Vitesse Throttle Controller - Wow!
KZ
there is no way you can duplicate with your foot what these controllers do , its not about full throttle , its about mid throttle and how the throttle responds to the amount of pedal pressure
there are thousands of these things sold , not just for Corvettes but for Camaro' s CTS' and other cars.
Are there going to be a few that throw a code .... sure nothing in life is perfect ,
is it a problem with the car ?
is it a problem with setup
or is it a problem with the unit itself ?
Who knows .
We get few people who report that they are getting a code and right away everybody says they are Junk
Considering how may are sold , I can assure you that the huge majority install and run fine ....
Dave
If this controller worked for the 05 I would have already tried it.
Who knows .
Dave
Hey Dave.... Isn't it just crazy how much I got made fun of for Creating and Offering the CoW BOOSTER! in the beginning.....
And just look at what it's turned into......
Just crazy..... and hard to believe.
Chuck CoW
You are correct! If you never tried it, you would never understand.
Chuck CoW
Dave
Chuck CoW
the current GM throttle programming has what is called REVERSE Exponential programmed into it for one reason or another
What that means is 25 percent of gas pedal travel is only 15% of throttle opening, 50 is 40 75 is 60 and 100 is 100
the Vitesse smooths this curve out and in some cases turns it into a positive expo
25 % = 25% 50% = 50% and so on ....keep turning it up and 25 % becomes 35% , 50% is 65% , 75 is 90 ......
now everybody says they can just push harder and do the same thing are so wrong , no matter what you do u cannot overcome the lag just by pushing harder , with a throttle booster the engine response is instantaneous...
Dave
By the way, when I calibrated it, for low it showed L0.5 and high (pedal floored) was H2.0
I'm guessing that's the voltage range of the throttle sensor?
At mid throttle points , the trans will hold each gear longer with the smaller amount of pedal travel making the car that much more responsive ....
So instead of the quick shift we experience out of 1st and 2nd the trans holds the gears longer....
Again you cant do that by pressing the foot to the floor harder or faster at lower throttle inputs
Chucks "Cow Booster" accomplishes the same responsiveness but he achieves these results in a different way that he has perfected over the years
Also my wife's AMG from the factory has 5 different settings , Economy ( that's a laugh in an AMG right ? ) Comfort , Sport , Sport One and Custom , each one of these settings all have a different throttle sensitivity , trans shift points and suspension settings ....
When you switch from ECONO or Comfort to Sport or Sport One believe me you feel it , its the same motor , making the same power with the same trans but the car is a different more responsive performing animal !
Again , if you have not tried it ... don't knock it.....
Dave
And yes you are correct when you calibrated it the number you are seeing is the reference voltage that is coming out of the pedal sensor
Dave
Dave
you are right the mid throttle response is great, I also use mine at the track , if the grip is good I set it to sp7 , if not I set it down to zero or 1 ....
Dave
