Multiple Handling related lights going off! PLEASE HELP!!
Old Jan 19, 2012 | 08:33 PM
GM Power4Life's Avatar
GM Power4Life
Ran codes. It was B0040 right front wheel speed sensor circuit history. I replaced the wheel bearing assembly with the built in sensor today and I am throwing the same code still at 60mph! So now it's down to the wiring harness?
Has anyone chased the harness down? Where does it go? Any suggestions?
Old Jan 20, 2012 | 04:56 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
http://forums.corvetteforum.com/c6-t...need-help.html
Old Jan 20, 2012 | 07:23 PM
GM Power4Life
Thanks a lot. I'll research this. I don't have a voltage meter tho... My electronics skills aren't too great. A test light is about the extent of my electo-skills... might have to go to the dealer
Old Jan 20, 2012 | 10:06 PM
Bill Dearborn's Avatar
Bill Dearborn
Originally Posted by needcheese
It has been awhile since I have done or heard anything about ABS. I believe that the sensors are magentic. If your rotors had the metal to metal contact with no brake pads. The metal from that can sometimes ruin the sensor. A friend of mine always replaces any ABS sensor that gets any metal on them (this is on any type vechile). I would check the ABS sensors for metal on them. I hope this help. Good luck.
That won't happen with the sensors on a Vette. They are sealed inside the bearing. When you replace the bearing you replace the sensors.
Bill
Old Jan 20, 2012 | 10:31 PM
GM Power4Life
Yeah I replaced the front right just to be sure. But it's still throwing the code
Old Jan 21, 2012 | 12:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
To read the DTCs for the EBTCM,, read them when the problem HAPPENS. If you turn OFF the ignition, you clear the DTCs and the EBTCM has to go thru it circuit checks and warm up before it looks for and post the DTCs. If your DTCs only happen during dynamic driving events, read them AFTER it happens and before you turn the IGNITION OFF
I posted this in one of your other post for the same issue:
Ok boys,,, I will add some stuff that I figured out for the C5s. Its pretty much the same for the C6.
The Wheel Hub speed sensors are pretty much bullet proof. There NOT very complicated when you take them apart.. These are C5 units but the C6s are not that much different and work the exact same way:
Its just a coil of wire around a plastic spool a small circuit board to connect the coil to the harness and the harness/plug assy.
Another fact that you need to know, the sensor output is an AC signal. Its a pulsed DC but the AC setting reads it better.
All the years that I have been dealing with wheel speed sensor issues (since 97) I have NEVER seen ANY wheel speed sensors FAIL.
What does fail and they fail a LOT are the crappy female pins inside the connectors on the main wheel speed sensor harness connector on the frame and the female plug in the sensor jumper harness
Heres an example of a NEW Female connector vs a BAD used female connector. The one on the RIGHT is BAD!!!!:
If you use a metal pick, you can reshape the little metal tung and make the proper connection. You can also purchase a new female connector pigtail. DO NOT get if from the stealership. There $26 each!!! Ask me how I know! Get them from the local parts store or Gene Culley www.gmpartshouse.com for a whole lot less!!
For easy troubleshooting,, you can read the wheel sensor resistances and voltages (when you rotate the wheel right from the EBTCM main connector:
2001+ shown
Long Story made short, there are TWO female connectors on EACH front wheel and ONE on each rear wheel harness connector that need to be checked for proper female pin grip. If the female pin is all spread open,, it is most likely part of the problem. I use an old MALE pin to check for proper female pin grip/connection.
If you slide the male pin into the female pin, there should be a nice tight fit and it should take a little effort to extract it and insert it.
Yea,,,,, I know what that sounds like!
Hope this helps!
BC
Old Jan 21, 2012 | 01:25 PM
needcheese's Avatar
needcheese
Bill
Thanks for the info
Old Jan 21, 2012 | 01:34 PM
GM Power4Life
Thanks Bill! I checked both front connections and everything looks good and clean. It was previously throwing the lights at 60-70mph. I drove to the dealer this morning and couldn't get it to throw a code. On my way home I hit 90 and TC/ABS/AH all went off.
Old Jan 21, 2012 | 02:06 PM
djbrun's Avatar
djbrun
It has to be a difference in speed readings of 12mph or greater 3 times in a 200 millisecond sample. Below those speeds you are probably falling just inside that error range.
I don't think your dealer will go for a ride that fast to monitor the signals at that time.
Be sure to do a wire wiggle test when performing your continuity testing, and inspect your connections very carefully.
DJ
Old Jan 21, 2012 | 02:27 PM
GM Power4Life
Yeah I'm starting to think its my tire size difference. I mean that's a long shot. But I can't make any lights come on until 65ish. Maybe that's when it falls into the parameters you just mentioned
Old Jan 21, 2012 | 02:39 PM
djbrun's Avatar
djbrun
Your tire sizes shouldn't throw a light, (Your diameter difference is the same as mine) but if you know someone with a slightly smaller front tire diameter that could let you try it out. That wouldn't be a bad test.
DJ
Old Jan 21, 2012 | 03:15 PM
GM Power4Life
Unfortunately I don't have any friends with corvettes. According to bfg. My front tires are 26" and rear 27". So I think your right about the difference.
Old Jan 22, 2012 | 09:45 AM
  #33
cleanerPA's Avatar
cleanerPA
Stock sizes are 25.7" front, 26.9" rear. That sounds fine, although it's really not the height differences, it's the circumference difference that matters- the percent difference must be kept constant. Stock is 813F, 775R. Mine are 823F, 792R. Mine are about 1% off- 96.23 vs. 95.33.
Stock Z06 sizes are 816F, 783R, comes out to 95.96. So there is definitely no problem running tires that are 0.7% less revolutions per mile, but if yours are significantly less or more, you might have an issue.
Old Jan 22, 2012 | 10:05 AM
  #34
GM Power4Life
My rear are 789 (27") and fronts are 801 (26"). I'm not sure how you got your percentages.
Old Jan 22, 2012 | 10:06 AM
  #35
GM Power4Life
I apologize. Fronts are 769 (27") and rears are 801 (26"). Is that too big of a difference?
Old Jan 22, 2012 | 11:52 AM
  #36
cleanerPA's Avatar
cleanerPA
I just divided the rear by the front to get a ratio of rear to front. It looks like yours are right about exactly the same as the Z06 ratio, so you should be fine. Sorry it's not as simple as that.
Old Jan 22, 2012 | 12:21 PM
  #37
GM Power4Life
Yeah.. I checked codes this morning an I have 0040, B0161, and B0561.
Old Jan 22, 2012 | 07:03 PM
  #38
crimlwC6's Avatar
crimlwC6
I had similar problems and I believe it is either the tread or size of the nitto invos tires. I still get engine drag active messages unless I run with TC off. I would get the service active handling and other messages. Be sure your tires are inflated properly ( I know that sounds dumb but it caused problems for me). Do a search for active drag and see all the people running invos getting the code. Try turning the TC off and see if you get the message.
Old Jan 22, 2012 | 08:46 PM
  #39
GM Power4Life
I'm running G-Force TA KDW. And I've never seen the engine drag message. I still throw my codes regardless of TC on or off. But it seems to be more intermittent now that I've checked all my plugs and grounds. Unfortunately it still happens...
