Lowering bolts replacement
Old Nov 21, 2016 | 05:02 PM
StallionCorvette's Avatar
StallionCorvette
Default Lowering bolts replacement
I was ready to actually raise my car about 1 inch on the front so i could clear 285/35/19's when i noticed my lowering bolt bushing was completely destroyed. Does anybody have any idea how hard is it to change the bolts? I just order some VMS Racing bolts, they seem pretty legit, any input will be great
Old Nov 21, 2016 | 05:56 PM
Curt D's Avatar
Curt D
Easy to change, just a little work. Take off 4 bolts holding upper control arm on to chassis (remember shim locations), lower shock bolts, one end of the sway link, and caliper. jack up on the spring with another jack and then push down on the lower control arm. This will give you enough room to get the bolt out. keep an eye out for any wires or hoses getting caught. If you have mag ride you will need to unhook one end of the sensor thing.
Old Nov 21, 2016 | 06:42 PM
timd38's Avatar
timd38
I would buy OE type adjusters. My luck with others before I got coilovers was not very good.
Old Nov 21, 2016 | 09:35 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Last I heard, GM does not sell the bolts as separate items- you'd have to buy complete spring assemblies.
Sometimes you can get lucky and buy the bolts from someone who replaced his springs.
Old Nov 21, 2016 | 09:37 PM
Curt D's Avatar
Curt D
https://www.corvettecentral.com/c6-0...f%3fcount%3d18
Old Nov 21, 2016 | 09:46 PM
Gearhead Jim
St. Jude Donor '13
Thanks for the link.
Reproductions, but if done right they could be what some people desperately need.
Old Nov 21, 2016 | 11:32 PM
torquetube's Avatar
torquetube
I installed the Corvette Central OEM reproduction bolts to replace my OEM ones whose bushings were half gone by 130K miles.
Installation is easy but time-consuming - provided that your bolts aren't seized. Mine were easy to turn, but a few people have reported frozen bolts. In that case, try applying penetrating oil and letting it work overnight.
To change out the bolts, you need to jack up the car to remove the wheel, put the car on stands, and then jack up the spring itself (use a block of wood to avoid damaging the spring). This will unload the adjuster bolt so you can remove the old one and install the new one.
Be smart, don't put your fingers someplace where they could get squished if the jack releases.
Working one corner at a time, the anti-roll bar will be fighting you. So I recommend disconnecting one end link first (doesn't matter which side).
Leave the links undone until you get the ride height adjusted. This may take several cycles of turning the bolts, driving around to settle the suspension, measuring the height at the fenders, rinse, repeat.
Old Nov 22, 2016 | 12:04 AM
Curt D's Avatar
Curt D
Sorry, but no way that bolt comes out by just jacking the spring, even with the link unbolted. I have done a few cars.
OP...give it a try and let us know.
Old Nov 22, 2016 | 12:54 AM
torquetube's Avatar
torquetube
Sorry, my comments were intended as a series of observations, not complete instructions. Yes it is necessary to disconnect more of the suspension to get the lower control arms low enough. The lower shock mount and either the upper ball joint or the upper control arm mounts (I wouldn't).
However, just how much will depend on how gone his bolts are. The more trashed they are, the less clearance is required to remove them. The aftermarket ones he bought have hardly any bushing at all, so they won't require as much clearance to install.
Old Nov 22, 2016 | 08:30 AM
StallionCorvette
Aagghhh! Just received a quote from a local mechanic shop to do the removal of old bolts and the installation of all 4 new bolts, raise and/or lower the car where needed to get the look i want, install new rotors, bleed the brake lines, install z06 calipers and 4 wheel aligment for $1000 !
Too much right? Or a fair price?
Old Nov 22, 2016 | 10:37 AM
timd38's Avatar
timd38
Will your wheels work with the calipers? Pricing sounds fair to me.
Old Nov 22, 2016 | 11:55 AM
Unreal's Avatar
Unreal
Did my VMS bolts in an afternoon. No way in hell would I pay $1000. It was ~2 hours start to finish. Then $120 for an alignment afterwards.
If possible I would do the OEM repros. The VMS bolts drop the car atleast an inch or more. I have them cranked up all the way and they are still pretty damn low.
Old Nov 22, 2016 | 12:10 PM
Gearhead Jim
St. Jude Donor '13
For those who replace bolts or jack the spring to adjust the bolts; the car usually will not settle to it's final height until driven a couple of hundred miles.
At first, it will look like a jacked-up monster truck. Drive it and be patient.
Ours was not fully settled after 50 miles, looked closer by 100, and had stopped settling at 200.
At that point, you can measure and start the process all over again if needed.
Here's some factory specs whether you use the GM tool underneath (I have one but don't use it any more) or measure at the fender lips (more convenient and probably just as accurate).
timd38's Avatar
timd38
Report back in 6 months and let us know how they wear. Not sarcasm, really want to know.
Keep in mind the $1,000 includes a brake upgrade. So, at $125 an hour, it would cost you $370, to replace the bolts, still a tad high, but not real bad. That leaves $600 for the brakes and the rear brake lines can be a challenge.
Old Nov 22, 2016 | 12:27 PM
Curt D's Avatar
Curt D
Same here. I'd like to go a little lower (stockers are cut) but usually never hear good things about aftermarket bolts with plastic or Delrin.
Old Nov 22, 2016 | 01:01 PM
StallionCorvette
Yeah they will they are wider wheels 19x11 fronts and 20x12 rear with the right off set to fit my base c6.
Old Nov 24, 2016 | 10:51 AM
StallionCorvette
Default Found them! You are welcome!!
Well if you are on the same boat as me you been looking around for the glorious "stock bolts" yet you come to find out that the only ones that are available are the "lowering bolts" which they don't last or reset the factory height of the car. After many searches i came across this:
http://www.parts123.com/corvettecent...50V&ukey=51206
and Happy Thanksgiving!!!!
To Lowering bolts replacement
Old Nov 24, 2016 | 04:53 PM
Blk 08 C6's Avatar
Blk 08 C6
I agree with Unreal.no way in hell I would pay $1000 for that job.buy the parts and do it yourself even on jackstands.some of us are lucky I have a 2 post lift.
Old Nov 25, 2016 | 10:17 AM
Unreal's Avatar
Unreal
I have a lift and still did them with a floor jack one corner at a time. Quicker and easier than using lift.
Old Nov 25, 2016 | 07:15 PM
timd38's Avatar
timd38
People don't understand that sometimes a floor jack is easier to do a job with than a lift.
