Vitesse Throttle Controller - Wow!
Old Aug 28, 2015 | 10:57 AM
  #221
J Christensen's Avatar
J Christensen
Originally Posted by 05Z51C6
Received confirmation from the manufacturer that this product will not work for the 2005 year Corvette. Posting this in case some 2005 year owners are viewing this thread and interested in this product. Disappointing as this appears to be a very cool item.
I wonder if the module on the pedal is wire sufficient, could another year module work? Requires a re-wire whiz to figure out?
Old Aug 28, 2015 | 10:59 AM
  #222
Kouasupra's Avatar
Kouasupra
Does anybody not like theirs and want to sell it to me for cheap?
Old Aug 28, 2015 | 11:05 AM
  #223
J Christensen
Originally Posted by ptroxx
This is the main reason I got the unit... Ill know more next wed when I hit the drags ,,Ill be running some old kuhmos just to get use to the new power ... after that ill try it with either some r888's or supersports
it really does feel like 'more' power. That's why these pedal accelerators (using the transmission more aggressively) feel so great.
more power.
Old Aug 28, 2015 | 11:08 AM
  #224
J Christensen
Originally Posted by Kouasupra
After reading all the great reviews for this product I'm very tempted to buy one also.
Well, I just bought the last one.... ha.
Go past tempting to grinning... and if you have a sweetie, let them try it also, then it will be
Old Aug 28, 2015 | 11:10 AM
  #225
J Christensen
Originally Posted by cstapp99
My car has a plastic cover which makes access to the wiring harness near the throttle pedal difficult. Are you guys removing this panel for installation, or just reaching behind it? I can't even see the throttle pedal wiring harness because of this plastic panel.
The plastic piece has three push pins, two up front and one rear, by the side a/c vent. Takes about 1 minute to pull if off.
Old Aug 28, 2015 | 11:59 AM
  #226
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
more power.
No really, I just added a supercharger lol so its going to be a chore getting the power to the ground ..
Old Aug 28, 2015 | 12:01 PM
  #227
ptroxx's Avatar
ptroxx
Come out to the wed night drags on the 2nd and you can check it out in a few cars ,
Old Aug 28, 2015 | 07:46 PM
  #228
548chevelle's Avatar
548chevelle
Sounds great. I'll probably get one. But what I don't understand is why you can't modify the throttle position table itself and not have to buy a separate electronic unit. I know there's something that says not to do that because it will blow up the ecm. But why is that? Its just a table and not the operating system your modifying. You can modify all the other tables but not this one?
Old Aug 28, 2015 | 08:19 PM
  #229
J Christensen
Since it can be done via the ECM, and Chuck does it that way, I suspect it must be in some type of 'table'. The BIG difference is, that in a table you'd have to have the know how, equipment, and to change the setting would be 'how easy'?
This gadget is just too easy. Now that my joints are limber, I can remove or install in under five minutes.
Did I say this thing is ADJUSTABLE.... ??? Way too easy.
Old Aug 28, 2015 | 09:03 PM
  #230
schpenxel's Avatar
schpenxel
St. Jude Donor '15
There is a table that relates pedal position to throttle blade position. CoW says this isn't what he changes, though many people on the HP Tuners forum disagree.
Regardless.. you can't beat the adjustability of this unit. I really wish it worked on 05's!
Old Aug 28, 2015 | 09:37 PM
  #231
russ472's Avatar
russ472
has anyone actually looked at the throttle blade at wot before and after the unit is installed?
I ask, because I have read that at wot, the throttle blade is not open 100% with stock tuning. If this tuner will allow the throttle blades open more, then perhaps it can actually produce more horsepower as well.
all the positive post about this module is really giving me the bug to get one too.
Old Aug 28, 2015 | 09:55 PM
  #232
J Christensen
Russ, interesting question about perhaps having less than 100% open. Any idea what OEM has as it's max?
You need a bigger bug... this thing is a blast. Get one already. We'll hear your "YAHOO" from S. Carolina to Calif.
Old Aug 28, 2015 | 09:57 PM
  #233
schpenxel's Avatar
schpenxel
St. Jude Donor '15
"WOT" is about 88% on the throttle position sensor if memory serves
Doubt you'd get much more out of the tiny bit more open area (if any really) you'd get from opening the last little bit
I also don't think you can physically make the computer open the throttle blade any further. This is 100% WOT as far as the ECM is concerned. Just the TPS reports 88%
Anyone with a scanner or HPTuners can verify WOT TPS % with the unit installed
Old Aug 28, 2015 | 09:58 PM
  #234
xyoung347x's Avatar
xyoung347x
Banned Scam/Spammer
Got mine today and install/setup was a extremely easy. I thought I didn't do it right. Took it for a spin and really liking it. I knew I would like it from all the researched I've done. But only thing worries me is when I was researching, I saw the camaro forums was having CEL coming on and what not. It helped me feel a little better when the man himself commented on it and gave a 30 days money back and a 1 year warranty. That made me fully pull the trigger. So if he warrant it for the Camaro, I'm sure it goes for the Vettes.. Thanks for the awesome mod!
Old Aug 29, 2015 | 12:55 AM
  #235
J Christensen
I think he said an engine warning light might come on, but that it should go away after a few starts. I haven't seen this on my car.
Old Aug 29, 2015 | 01:12 AM
  #236
Kouasupra's Avatar
Kouasupra
I might order one soon. What's the link again? How long did it take to get it?
Old Aug 29, 2015 | 01:22 AM
  #237
Rajack's Avatar
Rajack
I just ordered mine today - they emailed me this link:
http://vitesse-motorsports.com/throt...orvette-c6.htm
To Vitesse Throttle Controller - Wow!
Old Aug 29, 2015 | 01:40 AM
  #238
Kouasupra's Avatar
Kouasupra
NoOoOoOoooo.. I just pulled the trigger.. I hate this forum. Lol
Old Aug 29, 2015 | 08:31 AM
  #239
rcnells's Avatar
rcnells
I paid for mine a week ago and contacted them yesterday about shipping and they responded saying it will go out next Tues with the rest of the batch. Sucks having to wait 2 weeks for this item with no warning. Oh well..
Old Aug 29, 2015 | 10:23 AM
  #240
PDsVettes's Avatar
PDsVettes
Ordered mine on Saturday, 8/22 with PayPal. It was at the Rutherford, NJ, post office on Wednesday. I just checked tracking and it's at my local central TX post office for delivery today.
