shock install
Old Mar 22, 2012 | 12:52 AM
NARIMAN's Avatar
NARIMAN
Default shock install
i installed the shocks and on one side the upper bolt is spinning together with the shock
how to tighten that bolt so shock will not spin , what tool to use?
thanks
Old Mar 22, 2012 | 01:49 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
On TOP of the shock rod there should be two flats for a wrench or a HEX or a allen hole to hold the rod. Take a look. Hold the top of the rod with (what ever tool it requires) while tightening the nut.
BC
Old Mar 22, 2012 | 10:11 AM
LFZ's Avatar
LFZ
Go to O'Riellys and get the shock absorber tool.
Old Mar 22, 2012 | 11:56 AM
Mike's LS3's Avatar
Mike's LS3
It made my shock change easier and reduced the cursing dramatically.
Old Mar 22, 2012 | 01:46 PM
FloydSummerOf68's Avatar
FloydSummerOf68
BC
Looks like a waste of money. It doesn't take any longer to do it with the proper hex/allen tool.
Old Mar 22, 2012 | 01:54 PM
el es tu's Avatar
el es tu
thanks
you have to hold the pin top in place while undoing or tightening the nut
i tried vise grips and every wrench available without success, then I found you really need to get a socket thats made in the shape of the top of the pin.
I think it was 2 to 3 bucks from napa.
Old Mar 22, 2012 | 05:04 PM
LFZ's Avatar
LFZ
You're right if he is taking off or installing an aftermarket shock, but the stock shocks have a rectangular shaped end which makes life a lot easier when using the tool.
Old Mar 22, 2012 | 10:16 PM
NARIMAN's Avatar
NARIMAN
thanks
To shock install
