Fast Idle Problem Continues
Old Sep 20, 2015 | 10:26 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by stoessjc
Does the throttle blade close completely? I noticed when I removed it yesterday that it has a slight gap.
No, at rest, it's about 20% open. When you turn the car on it goes shut. You can have someone turn the car on while watching it if you like.
Old Sep 25, 2015 | 01:34 AM
stoessjc's Avatar
stoessjc
Replaced throttle body. Engine idles correctly now.
Old Sep 25, 2015 | 06:15 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
It happens. Thanks for closing the thread in case someone google searches with your symptoms and they come across your thread.
Old Sep 25, 2015 | 09:33 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Good to know!
Old Sep 26, 2015 | 08:00 PM
stoessjc's Avatar
stoessjc
Guess I was a bit premature. The replacement throttle body I borrowed was a gold one. Mine has a silver one (2008). Therefore, gold will not work 100% of the time. At least the gold one confirmed that the throttle body was my problem. Now I just need to buy a silver one.
Old Nov 3, 2015 | 12:25 PM
stoessjc's Avatar
stoessjc
Replaced the throttle body with a new one and still have the hanging idle at 1100 rpm when the car begins moving. Idle only comes back to 600 when the car is completely stopped.
Old Nov 3, 2015 | 01:01 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Some of the adaptive idle stuff doesn't get enabled until you're stopped.
What tune is it running now? Factory original or something else. Lowering the min airflow table would fix it.
Old Nov 3, 2015 | 01:09 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
My first though exactly when this popped back up, I looked, he says the stock tune.
stoessjc, can you give us more details about when this started again? Had the car been fine for a long time after the new TB, then all of a sudden this happened? Any reason you had unhooked the battery before it started happening again? Looking for something that changed between when you said it was fine on 9/25/15 and today 11/3/15.
Old Nov 3, 2015 | 02:42 PM
stoessjc's Avatar
stoessjc
Stock tune. I have had a vararam intake on this car for about 100,000 miles without any issues. I got a TPS code back in May and took the throttle body off and cleaned it and the MAF sensor with MAF cleaner. Put the throttle body back on and immediately had the hanging idle problem. I was able to borrow a new throttle body and try it. When I installed it, the idle dropped down to 850 rpm without doing the idle relearn procedure. That was 9/25/15. I then found out that the gold throttle body will not work on my 2008, so I removed it and ordered a new silver throttle body. Put the new silver throttle body on, went through the idle relearn procedure, and then droved the car. Idle hang still there. Only time idle is normal is when the car stops moving.
I have not disconnected the battery since I removed the gold throttle body. I did not disconnect the battery when I installed the new silver throttle body.
This is very frustrating. Some have said a vacuum leak is the cause. Without any throttle pedal input, just easing the clutch out to start moving, as soon as the car moves the engine jumps up to 1100 rpm.
Old Nov 3, 2015 | 02:51 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I don't see it being a vacuum leak as that would set a p0174 code. I had a MASSIVE vacuum leak when the graft on the back of my FAST came loose and the car still idled perfectly. It did set the lean code pretty quickly though.
I'm looking at your MAF sensor. I'd suggest you remove, inspect and clean it again but be super gentle with it, the heated wires in them are very sensitive by design.
Do you have a buddy you could swap MAF sensors with to see if that changes anything?
Old Nov 3, 2015 | 03:02 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I would personally eliminate the MAF sensor as a possibility by unplugging it.. the problem is the IAT sensor is integrated into the MAF, so you'd have to only remove one of the wires that makes the MAF sensor itself work, while leaving the IAT sensor wiring alone.
If you're interested in trying this let me know and I'll find the wiring diagram for which wire you'd need to pull out of the MAF connector.
Old Nov 3, 2015 | 11:54 PM
stoessjc's Avatar
stoessjc
Cleaned the MAF sensor with MAF cleaner. Still has the hanging idle.
Old Nov 3, 2015 | 11:58 PM
  #33
stoessjc's Avatar
stoessjc
What about just unplugging the MAF? Since they are integral, if one or the other (MAF or IAT) is bad, you replace both with a new sensor.
Old Nov 4, 2015 | 05:48 AM
  #34
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Try it, but since it'll create trouble codes, check trouble codes first and post up any that show up.
Old Nov 4, 2015 | 08:37 AM
  #35
schpenxel's Avatar
schpenxel
St. Jude Donor '15
If you just unplug the MAF the IAT will be unplugged too and will read like -40*F, which will screw fueling all up. Without the MAF the car will revert to speed density mode, which needs an accurate intake air temp in order to be able to calculate air flow
I'll be surprised if it runs like that honestly
Old Nov 4, 2015 | 09:55 AM
  #36
stoessjc's Avatar
stoessjc
OK. Is it easy to remove the maf control wire from the connector? How do you do this and can you tell me which wire it is?
Thanks.
Old Nov 4, 2015 | 10:41 AM
  #37
schpenxel's Avatar
schpenxel
St. Jude Donor '15
What year is your car again?
It's not too bad to do but you need a very small screw driver or something similar.. a very skinny blade would almost work better
To Fast Idle Problem Continues
Old Nov 4, 2015 | 10:52 AM
  #38
stoessjc's Avatar
stoessjc
what year is your car again?
It's not too bad to do but you need a very small screw driver or something similar.. A very skinny blade would almost work better
2008
Old Nov 4, 2015 | 11:11 AM
  #39
schpenxel's Avatar
schpenxel
St. Jude Donor '15
You have to pop the purple thing off the bottom of the connector and insert a very skinny tool into the smaller opening near the pin(s) you want to remove. The purple thing comes off by prying it gently from both ends.. it will pop off without too much trouble
There's also a cover on the opposite end of the connector that you may or may not have to pop off (I've seen it missing on a lot of cars for whatever reason). It's already removed in this picture
The wires in the picture are from a 2005, so the colors may be different on yours, but the locations should be the same. The two on the left are the same color and are for the IAT sensor. The other three are for the MAF sensor. Pulling any of the three should do the trick (power/ground/signal)
Old Nov 4, 2015 | 11:41 AM
  #40
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Read your codes before you do any of this as this will cause a code to come up and we need to see what codes exist now while it's screwing up.
