failed h/c project...
Old Feb 21, 2012 | 12:10 PM
  #41
marine&hisvette's Avatar
marine&hisvette
Not that I know of but I highly recommended to use the DYI thread cam swap. Now if your doing more then that just ask on forums. I did a h/c package and some other odds and ends. Ls1howto has a really good write up for h/c for the ls1. I got enough pictures to make an entire h/c swap guide including the little odds & ends.. so you don't end up doing what I did or warping your intake manifold. Yes your intake will need torqued in a certain procedure or you might warp it.
Old Feb 21, 2012 | 12:17 PM
  #42
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
Originally Posted by family-man
alittle off topic but is there a book to order to do a cam swap? Im going to be ordering the "how to build high perf LS1 book" is there any other book you recommend? I have a LS2 if that makes a diff
If you want, PM me your email address and I can forward the 'list' of references I used to do my cam swap. I did a ton of research ahead of time and saved them all for future reference.
Old Feb 21, 2012 | 01:18 PM
  #43
ctusser's Avatar
ctusser
I have that book and at this point its a bit dated. Better to get more current information elsewhere.
Old Feb 22, 2012 | 02:28 AM
  #44
SpinMonster's Avatar
SpinMonster
My first cam swap was on my 2001 corvette. I started about 3pm on a Sat afternoon and finished about 9pm on Sunday night. It was around 5am on Sunday when I jumped out from under the car with the cam in my hands and no one was there to hear me say, "I did it!".
All I heard was crickets outside.
Now taking my time its about 10 hours. I lost count of how many I've done.
Old Feb 22, 2012 | 07:36 AM
  #45
1fastbob's Avatar
1fastbob
Mine can be driven the 400 miles to your location for a cam install any time you say.
Old Feb 22, 2012 | 10:19 PM
  #46
SpinMonster
....And I will likely want to install one the first week in June.
Old Feb 22, 2012 | 10:31 PM
  #47
1fastbob's Avatar
1fastbob
Interesting, we may need to soon speak by phone. I will PM you some info and if you have time and wish to iron out the details we can talk.
Bob
Old Feb 23, 2012 | 09:48 PM
  #48
marine&hisvette
Found the issue!!!!!
I took this pic as I was looking at it for the first time. Was easier to take a pic the squeeze under the car and pop my head up
Old Feb 24, 2012 | 01:49 AM
  #49
SpinMonster
Awesome!
With that fixed, you will enjoy a fast new car.
Remember: put the o-ring on the pick-up tube and slide it into the oil pump by turning the unbolted oil pump onto the tube. Lock-tite the bolt on the pick-up tube.
Old Feb 24, 2012 | 04:46 AM
  #50
taken19's Avatar
taken19
Track Junky
Good to hear it wasn't a bigger issue. Sucks to have to take it all apart again, but it could have been worse.
Enjoy the car once back together again!
Old Feb 24, 2012 | 06:44 AM
  #51
RamAir972003's Avatar
RamAir972003
Default Nice Job
Nice Job now you can change your title...... Spin for the Win... hope you enjoy your car now...
Old Feb 24, 2012 | 08:40 AM
  #52
JUIC3D's Avatar
JUIC3D
It definitely could have been worse.
Matthew, I take it you received the package? It should have gotten there by now.
Originally Posted by RamAir972003
Nice Job now you can change your title...... Corvette Forum for the Win... hope you enjoy your car now...
Fixed it--with all due respect to Spin, CF identified the problem in this thread, and the original thread, long before he posted. Spin is good, but this one was a no-brainer
Old Feb 24, 2012 | 08:59 AM
  #53
wazslow's Avatar
wazslow
Glad to see you found the problem! Sucks you had to pull it all back apart, but it will be a good feeling when you fire it up and the oil pressure jumps up to 40psi!
Old Feb 24, 2012 | 09:41 AM
  #54
marine&hisvette
I'm putting the new o ring in today and going to start it up when I get the pulley on.. Figure it wouldn't hurt to test it out just in case. I'm still debating on what might of tore that o ring like that? Any thoughts or was it just worn out. I surely hope nothing got sucked up in it.
Old Feb 24, 2012 | 09:44 AM
  #55
JUIC3D's Avatar
JUIC3D
You pinched it when it was reinstalled. Any nick, regardless of how big or small, will get exacerbated as soon as the motor fires up. 40+psi of pressure would have ripped it in half as soon as you turned it over and bam, it's done.
Good luck with the reinstall
Old Feb 24, 2012 | 04:13 PM
  #56
SpinMonster
but I thought he was talking about having sold him the head/cam package from my car.
The O-ring was a no brainer.
Old Feb 24, 2012 | 04:14 PM
  #57
JUIC3D's Avatar
JUIC3D
Ah, very good. Nice job on the after-the-sale support.
To failed h/c project...
Old Feb 25, 2012 | 12:18 PM
  #58
marine&hisvette
Nah spin you are a very legit guy to deal with. I'm sure if there was an issue with anything you sell you would take care of it in a proper manner.. If I did have an issue I wouldn't rant about it without negotiating with you first over phone. I am changing the title now.... as you will see in this video thanks guys for the support and help! I will finish installing everything and take her for a drive without 02 sensors installed just to get gas.. about a 1.5 mile round trip.
Old Feb 25, 2012 | 12:23 PM
  #59
JUIC3D's Avatar
JUIC3D
Outstanding Matthew, glad she hit 40psi like a champ. I remember that feeling very well.
Congrats on a successful h/c swap. Let's get a mod in here to change the name of this thread. "Successful h/c project!" sounds much better
Old Feb 25, 2012 | 12:35 PM
  #60
marine&hisvette
Thanks Justin this owes a huge part to you. only other issue I'm having is the darn o2 sensor extensions.. Well I ordered one and it's able to plug into the rear but not the front plugs. Apparently there a really big difference. Now I debating on splicing off the o2 sensor extensions plug and hard wire the extension and the wire harness. Proper seal them together and wrap them in cool tape. What you guys think? I plan on to cancel the rears. One more final question.. Can I run a wide band in say the driver side 02 port and just use 1 02 sensor on the passenger side.. basically I don't want to remove the headers to weld in the bung.
Here's the front 02 plug
And here's the 02 extension that plugs into the rear but not the front
