Observations after Header Install
Old Feb 21, 2017 | 07:46 PM
A Marsh's Avatar
A Marsh
Default Observations after Header Install
This weekend I had Kooks 1 7/8 long-tube headers, catted x-pipe, and Elite Engineering insulated tunnel plate installed on my 2012 Grand Sport with auto. These are my initial observations after about 150 miles of driving.
1. More power - I have a canned SCT tune installed. I selected the long-tube headers setting. Although not a dead on tune, the car runs good and throws no codes. I'll get a dyno tune later, but don't feel an urgent need. The car runs a lot more like a Corvette should!
2. Less console heat - I had the headers and x-pipe ceramic coated. Combined with the insulated tunnel plate, there's a noticeable decrease in how hot the console gets. Admittedly, I haven't driven in really hot weather yet.
3. The car feels lighter - I'm not just talking about at speed. Even at low speed when I'm not using the extra power, the car feels lighter. I think it's because of the modest decrease in weight from the exhaust (maybe 20 pounds) and the modest stiffening caused by the thicker tunnel plate.
4. The car isn't very much louder most of the time - My car has NPP. At idle and at highway/freeway speeds it's not much louder at all, if any. It barks when the dual-mode is opened up, though. It also has a deeper idle note, a lot like a C6 Z06. In my opinion, this is just about an ideal exhaust setup.
5. The installation was very straightforward - The fit and finish of everything was top-shelf. There was no drama to the installation at all.
Needless to say, I'm pleased with the results.
Old Feb 21, 2017 | 08:25 PM
jpick73's Avatar
jpick73
Glad you are happy with your new setup! Is the exhaust setup the only mods done, or did you already have something else done? I ask because I am thinking of getting headers, catted x-pipe, and already have the NPP exhaust also, on my 2013 auto. Thanks!
Old Feb 21, 2017 | 09:07 PM
CMY SIX's Avatar
CMY SIX
NO! you need to get a tune now! more air in, more air out = tune. you are going to hurt it.
Old Feb 22, 2017 | 07:23 AM
A Marsh's Avatar
A Marsh
It has a tune. It's the imbedded tune from SCT. They must have put some development into it - it throws no codes, doesn't ping, etc. Economy seems to be just about the same, maybe a tad better. All engine-related temps are good.
I'll be getting a dyno tune soon to improve the transmission function as much as anything else.
My only other mod is a Z06 CAI with K&N filter.
Old Feb 22, 2017 | 07:29 AM
Travlee's Avatar
Travlee
agree, curious to what his AFR is. you are prob running lean
Old Feb 22, 2017 | 09:06 AM
BlindSpot's Avatar
BlindSpot
He has 150 miles on the headers, fuel trims are already pretty settled in. If he hasn't thrown P0171/P0174 then he is NOT running lean in closed loop. And he is not going to hurt it. AFR is running around Stoich in CL. PE might be tweaked, but he is not going to hurt it.
Old Feb 22, 2017 | 09:58 PM
Not So Fast's Avatar
Not So Fast
Man I cant wait, my Kooks have been sitting here waiting, and waiting, for around a month I went 1 3/4" cause its staying stock.
Up in the air whether to dyno or Diablew
Glad to her the install went smoooothly
Good luck
NSF
Old Feb 23, 2017 | 06:44 AM
Travlee's Avatar
Travlee
not a risk i would be willing to take, but to each their own
Old Feb 23, 2017 | 08:47 AM
BlindSpot's Avatar
BlindSpot
If you don't understand how engine management works in an E38 ECM then you cannot possibly analyze the risk with any degree of accuracy.
Headers, by themselves don't increase airflow. How can they if nothing is changed coming in through the air intake and past the MAF. They might reduce back pressure which could impact cylinder air mass and load and that might create a tune performance opportunity in timing and PE fueling. OP does have a CAI too, so lets say airflow has increased. The MAF is calibrated and will measure a higher frequency of air flow commensurate with the new volume coming in which the ECM relies on to fuel. Nothing has changed with fuel injectors or injector calibration. With headers, the bigger challenge is the fact that the front O2 sensors end up farther downstream from the actual combustion event making fuel trims more challenging to interpret.
Old Feb 23, 2017 | 08:51 PM
Dcasole's Avatar
Dcasole
I drove mine for 100 miles to let the fuel trims settle , then did a steady state log at 2400 RPMS ... made the adjustments and then did a WIDE Open Throttle log .....
all is good, the ECM fuel trims will adjust upwards of 25%
Dave
Old Feb 24, 2017 | 03:43 AM
Ahrmike's Avatar
Ahrmike
Sweet. This is one of the few things I want to do to my 2010 NPP GS... Sounds like you're loving it.
I suspect it feels "lighter" because its making more power everywhere.
Old Feb 25, 2017 | 11:23 AM
mikeCsix's Avatar
mikeCsix
Personally, I would rethink the K&N air filtter. The stock ZR-1 air filter flows more than enough air for your motor with the added benefit of better filtration.
Glad to hear the install went so well, I'm planning the same upgrades, including the tunnel plate.
Old Feb 25, 2017 | 11:28 AM
MarylandSpeed's Avatar
0MarylandSpeed
Former Vendor
Looking good Alan!
Old Feb 25, 2017 | 11:34 AM
BlindSpot's Avatar
BlindSpot
on the K&N
Old Mar 4, 2017 | 07:34 AM
BigBlue's Avatar
BigBlue
It's got a tune.
To Observations after Header Install
