ATF Cooler for '13 GS
Another thing to consider is that the tube and fin coolers are lighter and are less of an airflow restriction than the plate type cooler (although the t&f types are usually larger due to being less efficient) and so the plate type "super coolers" are better suited for being mounted with their own fan, in a remote location, instead of being hung in front of the A/C core and radiator.
So, to state the obvious, from what I'm hearing, if I install a supercharger, I need the DeWitts rad, a 160* thermostat, and a good stand alone cooler with its own fan for the ATF ( and most likely one for the engine oil as we'll). Basically, upgrade everything over stock, since these cars are already struggling to keep their fluids cool at stock power levels.
The system is closely engineered so the temps I see while normally driving isn't really a bother. There is a 100,000 mile warranty on the drivetrain so it doesn't follow GM under engineered the A-6 and its cooling system for normal every day use. But we aren't really talking about normal every day use now are we? So with the added loads, additional attention must be paid to keeping the transmission within normal operating parameters which is +/- 20 degrees of coolant temps (got that little factoid from GM engineering courtesy of GM Customer service that monitors this forum).
About as close to plug-n-play you'll find are the DRM coolers and the C-5 T-1 cooler kit for the diff and manual transmission. Since we are talking about A-6's, you might be able to install a cooler only back in one of the wheel wells, no pump needed.
Sitting in traffic with A/C on in Texas and you're lucky to pull 13 volts under 1300 rpm with it dipping into the low 12's high 11's at idle -- and that's BEFORE you add any other items to the system like ATF coolers with fans.
Countless threads on here and other forums about the crappy alternator output when hot ... the factory rating of 100 amps is cold rated and that is useless for anything outside of marketing reasons.
I almost hope mine would go, so I have an excuse to get one of those nice billet tech ones.
Long dead tread so no comments please.
http://forums.corvetteforum.com/auto...-course-t.html
I'm now back to where I started - I'm thinking of buying the larger B&M fan and supercooler module.
On why GM took short cuts - simple ... BEAN COUNTERS run the Engineering Departments.
I still laugh when I read post on here about " how well Engineered the C6 is..." Miss me with that crap.
The really unfortunate thing is that they seem to assume that the A6 cars will be driven as grocery-getters and that real performance drivers only drive manuals (there's a lot of that on here too). Yet, their European "competition" have developed instant shift, dual clutch/sequential gearboxes that have even the most hard-core of European drivers turning their backs on manual cars, simply because they can't compete with newer technology.
And GM wouldn't have had to reinvent the wheel to follow suit. Imagine for a second how well the ZR1 (or Z06) would perform if it had been offered with a tuned, dry-sump version of the 6L90. Maybe they'll see the light with the C7, but for now it looks like they will stick with the stick.
EDIT: after reading the article in Vette magazine today about the new 8 speed auto transmission that's going to be offered in the new Z06, it looks like I have to eat my words, because GM seems to finally have gotten it that the way to compete with the European double-clutch competitors of the Vette is to go auto, and they're building a serious A8 there. They have re-engineered the entire transmission, including the converter, and it appears to have a stand alone cooler on it from the factory. That Z06 sounds like it's going to be one awesome ride. I'm not a big fan of the lines on the C7 but that Z06 is really starting to look real good to me now. I'm betting that sucker is going to runs a high 10 out of the box with the 8L80 with just drag radials on it. Now we will get to see which one is faster, the paddle or the stick...
PS: The car has the sound of silence now, even over tracks.
I like the idea of placing the cooler in the front, ahead of the radiator. I too have been thinking about that area and installing both external EOC/TOC's there, side by side.
That might explain why I was only showing a trans temp of 210' stuck in heavy traffic for an hour, while the coolant was reading about 220' most of that time.
The really unfortunate thing is that they seem to assume that the A6 cars will be driven as grocery-getters and that real performance drivers only drive manuals (there's a lot of that on here too)....
A. Maybe they'll see the light with the C7, but for now it looks like they will stick with the stick.
Even in the C7 the Transmission temps are currently an issue - and GM actually "attempted" to address the trans temps in those cars with the vents on the top sides (which make the car hideous in my opinion) & by using a transmission cooler/fan.
If you look over the proposed Z07 with an Auto, they're going so far as mounting the Trans Cooler/Fan combo in pretty much the same spot as I have mine -
Click Here for thread with Pics
And they say us Industrial Engineering graduates are not really Engineers, LOL!
