LS2 Dyno guesses?
Old Oct 17, 2012 | 05:50 PM
  #41
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by JayplaySS2
You gonna come get me Joe?
I really don't even care, well see what it does and let Vengeance make a solid safe tune. I'm more interested in how the Halltech feels around town with a fresh tune
If I don't like it I may go larger car (5.0/GT500) or redo the H/C (G6X3/TFS) ....or buy a scooter and forget keeping up with the Jones'.
I'd come help ya...sure...but recall I'm the one telling you, don't set your expectations so high!
Your car is going to feel fast. Really fast. Traction will be a problem over 4500.
If you want in on the 500 rwhp club a g6x3 meat stick and a set of TF 225's are the way to get there.
Old Oct 22, 2012 | 11:27 PM
  #42
marine&hisvette's Avatar
marine&hisvette
sooo numbers sir?
Old Oct 23, 2012 | 04:28 AM
  #43
Wild's Avatar
Wild
@ Marineandhisvette - he said the 27th lol
Old Oct 27, 2012 | 02:14 PM
  #44
JayplaySS2's Avatar
JayplaySS2
482/435 with 2hr drive to get there. Car runs amazing. Ohwell, stop trying to chase a number on a strict budget.
Old Oct 27, 2012 | 02:41 PM
  #45
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by Joe_G
501 with those mods (stock based heads) must be a record. Your car backs it up with performance for sure.
I'm standing by my comments above though on this one.
Time will tell, I hope I'm wrong!
I'll be the wet blanket here. Here is what I'm thinking.
You didn't mention compression so I'll assume stock 10.9. I'll also assume you are running on a Dynojet 248 SAE Smoothing 5, and that you have stock gears. Based on my setup and similar setups I've seen I'll say:
480/430
Which is nothing to be ashamed of. Your 112 cam will help low end TQ at the expense of some top end.
It's enough to be a 10 second car on a cold day.
To get over 500 on an LS2 you need every last mod, including Trickflow heads (or shaved heads, 12.5 compression and METH), light flywheel, electric water pump, A/R or LG expensive headers. A few dyno tricks such as super light wheels, etc. don't hurt.
Great results. Told you it'll feel fast.
Old Oct 27, 2012 | 03:02 PM
  #46
JayplaySS2's Avatar
JayplaySS2
Show off
He said he could have gotten 5-6 more but since this is my DD, I chose safety over leaning it out. Wonder what a G6X3 would do, don't want to do the heads again really. Getting sick of mods...for a while anyway.
Old Oct 27, 2012 | 04:47 PM
  #47
taken19's Avatar
taken19
Track Junky
Good numbers!!!
We were virtually identical then. I made 485/440 with almost the same setup.
Old Oct 28, 2012 | 12:53 PM
  #48
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
I was really pulling for you Jason! Glad the car feels and runs strong.
Old Oct 28, 2012 | 12:59 PM
  #49
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Show off
I wouldn't put in a g6 with stock ported heads. It's a huge cam that needs huge heads to go with it. The killer combo is Trick Flow 225's and the G6. It's really a big cam for max effort builds, not for a DD I'd say. If you want 8-10 rwhp for your dyno satisfaction, get an electric water pump.
Realize you won't feel that difference; it might show up on a time slip but you don't race that much I don't think.
Old Oct 28, 2012 | 01:49 PM
  #50
JayplaySS2's Avatar
JayplaySS2
I look forward to your replies, always accurate. I'm leaning towards TF 225's and the G6X3 with a possible vacuum pump. That would (should) get me where I want, at more cost obviously. Ading the G6 now would not be optimal but a natural process (add TFS when affordable) and it would also be nice to have as a dyno result with (now EPS/AI) a G6 and AI's. We'll see.
I appreciate your advice
Old Oct 28, 2012 | 01:51 PM
  #51
JayplaySS2's Avatar
JayplaySS2
Thank you sir, not too bad but it sure does drive night and day.
Old Oct 28, 2012 | 07:08 PM
  #52
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Thanks for the kind words!
Frankly, if your goal is 500 rwhp, I would try to get there with your cam. Your cam is pretty big. I'd go EWP, then merh, then TF225's, in that order.
Call LG - get their advice, they have always been good with tech advice for me.
If indeed that is really your goal. Keep in mind that you aren't going to feel a difference between 485 and 500...and the difference will only be 5500-6800 rpm so you are seldom going to experience it. So it's a lot of money for IMHO very little gain.
Old Oct 28, 2012 | 10:35 PM
  #53
Toxic c6's Avatar
Toxic c6
I have the same exact cam as you man. I put down 506rwhp you just need TFS225cc heads like me. That was in terrible weather too in cool weather with a ported fast I guarantee I will put down 520+rwhp.
Old Oct 29, 2012 | 11:24 AM
  #54
JayplaySS2's Avatar
JayplaySS2
Toxic, are they milled? If so, how much and what gaskets?
Thank you-
Old Oct 29, 2012 | 11:39 AM
  #55
Toxic c6's Avatar
Toxic c6
Thank you-
milled down to 62cc and stock gasket.
Old Oct 29, 2012 | 12:17 PM
  #56
C U IN REARVEIW's Avatar
C U IN REARVEIW
hey jason,have any idle video of this set up?
Old Oct 30, 2012 | 05:48 PM
  #57
Neumonic2002
Trick Flow heads are the ticket! You deff have more in that combo with a ported Fast!
Even a nice set of As Cast 220's from Brian Tooley would put Jason over 500 as I believe he has the supporting pieces already in place...
To LS2 Dyno guesses?
Old Oct 30, 2012 | 06:12 PM
  #58
JayplaySS2's Avatar
JayplaySS2
No sir
Thank you
Yea, yea. My budget is tight
Old Oct 31, 2012 | 09:53 AM
  #59
Toxic c6's Avatar
Toxic c6
I think so too. Ported FAST along with a vacuum pump I want around 530rwhp.
Old Oct 31, 2012 | 04:35 PM
  #60
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Show off
What are the specs of a G6X3?
