2006 LS2 M6
Halltech MF 107R
LS3 maf
Ported Fast 102
Ported TB
Intake Velocity ring
Vararam Spacer
Dynatech 1 7/8 C6Z lt's NO CATS
3" x 3" C6Z mid
GHL C6Z 3" axle back
EPS 234/242/603/605/112+4
Advanced Induction 226 243 heads
11/32 push rods
AC Delco ZR1 plugs
MSD wires
25% pulley
I think that's it...?
I did a prerun today installing the MF107R to test fitment since I have the Vararam spacer and the Hinson short mounts with the FAST 102....lots of variables there obviously...
Guys, it looks like the whole thing was designed around this set up
Look at the transition and angle. I don't think it could be any better, excellent job Halltech!
Now... my only problem.....driving 1.5-2hrs before I can actually install the Halltech since it's an LS3 maf. I was hoping to drive with it but it may be impossible since I can't get the LS2 maf to work on the Halltech (just for the drive for the tune...). Any ideas other than changing it all over in the parking lot at Vengeance racing??? I have to change the shroud and everything...but if so..oh well.
Any ideas?
2006 LS2 M6
Halltech MF 107R
LS3 maf
Ported Fast 102
Ported TB
Vararam Spacer
3" x 3" C6Z mid
11/32 push rods
AC Delco ZR1 plugs
MSD wires
25% pulley
I'll be the wet blanket here. Here is what I'm thinking.
You didn't mention compression so I'll assume stock 10.9. I'll also assume you are running on a Dynojet 248 SAE Smoothing 5, and that you have stock gears. Based on my setup and similar setups I've seen I'll say:
480/430
Which is nothing to be ashamed of. Your 112 cam will help low end TQ at the expense of some top end.
It's enough to be a 10 second car on a cold day.
To get over 500 on an LS2 you need every last mod, including Trickflow heads (or shaved heads, 12.5 compression and METH), light flywheel, electric water pump, A/R or LG expensive headers. A few dyno tricks such as super light wheels, etc. don't hurt.
It can be done without all of the above.
mid 230's cam
well ported 243 heads
mechanical water pump
1 3/4 headers
ported FAST 90/ stock ported TB
11:1 compression
stock wheels
NO dyno tricks (dynojet SAE) methanol
=501rwhp all day everyday for me
add an EWP
= 508-510rwhp all day everyday for me
My 402 with no holds bars 243 heads just made 607rwhp and that's never been done before from the best of my knowledge. It takes a solid combination of parts, decades of experience on the part of the engine builder and a great tune.
My car made 506/456 with AFR215s milled to 61cc 235/243 cam, ported fast 102, NW102, and LG super pros. I think the 243s will hold you back a bit but it will be close to 500.
No faith in the 243's yet again. You have a bigger cam, bigger FAST/TB yet I made more hp and tq then you when running the EWP at 364ci. Oppsss
mid 230's cam
1 3/4 headers
11:1 compression
stock wheels
add an EWP
501 with those mods (stock based heads) must be a record. Your car backs it up with performance for sure.
I'm standing by my comments above though on this one.
