DIY NPP Vacuum Pump Controller System - Avoiding Engine Intake
Old Jul 13, 2016 | 09:58 PM
Jay462's Avatar
Jay462
Alrighty- last part is now in- the filter for the vacuum relief port:
Old Nov 13, 2017 | 08:57 PM
jonathans2k's Avatar
jonathans2k
Jay462, just want to give you a big thanks. Such a wonderful and helpful how-to!
Old May 27, 2018 | 09:08 PM
johny125's Avatar
johny125
Jay, It's been almost 2 years since you installed your DIY vacuum pump for you bi mode exhaust. How is the pump doing these days? Any issues other than the first edition GM solenoid? I am planning to build one with your design in parts for my C6.
Any others build Jay's design and can give a review? Thanks,
John
Old May 27, 2018 | 09:25 PM
long_tall_texan's Avatar
long_tall_texan
Curios to hear back too. I have purchased all of the parts, and have the mufflers ready to install. Just have not had the time to do so yet. Any new or updated info would be appreciated before I dig in.
Old May 27, 2018 | 09:28 PM
XX's Avatar
XX
XX
St. Jude Donor '12
curious also and may give it a try.
Old May 29, 2018 | 05:14 AM
94Green's Avatar
94Green
C6 of Year Finalist (stock) 2019
Great write up. Thank you.
Old Jun 10, 2018 | 09:38 PM
johny125's Avatar
johny125
I went ahead and installed the DIY vacuum pump and associated parts on my 05 C6 vert after adding a dual mode Z06 cat back. I used all of the parts Jay had listed including the MAC 3 port valve. The install went great for the exception of the 7/64" diameter vacuum hose that Jay used. The MAC valve came with 1/4" brass fittings which made it impossible to get the 7/64" hose onto. So what I did was buy 6" of 1/4" hose (3" inches for each port and then placed a plastic reducer (1/4 to 7/64) which I purchased in a pack of vacuum reducers from Auto Zone for $2.99. Worked like a charm. Jay had said the pump was noisy, but I found the contrary. I mounted the pump and valve on the inside panel of the rear trunk area placing them behind the carpet. I cannot hear the pump run at all from the driver's seat. I also placed a 1/2" foam rubber around the pump to help insulate the noise. I purchased all of the parts on Ebay for approximately $100.00. I used an Eaton parts pump instead of the Dorman since the pumps appear identical and the Eaton was only $43 shipped. Hope this helps, shoot me a PM if you have any questions.
Old Jun 12, 2018 | 02:23 PM
farmington's Avatar
farmington
this surely seems to be the way to go. thanks for the great write up
Old Jun 14, 2018 | 10:36 AM
XX's Avatar
XX
XX
St. Jude Donor '12
Thanks to the op, I have the parts ordered and will try to install it similar to a Mild2Wild setup but opposite on the remote so lets call it Wild2Mild. The way I have planed with a wireless remote it will be off = Wild & on = Mild. Update to come
Old Jul 17, 2018 | 01:21 PM
davidlnf's Avatar
davidlnf
6th Gear
Great write-up, thank you @Jay462! I'm ordering the parts now for my 2013 GS. This looks like a fun project while I plan my exhaust upgrade. Currently thinking the BB Fusions. I'll provide an update once I get the parts and start assembly.
Old Jul 17, 2018 | 02:28 PM
HOXXOH's Avatar
HOXXOH
Strangely enough, a vacuum pump is the original method used to create the NPP in a box. Apparently not with the better pump though.
Old Sep 19, 2018 | 12:52 AM
Riveroger's Avatar
Riveroger
Is your 05 a manual? I have an A4 and wanted to used Z06 dual mode mufflers if they fit around the trans.
Old Nov 6, 2018 | 11:58 AM
  #33
mikejsmith1985's Avatar
mikejsmith1985
I know this is an older thread now, but there have been a few “recent” hits on it and I’m excited about my setup and want to share. I’m preparing to install z06 bi mode mufflers and wanted something kind of stealthy yet OEMish like install so I opted to hide my setup behind the flip down door in the console. I lost the cigarette lighter for the button and covered up the ashtray which looked out of place to me (as I’m a non smoker) I designed and 3D printed a stand-off to push the button out so it’s more easily reached and designed and printed a cover for the hole where the ashtray sits. This can be removed the same way as the ashtray which actually increases the storage space in this little cubby. Let me know what you think please. I know this is subjective and may not be for everyone. So criticism is fine as well :-)
I've tried adding attachments a few times and it doesn't seem to want to do it right now... So I added the pic in the below post.
Old Nov 6, 2018 | 12:07 PM
  #34
mikejsmith1985
Old Nov 6, 2018 | 12:37 PM
  #35
long_tall_texan
That looks awesome. Any chance you'd share your CAD file so I could use it as a basis to customize mine similar, but for a front curb alert display panel and print one myself.
Old Nov 6, 2018 | 12:49 PM
  #36
mikejsmith1985
And lose the potential hundreds of cents I could make on it :-P Yeah man I'd be happy to share. I designed it in Fusion 360 I'll PM you for your info.
Old Nov 8, 2018 | 02:34 PM
  #37
davidlnf's Avatar
davidlnf
6th Gear
Very cool!
To DIY NPP Vacuum Pump Controller System - Avoiding Engine Intake
Old Nov 18, 2018 | 09:25 AM
  #38
mikejsmith1985
So it’s currently mid 30s in Ohio where I live. The pump runs longer than anticipated at startup, long enough in fact that the pump is still running after the engine is running. Which essentially means I can’t start the car in quiet mode. I don’t live in a neighborhood so I’m not to concerned about neighbors being disturbed or anything but I just prefer to have quiet mode default and would like to improve performance.
Does anyone one know if the valves can be adjusted so that vacuum opens them instead of closing them?
Old Nov 18, 2018 | 11:29 AM
  #39
Riveroger's Avatar
Riveroger
I am about to do this project. Are you using GM mufflers? I have the mufflers installed now and default is open. I would think If you turn on acc mode a few seconds to run the pump before you start the car you would be in quite mode.
Old Nov 18, 2018 | 03:04 PM
  #40
Vetterator's Avatar
Vetterator
Default Npp
You are correct, but the vacuum pump runs intermittently to keep the baffles closed.
