LS2 Dyno guesses?
Old Oct 13, 2012 | 03:31 AM
Wild's Avatar
Wild
490rw and 475tq
Old Oct 13, 2012 | 01:34 PM
JayplaySS2's Avatar
JayplaySS2
Pics now
Old Oct 13, 2012 | 02:07 PM
SpinMonster's Avatar
SpinMonster
Originally Posted by Joe_G
480/430
Advanced induction heads never made stellar power on any of the cars I used them on. I tuned all of those builds myself on both a dynacom and dynojet.
Old Oct 13, 2012 | 02:13 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Remove the tb spacer (throw it away, I've read reports of them cracking after a while and causing a vacuum leak). That will give you room to get the ls2 maf in before the TB. Use two pieces of silicone (or Fernco) to connect it all up to the air cleaner. You should tie in your valve cover breather to the setup...but it will be ok to drive to the dyno if you don't feel like fooling with it.
Old Oct 13, 2012 | 02:42 PM
JayplaySS2's Avatar
JayplaySS2
Anyones guess
I have run the spacer on all 3 C6's and never had an issue. When I installed the Spacer on this one it was to smooth the transition for the stock TB into the FAST (even with the Vmax ring inside) and it made a huge difference in light throttle feedback, amazing difference.
I'm going to screw with it a little later and see what I can do. Could I drive (highway) with the LS3 maf connected without the proper scaling...?
Anway, this will be my final round of mods and then on to a 10-11 GT500 (another thread right there ) since my wife does want a second child and I need a little more rom and can't begin to afford a GTR
Old Oct 13, 2012 | 02:50 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by JayplaySS2
Anyones guess
I don't think it will run at all with a ls3 maf...the scaling is night and day.
If you don't want to throw away your spacer then don't, but my idea would still work - if you removed it, you'd have room to put your maf in and seal it to the TB and air cleaner.
Old Oct 13, 2012 | 05:38 PM
JayplaySS2's Avatar
JayplaySS2
Thanks for the input gentlemen
Old Oct 13, 2012 | 06:19 PM
taken19's Avatar
taken19
Track Junky
It didn't for me, but I have a 2005 LS2. I have heard that ECU is unique to that year and is very finicky. The LS3 MAF wouldn't let the car run for more than a few seconds at a time before stalling out.
I had to borrow parts from Joe G to make it to the tuner (70 mile trip each way), then swap back on the Dyno.
Old Oct 13, 2012 | 06:50 PM
JayplaySS2's Avatar
JayplaySS2
Originally Posted by Neumonic2002
Good luck Jason!
My last tuning session netted me 503/450 on a mustang dyno in 100 weather, JoeG was here in STL around that time to verify how nasty hot it was here.
Your a solid wrench man and I know you had your 243's worked over pretty good so I think you will be right at your goal numbers.
John
Hope you're doing well sir
I'll be doing the install in Vengeance racing parking lot, no other way, tried everything today. Oh well-
Old Oct 15, 2012 | 11:42 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Doing well, thanks Jason.
Do you have HP Tuners? maybe I can talk my tuner into emailing you the LS 3/7 MAF scaling from my tune?
Old Oct 17, 2012 | 07:25 AM
HC Mechanic's Avatar
HC Mechanic
Originally Posted by LEAVINU
No faith in the 243's yet again. You have a bigger cam, bigger FAST/TB yet I made more hp and tq then you when running the EWP at 364ci. Oppsss
Now these 243's are making over 600rwhp.
Love your avatar pic by the way!
My RPM 243's are pushing almost 540rwhp now w/stock displacement.
Going from full bolt on's, to cam and heads was over a hundred rwhp increase on my LS2.
Glad to see your stroker is making some serious power with your 243's. It'll be interesting to see what mine do with the next round of mods.
Old Oct 17, 2012 | 10:13 AM
LEAVINU's Avatar
LEAVINU
Long live the 243's!
Old Oct 17, 2012 | 10:54 AM
  #33
FloydSummerOf68's Avatar
FloydSummerOf68
I'd be disappointed if it didn't make 500rwhp
Old Oct 17, 2012 | 01:39 PM
  #34
JayplaySS2's Avatar
JayplaySS2
If it doesn't I'm leaving it there
Old Oct 17, 2012 | 01:59 PM
  #35
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Are you adding meth or milling the heads?
Old Oct 17, 2012 | 02:25 PM
  #36
Toxic c6's Avatar
Toxic c6
im guessing 495rwhp 440rwhtq. I put down 506rwhp 444rwhtq with same cam but with TFS 225cc heads. Im going to get my fast ported and go back in actual good weather and hope for 515-520rwhp.
Old Oct 17, 2012 | 04:44 PM
  #37
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
When are you putting it on the dyno?
To LS2 Dyno guesses?
Old Oct 17, 2012 | 05:13 PM
  #38
JayplaySS2's Avatar
JayplaySS2
No sir, no meth. The heads were milled just enough to bring the compression back after porting. Considered F/I in the future and didn't want to complicate things.
Nice job on yours- I have a 2 year old and my funds are filtered to Disney movies more than an LS2
Next Saturday, I'll be sure to report back-
Old Oct 17, 2012 | 05:23 PM
  #39
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I hope you don't need to get a ride home then.
I hope I'm wrong with my estimate above. But I keep posting as I for some reason want to prepare you for disappointment. Your car will still be blazing fast and a 10 second machine on a cold day if you launch correctly. P.S. I was hoping for 500 too in my car with AFR heads and a larger cam than yours...no dice.
I know it was a real accomplishment when Charlie got 500+ rwhp from his 243 ported headed ls2 and he had meth, EWP and a razor sharp tune IIRC.
Keep in mind too, if you end up going razor sharp on your tune to get your number (which you often can get a number if you go 13.0+...I'd never use that on the street) you will want to back it down for street use. I had to take timing out of my best dyno tune on the track when i was running in the real world in the heat...I scan all my runs so I know when I'm pinging.
Old Oct 17, 2012 | 05:41 PM
  #40
JayplaySS2's Avatar
JayplaySS2
You gonna come get me Joe?
I really don't even care, well see what it does and let Vengeance make a solid safe tune. I'm more interested in how the Halltech feels around town with a fresh tune
If I don't like it I may go larger car (5.0/GT500) or redo the H/C (G6X3/TFS) ....or buy a scooter and forget keeping up with the Jones'.
