Car dies while driving
GS runs dry sump system, so battery is in the back with a lead off that to the starter, then off the starter to the engine fuse box.
If I was a betting man, would bet on either the positive wires from the battery to the starter is shorting out against the chassis ground points, or the positive wire off the start to the engine fuse box is ground out to the back of the passenger side head (it runs up from the starter behind the head, then swings around to the engine fuse box terminal.) Hence although that wire is in a wire loom, if the groom was not snapped in correctly, the wire in its loom can rub against the back of the head to wear through not only the loom, but the shielding on the positive cable as well.
Bottom lug where the two wires connect together,
Or, could be that someone tweaked the settings on the radiator fan to have it come on at a lower temp setting, did a tweak to the connect that burnt up the first time, and now you have a melt through at the PWM that is causing a short there instead.
Hence the connector burnt up the first time, they soldered the wires to take the connector out of play (safety link), and now the wires burnt up at the PWM to cause the short there instead.
https://www.corvetteforum.com/forums...ing-again.html
Also to point out, the OEM raditor was never meant to be run 100% all the time, so if its run this much, it will start to wear the fan motor out, which cause higher voltage demands through the PWM from the fan itself as the bearings start to bind up, and will fry the PWM as well.
see link;
https://www.corvetteforum.com/forums...ter-where.html
see link;
I'm with the others on it being a short somewhere, and that starter lug is the usual culprit. If you smelled wires burning and it drains the battery, it's definitely a massive short and you're lucky it didn't catch something on fire.
BTW: I relocated my battery to the rear cubby (auto GS) and installed a Bussman 150amp marine circuit breaker, just in case something shorts out. It's also a great tool for me to shut the battery off when I go away on vacation etc. Every car should have one of those, IMV.
WTF is going on with that? Anything can happen I guess...... weird....... keep us posted.......
