connections
Old Nov 22, 2015 | 09:59 AM
ERIC_MEMS1@YAHOO.COM's Avatar
Default connections
Hello Guys, I know that the ECM has two connectors and there is a blue and a black connector but on my C6 there is on more connector its black and has a beige looking arm that locks,with a white square on it . I don't know if its a stage 1 coupler or what but it comes from the factory harness , can someone help me, Thanks
Old Nov 22, 2015 | 10:08 AM
Dano523's Avatar
Dano523
C-6 ECM has three connectors, and if you have a auto, should be a forth connector that goes to the TCM that mounts behind the ecm on the other side of the plastic piece (top blue connector in the below photo's).
https://www.corvetteforum.com/forums...on-the-m6.html
If you have a interceptor connector that mounts in between the factory connector and the ECM, then that could be one for an after market device instead.
When all else fails, post a photo, and trace the interceptor connector back to it's module to determine what it is.
Old Nov 22, 2015 | 12:05 PM
Default connectors
Ok , thanks I will send a photo soon My C6 is a manual trans but the ECM only have 2 connectors
Old Nov 22, 2015 | 04:47 PM
Dano523's Avatar
Dano523
Year and model would help, since you may have a E38 ecm in the car instead.
Old Nov 22, 2015 | 04:58 PM
just from looking at your photos its a E38 , my car is an 06 base model vert with a LS2
Old Nov 24, 2015 | 05:40 PM
Default connections
should there be any other connections coming from the harness ??
To connections
