported LS3 heads and only the head porter can tell you what results their heads have seen.
I think it would make about the same power with a 6 degree split based on what I saw using a 230/242, 230/234, 230/230, 230/236, all on the same engine at my expense to learn the truth about big splits.
At 21 degrees overlap and only 11:1 compression will make a rough idle and some driveability issues at 1600rpms. It will pull hard, just dont plan on a civil ride.
Old Aug 7, 2011 | 03:50 PM
  #87
SpinMonster
Originally Posted by BornSUPERCHARGED
Figures that it wouldn't be a static % loss across the board. All other things being equal, going from a stock bottom end LS2 with stock heads to a 9.2:1 402 with AFR 225s, should the longer stroke and better flowing heads end up making more power with F/I over the stock setup, at a meager 6~8psi? I've not seen or heard anything as of yet for my dyno numbers, so not sure how the TQ curve looks compared to what I had.
I think what got lost in translation is that a 403 boosted at 550rwhp if that was the number that was targeted was really inefficient. If all you werre looking for was a forged motor, 550rwhp, and longevity it would have been cheaper and more reliable to get a 427 from Katech. Superchargers are never as reliable as an N/A car. Its gotten much closer in recent years but eventually the belt starts up, accessories don't like the belt tension, tuning is more tempermental.
(powerlabs) Not quite apples to apples there, because he did not go with a stroker, he did not swap heads, and his engine had some serious issues.
Irrelevant. 9.2:1 is lower than I would use at 900rwhp. There was zero gain in anything including reliability by lowering VE like that. At 550rwhp, all you did was kill fuel economy and off idle TQ where you have no boost.
PowerLabs' unfortunate and terrible results that he had fixed, doesn't really correlate in my mind for how a properly running engine would run. In fact, he did not rebuild at 9.8:1, but at 10.5:1 which is still under stock CR.
Powerlabs and I speak on the phone all the time. What you read on the forum reflects near nothing of the real story and lots of facts were intentionally left out. The compression factor was huge in low end TQ death, killed fuel economy, and he will be the first to tell you it was an unacceptable loss. What was posted about compression is this: No one at 600rwhp or less should lower the compression at all. If it makes you feel like you did something smarter than the other 1000 guys thats OK. Its youre car. The was no legit tech reason for it unless you want to run 87 octane.
I just find it hard to believe that 0.7CR loss would account for a 10% power loss. That would mean at 9.2:1, which is over his CR loss, he would have been making >20% less power... so 550rwhp@15PSI? I think that's insane and simply don't see that happening. But I'm not an engine builder and I'm just using your example, if I'm wrong please correct it
Peak power numbers as you calculate them have nothing to do with the reality of how much of a slug a low compression motor drives when its low in RPM and off boost. Low compression pays the biggest divident in low end TQ. A H/C car making 500rwhp, that goes down one point in compression is 4% at the HP peak or 20rwhp. The TQ at peak takes a bigger hit. At 2000rpm its something like 20rwtq but the percentage is staggering. I'm sure when you get in it, it will pull hard at all the high rpm power points you quote. Where you will feel cheated is the first time you get a ride in a car with a cammed LS3 with 4.10 gears and you feel how razor sharp throttle resonse feels.
My reason is because I do not care to make a certain amount of power, I just want the engine to last a long time. If I'm leaving 250HP on the table, I don't care. I've been making my monthly payments for 10 months now, on a car that I cannot even drive because it's in the shop. I'm ready to get my car back and never be without this long ever again. I tried to convey that to Stephen and let him know I want a solution that will provide a compromise between longevity, reliability, and an increase in power (over stock).
10 months for a 403 swap with a supercharger making 550rwhp?
Well I'm in Dallas and don't take road trips to Denver, so I don't have to worry about altitude
Your passage here indicates that you seem to think my info was direcdted solely at you. As I often find myself typing when I quote someone, just because I quoted your post doesn't mean the info there didnt have to only pertain to you.
Other people read these threads besides yourself. When people do a search for these topics, they want generic info and not just a single point of view and I answered from that perspective. If someone looking for info does a search and is from New Mexico at 4500 feet or Wyoming at 4000 feet, he has just as much right to know how elevation affects power and economy. A guy in Nevada at 2000 feet should be aware that his cylinder pressures are 9% different and as such if he was looking for longevity in his daily driver that some compression loss is already built in. Here are some stats you may want to know before posting about needing or not needing elevation info. First: the average mean elevation for the United States is 2500 feet. The number of states that average over 2000 feet is 13. Number of states that have any location above 2000 feet:37 states. These guys have about 9% lower cylinder pressure, some have 30% less nearer 6500ft, and shouldnt run the same compression as guys at or below sea level. Elevation most certainly is used in boost compression calculation. Lastly lots of guys should know about this because unlike you they do make road trips that will invariably go to these places.
I know your build is solidified and nothing I typed was intended or expected to get you to change anything. It was intended solely for info to the next guy who should be aware that there are likely 1000 cars at stock compression near 600rwhp.
Site for elevation info:
http://www.infoplease.com/ipa/A0001792.html
A boost compression calculator that asks you for 3 things.....note number 3:
http://www.rbracing-rsr.com/compression.htm
One thing not stated in this calculator is that it isnt for comparing different displacement motors. A 6lb boost on a 6 liter has no correlation to 6psi on a 7 liter. Its for same motor comparison. If a 6 liter at 10psi and stock compression results in 18psi boost compression, then a 8psi 403 isnt comparable. You can actually have lower cylinder pressure on a 427 at 500rwhp than a 6 liter at 500rwhp, but, in the same displacement, you cant have power go up without increasing cylinder pressure (doesnt count exhaust backpressure releases).
I'm not running 100% meth, it's 50/50, and it will only come on at 3 or 4psi - again I had Stephen set it up for safety, not to make more power or increase my dyno numbers.
Percentage of meth has near nothing to do with detonation suppression. Water injection alone (0% meth) can increase detonation supression as if you have 120 octane. Your car with 50-50 is still effectively 115 octane. Meth was quoted as a reason that no one at 650rwhp would need lower compression. You dont need meth at low RPMs because there is no boost.
Thank you (sincere) for the compliments at the beginning of your post. I fully understand why no tuners will post in threads like these. You can share a lifetime's worth of info and give 1000 usefull facts and your only as good as the one thing a guy finds fault with. These are usually the same guys that have never ever started a tech thread of their own. You dont get compliments for the 999 correct facts and get talked down to like a servant. I have done so many installs and shared everything from cam specs to how-to threads. Still you get stomped so thanks again and good luck with your build.
Low compression = poor throttle response off boost.
Old Aug 7, 2011 | 05:40 PM
  #88
BornSUPERCHARGED's Avatar
BornSUPERCHARGED
Originally Posted by SpinMonster
I think what got lost in translation is that a 403 boosted at 550rwhp if that was the number that was targeted was really inefficient. If all you werre looking for was a forged motor, 550rwhp, and longevity it would have been cheaper and more reliable to get a 427 from Katech. Superchargers are never as reliable as an N/A car. Its gotten much closer in recent years but eventually the belt starts up, accessories don't like the belt tension, tuning is more temperamental.
Really I don't have any kind of number targeted. It's more of, whatever it makes, it makes. I already had the supercharger installed, so went with a 402 LS2 stroker instead of selling it at a loss. If fuel economy drops 3mpg that wouldn't be so bad, I had a V8 dodge ram that got 11mpg I get what you're saying though, but for me I don't envision my torque being any less across the board than what the car was stock. First gear is pretty useless as it is. Also, I have an A6 with 3.42s and a 3400 stall. I know you're talking in general and not just straight at me, so other people should take their own mods and driving patterns into account when reading this stuff.
If it makes you feel like you did something smarter than the other 1000 guys thats OK. Its your car. The was no legit tech reason for it unless you want to run 87 octane.
When other guys are trying to hit high power numbers and I'm trying to have reliability, I basically went down the checklist of "what can I do that would likely increase longevity and reliability". I didn't make my choices to be smarter than everyone else, or to have a tech reason for more power or run 87 octane - my choices were based on blowing up my stock engine and not wanting to encounter that scenario again. There's always a chance, but I wanted to reduce the chances where possible.
The first mod I ever did was getting 3.42s installed. It seriously changed how the car felt, gave it an insane "fast" feel. All the other mods I did just added to how fast it really was. It will be interesting to see how much off idle throttle response I've potentially lost by the choices I made.
No, 11 months so far But actually, the motor died in September, then in October I had it towed to the shop it's at now. Funds were hard to come by (being married, approval from the wife was harder to come by), so it sat at the shop for many months. It was not just an engine swap. It was a 6L80E transmission rebuild from Circle D, lots of parts from The DriveShaft Shop, coilovers, tires, new engine, meth injection, trans cooler, Circle D torque converter, new front bumper and front fenders, and a nearly full body paint job - only thing not getting painted are rear fenders and doors. So no it's not quite 11 months just to do a simple motor swap, a lot of it was waiting on parts to come in, and most of it was waiting for me to have the money approved to pay for it all.
Your passage here indicates that you seem to think my info was directed solely at you.
True this particular piece regarding altitude is important to many people, more to others than to me. Being a public forum I know many people will read the posts and hopefully our back and forth will have some pieces where they can relate to what I did/am doing, and where they can learn something new from you, etc. I'd hope they substitute their situation for my own and make their decisions and conclusions accordingly
I see what you're saying, and it makes sense. I understand and completely agree that I'm leaving a lot of power on the table by reducing the compression, and perhaps there are few if any real benefits from doing so - and although I feel good with my decision right now, the true test will be how much I enjoy driving the car when I get it back.
BTW, it was my understanding I would lose some throttle response with a 3400 stall torque converter, having to give it a bit more gas to get the car moving. Sounds like the combination of low CR and high stall will prove detrimental to my throttle response, guess I'll find out and either learn to live with it or make the appropriate changes.
Old Aug 7, 2011 | 07:49 PM
  #89
njgreg's Avatar
njgreg
Hey Spin, I have a question about a post from a while back concerning a build you were talking discussing. You quoted these numbers about a stock CI LS2 with TF225's but I noticed a meth kit is also on the car. Do a lot of the H/C cars making 520+rwhp require meth injection? If not, what was the reason for the kit? I realize that thread was over a year ago, but it was bumped recently and I noticed the numbers. The TF225s certainly are intriguing, but other than dpc300c(I believe that's his name) I don't see many members posting track results. Yes, track results will differ within areas but if you remember from our conversation on the phone I'm in NJ and high altitude isn't a major concern. I know another member mentioned this, but you are an asset to the site and add more useful help for free than many vendors.
LS2 C6 2007
Trick Flow 225
11.6:1 CR
G6X3
LG 1 3/4 w/cats
stock gears
Ported FAST 102
Ported TB
UD pulley
LS7 clutch al flywheel
Royal Purple fluids
93 octane w/Labonte meth injection
LS3 NPP exhaust
526rwhp/463rwtq SAE dynojet 248
Others have gotten 520rwhp on the LS2 with these heads namely Braciole.
Old Aug 7, 2011 | 08:32 PM
  #90
dennis50nj's Avatar
dennis50nj
LS2 C6 2007
Trick Flow 225
11.6:1 CR
G6X3
LG 1 3/4 w/cats
stock gears
Ported FAST 102
Ported TB
UD pulley
Royal Purple fluids
LS3 NPP exhaust
braciole got 520 according to rpms dyno and he did run a 10 6, and hit 134 mph, if you look at the video you will see he could have left harder and shifted faster,
Old Aug 8, 2011 | 09:28 AM
  #91
FloydSummerOf68's Avatar
FloydSummerOf68
Under 4k doesn't really matter much when talking about drag racing.
For a street car looking for just regular street performance I definitely agree many are overcammed because they don't see much power increase under 4k.
For me, I want a drag cam making insane power from 4k-7k. I don't really care about "off idle" power. My converter will flash up to nearly 4k and then won't see under that through the run.
Old Aug 8, 2011 | 12:18 PM
  #92
SpinMonster
I used to believe that until I was shown just how much harder a car leaves the line with 40 more TQ in that 2000-4000rpm range. Even if there wasnt a power difference down low the up top power isnt as clear cut on our engines.
An LS3 is limited by its heads with what it can use with cam size. 227 intake durations and 235 intake durations make the exact same power from 4000rpms to 7000rpms. The 21 century cam is 5 degrees overlap and the LG G6 cam is 18. Why you would run more overlap is beyond me if it isnt making more power up top? There is no insane power made by having more cam on that cylinder head. It goes back to what 99blancoss said.....combo.
Now put a G6 cam on the same LS3 but use Trick Flow 235's and you will see near 540rwhp.
Back to my statement taking into account that no one runs trick flows on an LS3....most cammed cars on this board are overcammed....and I will add: because of the combo. They wont give up the beloved LS3 head.
Your car having an auto trans is also in the minority and I agree on autos it makes no difference except for getting a big overlap cam to drive nice. If the power is the same from 4k up, dont overcam unless you have the rest of the combo.
My statement does have conditions so I stand corrected if you have the right head and dont care about driveability.
Old Aug 8, 2011 | 12:30 PM
  #93
SpinMonster
LS2 C6 2007
Trick Flow 225
11.6:1 CR
G6X3
LG 1 3/4 w/cats
stock gears
Ported FAST 102
Ported TB
UD pulley
Royal Purple fluids
LS3 NPP exhaust
Charlie from RPM showed that a stock head/cam car shows nearly 20rwhp gains from meth so yes a 500rwhp car will also. If you're at 526, expect 545 or so and the biggest gains are in the TQ. The tune is able to run max timing with optimized compression which most builds dont seem to do.....11.8:1 with a 235/245 cam. Higher compression also makes it drive better. Obviously more octane allows higher compression. Low in rpm you run normal timing where meth isnt as ramped up. Meth's biggest benefit is on really hot days where your car will pull like its 70 outside when its 100 because its lowering IATs by 30 degrees.
E85 is also an option if you get the 60lb injectors and pump needed to support the power level. I like meth because it also lowers IATs and you dont have to hunt down E85 stations.
Old Aug 8, 2011 | 12:40 PM
  #94
SpinMonster
If anyone is interested in a Trick Flow 235/G6X3 cam build using meth, please contact me. The install is in Colorado Springs and is for research on my part so I'm willing to donate the time into it.
If you already have a G6 cam with stock LS3 heads and want it to drive much better, thats even better for me.
Old Aug 8, 2011 | 12:54 PM
  #95
CTD's Avatar
CTD
Spin, I have some information that maybe of interest to you, I'm not ready to post any results yet. If you are interested send me a PM with your email & I will forward.
Old Aug 8, 2011 | 12:57 PM
  #96
LEAVINU's Avatar
LEAVINU
Where is the meth entering the intake tract to reduce IAT's?
Old Aug 8, 2011 | 01:49 PM
  #97
njgreg's Avatar
njgreg
I understand what methanol does and E85, but I got the impression that there were builds making 520rwhp+ and big torque numbers without these types of fuel upgrades. When I talked with Fran from RPM he mentioned he had a customer's car crack the 510rwhp mark with a set of Cartek 3x or 4x heads so I'm curious how different they are from the 2x heads that I have. We seem to have a numerous amount of numbers from stock CI cars, but anymore stroker builds that are willing to contribute?
To Stroker motor numbers
Old Aug 8, 2011 | 02:29 PM
  #98
njgreg's Avatar
njgreg
There were a few members curious on the exhaust setup I have on my car so here is a small clip of the car at idle. The exhaust is Kooks 1 3/4'' headers, hi-flow mid-pipe with turn-downs on the end of the pipe. Some may think it's a bit loud, but I like it Not sure how to post the actual video but here is the link for anyone curious.
http://youtu.be/KV9WcJmsuAY
Old Jan 13, 2012 | 06:55 AM
  #99
BornSUPERCHARGED
Just an update, it's still being tuned but it made 626/522 without meth - they'll probably be doing that today (not tuning to require it, just for additional safety). Factoring in that its an automatic with a 3400 TC, 3.42 gears, was built at 9.2:1CR, and we didn’t pulley down from the 3.8″ that I had on my car when the engine blew, the numbers are very pleasing.
No sheet yet but those numbers are better than the 571/505 I made previously. Even if the #s down low are lower than before, the high stall will get me into the band much faster.
Oh, the best part.. 24mpg hwy. Some said 9.2:1 was too low, despite that being what the ZR1 has, but I'm perfectly happy with the results
Old Jan 13, 2012 | 07:44 AM
  #100
pit-man's Avatar
pit-man
Any other stroker builds? I'm very curious how substantial the gains would be if I swapped out my ported 243s for an AFR or Trick Flow head. Anyone have any experience with before and after gains, whether it is stock CI or not?
I have 2 Strokers:
Vette:
First was H\C (AFR 225's & Fast) on my 346, dyno was 434/400 and it ran 11.33 ET @ 124
Changed to 383 Stroker, no porting just out of the box ARF 225's and a Fast 90. Dyno was 480/445, Et dropped to 10.66 @ 129
Silverado:
402 Stroker with same AFR 225's and Fast 92. Dyno is only 445/413 but it pushes a 4000 lb truck to 11.14 @ 120
The cam is very mild, 232/601, great street machine.
I would not worry that you don't have 550 hp Stroker. That is Just dyno numbers. See how it produces numbers at the track. Get the right gear, tires and suspension and you will be happy. Robz that posted earlier... is a master at that.
Sorry I don't have the 383 dyno and slip handy. I do have the slip and vid of the 10.66 run in the ZO6 fast list on this forum if you want to look at it.
Pitt
