Can anyone give me some general info on the process. I personally will not be doing the work but some shops want to change the whole unit and some want to just swap the gears. Any pros or cons on that. Which fluid do you guys recommend to go back with? Should i swap axles while i have it out with stronger ones?(been hitting the strip a lot lately). Thank in advance Will be going from 3:42 to 3:90
If they have the tools and shims, they most likely want to do it themselves, if they don't have the tools and shims, they most likely want to swap out the whole thing.
I only use Red Line. I like it so much, I went to work for them when I retired!
I went from 3:42 to 3:73, not sure what you do with your car, but 3:90 is a big jump!
I did whole diff with a Quaife, but you can buy a diff exchange with new bearings and such fro several forum vendors.
Can the swap be done at home with basic knowledge? Im not a complete idiot and pretty mechanically inclined but lack a full array of tools if anything special is needed? I have no lift but i can get the car up plenty high enough to work on it. If its pretty much a cut and dry swap i think i could do it
Lots of people have done on the garage floor. Victorf did a very nice write up on doing it in your garage.
It does take a special tool to setup the gears in our diffs. It is better to just do a swap, imo. I have had the wonderful pleasure of having to drop the rear drive train and the diff in my garage. I did buy some harbor freight cork screw type transmission jacks. The C6 is fairly easy to work on overall compared to a lot of other cars. The process of some repairs are just take a lot of time to do. I do not have a link handy. You can find one for clutch replacement. it will give you the basics for dropping the rear cradle. It is just a few bolts holding the diff to the trans. It will just pull apart from there. There is a big o-ring between them.
I also used that harbor freight scissor trans jack. It worked very well when I changed the clutch.
If the shop knows what they are doing a gear swap is fine and less money, Cartek swapped mine from 315 to 373, 8 years ago and know problems, I cracked the case an 05 4 years later, and they upgraded it to the 2nd generation case using the same gears from the cracked case with no problems
