No LT headers are CARB certified, so I'm running ZR1 exhaust manifolds. I think we can add the bung, and not make it stand out. There's a vid of a Lambo getting "smogged" in CA with both banks monitored. I'll check with my Tuner, Matt. He'll likely know..
Thanks!
Originally Posted by schpenxel
Just one is fine. Most put it on the driver side as that bank tends to run a little leaner
Are you using factory headers/cats or something else? LS2/3 or LS7?
Not sure about CA smog issues... wouldn't think it would matter but I've been surprised a few times by the rules out there
Originally Posted by DashLogic
I would assume since you actually didn't change anything and only installed a sensor it wouldn't effect CARB, but you should check the laws to be sure.
Thanks!
I have Z06 manifolds on mine. To add a bung I had to cut some of the heat shielding off and I added it on the bottom, kind of to the side. You could probably add it in such a way that it would be very not noticeable, especially if you didn't hack up the heat shielding and did a good job welding in the bung.
Not being a tuner - how critical is the AFR to monitor? Getting some concern from Tuner/mechanic..
I wasn't planning to log anything - just monitor/read. I understand logging requires even more tuning equipment? With a mild set up and boost, is it really that beneficial? Last question - promise!
Thanks!!!!
If I was only going to log one thing, that would be it
You can watch what's going on with Dash logic, no need for anything else (other than a WB). If you want to be able to change things then yeah, you'd need HP Tuners or EFI Live.
For a mild setup plenty of people don't monitor anything. Whether that is a good idea or not is debatable. I wouldn't be comfortable with that but some would prefer it.
