A6 on dyno
Old Dec 30, 2011 | 12:58 AM
Redrocket1045's Avatar
Redrocket1045
Default A6 on dyno
When your A6 car is on a dyno - what is the norm - run it on paddles in 3rd gear or 4th gear? Thanks.
Old Dec 30, 2011 | 02:33 AM
filmjay's Avatar
filmjay
St. Jude Donor '10
4th from 3k is the norm
Old Dec 30, 2011 | 07:59 AM
taken19's Avatar
taken19
Track Junky
Running from 4th produces the least parasitic losses since it's generally 1:1 ratio
Old Jan 1, 2012 | 11:22 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
I run them from 2000 rpm to 6500 rpm in 4th. There is no 1:1 in the A6. 4th is 1.15 in the A6.
Old Jan 1, 2012 | 11:35 AM
Red06Vette's Avatar
Red06Vette
If the dyno was done in 3rd, what would the difference in HP reading be?
Old Jan 1, 2012 | 12:06 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I don't know about other dyno's but on the dynopack that my guy uses he changes a setting to compensate for the ratio so that you get a correct reading.
Old Jan 1, 2012 | 12:14 PM
glennhl's Avatar
glennhl
By the way, there is not a 1 to 1 gear ratio in the A6. Run it in 4th, it's the closest at 1.15 to 1. If you run it in third, that's fine, you'll just show a little less horsepower. And, of course, this is perfectly fine if you are using the dyno for what it's meant to be used for, a tuning tool. Just make sure you dyno it in third again after you do your mods and/or tuning. A dyno is not that good for an absolute number, but it's great for a comparison.
Old Jan 1, 2012 | 01:22 PM
LS1LT1's Avatar
LS1LT1
Old Jan 1, 2012 | 04:42 PM
Red06Vette's Avatar
Red06Vette
Thanks for the info!
Old Jan 2, 2012 | 11:11 AM
Gering's Avatar
Gering
Tolero Apto Victum
I always learn something new on here.
Old Jan 2, 2012 | 02:37 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I do them in 4th gear here, as they said there is no true 1:1 like with the manual cars.
Unlike the older 4spd cars that had to have a Tech II or laptop to keep the car in gear, the paddle cars will stay in gear during sport mode which makes is very nice. Generally do a 2500-redline pull depending on the cam setup what redline would be.
Old Jan 3, 2012 | 12:54 AM
madmax4499's Avatar
madmax4499
does anybody lock the converter clutch for the dyno?
Old Jan 3, 2012 | 10:16 AM
pettvette's Avatar
pettvette
CI 5-6-7-8-9-10-11 Vet
My 08 A6 on the Dyno at the Holly LS Fest in Bowling Green Ky.. 370hp & 363tq completly stock done in 4th at 6k rpm.
http://www.youtube.com/watch?v=Exc7U...okdVhqwrBRvVzs
To A6 on dyno
