failed h/c project...
Old Feb 25, 2012 | 12:47 PM
  #61
Joe_G's Avatar
Joe_G
St. Jude Donor '08
You need the pre-cat 02 sensors in both sides.
I wouldn't personally drive the car down the driveway with no 02's. It could wash down the cylinders with gas and ruin the engine or at least foul the plugs. Probably wouldn't do that, but I wouldn't risk it as it won't run properly with no 02's.
There is a an extra set of wires on the innovate lc-1 which emulate a narrow band so you can splice those into your system, but their instructions are confusing. I ran ran the wrong wires to my wideband the first time I tried.
Personally I just left my front 02 sensors alone and ran my wideband behind my cats in one of those bungs. That's what all the dyno tunes use if you think about it.
Old Feb 25, 2012 | 12:52 PM
  #62
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
Joe is right. Don't drive w/o 02 sensors. You're asking for trouble.
The front and rear 02s have different plugs, presumably to make sure they're never crossed or plugged in incorrectly.
Get the rfront 02 extensions and do the job right. You can splice, but again, you're asking for trouble. Those wires are probably the single most important in the entire engine and you don't want to risk having the wrong voltage.
Have guys spliced in 02 sensors? Sure, but I think you're asking for trouble if you open that can of worms.
Casper electronics has some really nice 02 extensions in various lengths. They're a little pricier than others, but they use OEM connectors and OEM wiring so there's no worry of voltage spikes or anything else strange happening. I think it was ~$70 for the pair.
Old Feb 25, 2012 | 12:54 PM
  #63
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Casper makes OEM quality wiring harnesses. I recommend them too.
Old Feb 25, 2012 | 01:37 PM
  #64
marine&hisvette's Avatar
marine&hisvette
Awww darn well I get the 02 sensors in march 1st... I just ordered the complete set. I wont need the rears because I'm running cat less. Sucks how that is the only thing stopping me to go get it tuned...
Old Feb 25, 2012 | 01:42 PM
  #65
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Any parts store sells the 02 sensors for about $50 each or less..I wouldn't let that delay me a week! OF course you need the extensions. Sorry I don't have a set or I'd send them to you.
A local speed shop might have them?
Old Feb 25, 2012 | 01:49 PM
  #66
marine&hisvette
I have about 8 02 sensors... 4 stock, 4 that came with z06 system I bought. I'm good on those and that's why I didn't mind to splice them up a but But yea 02 are very important and especially with larger injectors untuned. Man I just want to take it to the gas station.... It's been about 2-3 months since she last moved
Old Feb 25, 2012 | 01:58 PM
  #67
Joe_G's Avatar
Joe_G
St. Jude Donor '08
If you have larger injectors and no 02's I SURELY wouldn't even start the car anymore! You really don't want to wash those cylinders down.
Does your oil smell like gas? Might want to change it.
I'd suggest you flatbed your car to a tuner, between larger injectors and a cam, it's not going to run worth a darn and is going to be dumping fuel. At a minimum I'd put in my stock injectors to get there and swap back over there. Why did you put larger injectors in? Stock ls2's are good to about 500 rwhp, mine are fine at 472.
Old Feb 25, 2012 | 02:06 PM
  #68
marine&hisvette
I will be getting nitrous soon but the injectors came with the h/c/I swap I done. I had to swap mine because he was returning back to stock. Just 40lb nothing to big but I'm Want to run a 175 shot. I actually plan on installing everything and take it to rpm and let them tackle the tuning. Yea I just did a fresh oil change right before the last start up.
Old Feb 25, 2012 | 02:13 PM
  #69
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Dunno how far they are but I'd put in stock injectors to drive anywhere. Having improperly scaled injectors is not good for the car. You can drive a cammed car on a stock tune, it'll get you there, check engine light gleaming in your eye, but it's not smart to drive with bigger injectors that aren't scaled.
Old Feb 25, 2012 | 03:42 PM
  #70
taken19's Avatar
taken19
Track Junky
That's what I did. Swapped the injectors on the dyno, only takes 10-15 min.
Old Feb 25, 2012 | 03:47 PM
  #71
KB9GKC's Avatar
KB9GKC
Originally Posted by Dragracer_Art
Typically the valvetrain will get real noisy when the lifters collapse with no oil pressure.
If the motor is otherwise quiet, and you are reasonably confident you put it back together correctly, I would try to put a mechanical gauge on it to verify oil pressure first.
If a mechanical gauge screwed into the motor reads zero... THEN you have a problem.
It could be as simple as a bad sender. They DO go bad pretty regularly.
Old Feb 25, 2012 | 06:03 PM
  #72
marine&hisvette
Darn I don't have any sotck injectors so looks like I'll just trailer it everywhere
Old Feb 25, 2012 | 07:28 PM
  #73
taken19's Avatar
taken19
Track Junky
What happened to yours?
Heck, you may get and have someone local willing to let you borrow a set for a couple days.
Old Feb 25, 2012 | 09:01 PM
  #74
marine&hisvette
I traded my stock for 40 lb but I can haul my car with my truck to rpm... Truck gets about 16mpg but hauling prob about 10mpg highway. I have a lot of parts coming in this week anyhow. I Really want to start the car up and let it warm up to make sure nothing else goes bad. Before I take it to the tuner. Anybody has extra stock injectors. I'll pay shipping both ways and give you a deposit for you to hold on until you receive them back.
Old Feb 26, 2012 | 05:16 PM
  #75
marine&hisvette
So I started the car up after I finished installing the exhaust to hear how it'll sound but I couldn't just leave it at that. I ended up driving it just to the gas station. Well I go to the gas station and on my way back the damn clutch line blew... I got it home safe without a clutch and got to looking around and found the rubber clutch hose close to the exhaust melted and ruptured.. I wire tied it but that melted and it sat on my exhaust for the 10 mins it was running.. Hmm I see it as a good thing... Now time to get tick master clutch kit
Old Feb 27, 2012 | 02:23 AM
  #76
SpinMonster's Avatar
SpinMonster
I have a Spec Twin disc new in the package if you want it. If my present buyer backs out I can sell it to you for $700. It was 1200 new.
With nitrous 175 shot youre looking at 650-700rwtq and will need something beefy. This holds 900rwtq. Its the twin carbon model.
Clutch swaps are labor intensive but easier than a H/C swap on the tech side.
Old Mar 3, 2012 | 06:24 PM
  #77
SpinMonster
So how is it running?
100 more HP has to have you smiling.
To failed h/c project...
Old Mar 3, 2012 | 06:55 PM
  #78
Muchtodesign's Avatar
Muchtodesign
Hey Matt..... I have a set of stock LS2 injectors..... Let me know if I can help.... I won't ask you for a deposit....I will trust you. But paying for the shipping would be nice..... I will pay for the shipping up front so you don't have to wait.....
JML
Old Mar 4, 2012 | 12:06 AM
  #79
marine&hisvette
Don't sweat it and thanks guys. I just hauled it to rpm in Rayleigh, Nc. They're back up in work due to tax returns but they'll be starting on it Wednesday. I'm just having them do the aps clutch line mod and installing my wideband then tuning it. I'm excited!!! They was surprised it fired up right away also
Old Mar 4, 2012 | 06:51 AM
  #80
taken19's Avatar
taken19
Track Junky
Matt, where did you get that hood? And how much? Looks great!
Keep us posted on results of the tune...
