Steering pump replacement?
Old Nov 27, 2018 | 08:52 PM
Stevengineer's Avatar
Stevengineer
Default Steering pump replacement?
Hey guys, I have a LS2 Corvette and it is making a whining noise. It is a high pitched whine and seems to be louder when I turn the wheel. The steering rack has been replaced (was leaking anyway) and the noise did not go away.so I assume it is the pump (correct me if you think it could be something else).
First, are you guys pretty sure it is the pump as well?
Second, do you guys recommend getting the OEM pump? The dealership is saying over $850 for the OEM pump but can get one from ACDelco for around $450. Online I can get one for $190 on corvette central, $170 on corvette mods, or $100 (ACDelco) on rockauto, or a $50 Cardone on of summit racing (that price seems sketchy). I'm not sure if their are ones to stay away from or aftermarket ones that are cheaper and every bit as good. I would appreciate the help on this one.
Old Nov 28, 2018 | 11:38 AM
jayyyw's Avatar
jayyyw
See if your pulley is backing off the snout on the pump. One guy had that issue. If it is, maybe have someone reseat it for you. But, it's possible it will happen again down the road.
Old Nov 28, 2018 | 12:06 PM
Stevengineer
I would have expected that to cause more of a belt squeaking sound, but maybe not. Is there a good way of checking it?
Old Nov 28, 2018 | 12:24 PM
jayyyw's Avatar
jayyyw
Just look at it. The pulley should be flush with the snout.
Old Nov 28, 2018 | 01:21 PM
MTPZ06's Avatar
MTPZ06
OP, for reference: https://www.corvetteforum.com/forums...em-solved.html
Old Dec 4, 2018 | 06:54 AM
Stevengineer
It it does not look like to me that the pulley is misaligned.
Old Dec 4, 2018 | 08:30 AM
Sox-Fan's Avatar
Sox-Fan
Do not buy anything from Corvette Mods. Stay far away. Read the reviews in the feedback forum before you buy.
Another option to consider is the turn One pumps. It's pricey, but it's nicer than the AC Delco and a lot less expensive than the dealership.
https://www.turnone-steering.com/col...-corvette-pump
Old Dec 4, 2018 | 05:47 PM
Stevengineer
Thanks for the input, I'll keep that in mind! And I figured I would never get mechanical bits from Corvette mods, only stuff that doesn't matter. they have too much bad hype.
Does anyone know about the ACDelco pump on rockauto? If it works well, it'd be nearly impossible to beat at $100. It is refurbished, but I'd figure it's new blades, bearing, and paint.
Old Dec 4, 2018 | 08:28 PM
Shortpersonbk's Avatar
Shortpersonbk
Send it you dont have alot to lose the pumps are more annoying then difficult replace.
Old Dec 4, 2018 | 10:32 PM
timd38's Avatar
timd38
I have a Turn One pump and it provides more feel in wheel.
Old Dec 5, 2018 | 08:59 PM
Stevengineer
Thanks for the input guys, but are their any steering pumps as good or better than the original that aren't as expensive?
I just rechecked the price on Corvette Central and they have it for $190. Not sure what I saw before but I remember it being $450 or so before.
Old Dec 5, 2018 | 09:45 PM
BMF_C6's Avatar
BMF_C6
I just replaced mine with a Cardone Power Steering Pump from Advanced Auto Parts - lifetime replacement. So far no issues, works perfectly without any issues.
It's rebuilt but I did some research just like you are doing and found others that have had good success with Cardone, no reason to speed hundreds if you don't need to IMO.
Good Luck
Old Dec 5, 2018 | 10:52 PM
Stevengineer
Good Luck
Do do you know what model you got? There is one they make on summit racing for $50 and ones on RockAuto (the a1 model) for $150.
My problemn robis I'm not sure if there is any real difference between them or even the $100 ACDelco one on RockAuto. I would think anything made by AC Delco should meet to the OEM specs but the price difference is outrageous.
Old Dec 6, 2018 | 08:58 AM
BMF_C6's Avatar
BMF_C6
It was this one, Advanced has a lot of discounts like 20% off and I used that and got it cheaper. Ordered it online and a day or so it was at my local store ready to be picked up.
Like you said, almost all of the ones are sold are reconditioned with new bearings, seals and blades. I think most are the same unless you want to spend $400+ for a brand new one from the stealer which is crazy............ I think most have the Vette tax tagged on.... the easy part is buying it, getting the old one off and replaced is a complete BIATCH!!!
Cardone Power Steering Pump w/o Reservoir - Domestic
Part No 20-822
Warranty: LIMITED LIFETIME REPLACEMENT
Ordered From Here Online and Picked it up Locally
Old Dec 6, 2018 | 05:48 PM
Stevengineer
Does anyone know how the turn one pump actually compairs to the stock pump? They claim 3hp and lower temps, but is their any testing to go along with it? And how would a pump inprove the steering feel?
I'm thinking end of year bonus check
Old Dec 6, 2018 | 09:06 PM
timd38's Avatar
timd38
The Turn 1 pump gives you more road feel. It flows less than the stock pump, so it takes more effort to turn the wheel, but it is worth it. I also bought the fittings so that I could replace the high pressure line with steel braided Teflon hose.
The reason the fluid runs cooler is because it produces less pressure. I would buy again. Also, if you have the short pressure line, either make a new one like I did, or buy the replacement one that is about twice as long.
Old Dec 6, 2018 | 11:25 PM
Stevengineer
That makes sense. So why is it beneficial to have less pressure? Anything apart from the feel?
Why would I need one so long, is the pressure line just that short?
To Steering pump replacement?
Old Dec 6, 2018 | 11:57 PM
megan.andrews's Avatar
megan.andrews
I have a 2017 Chev. Corvette with RED LEATHER SEATS.
Recently i just replaced mine with a Cardone Power Steering Pump from Advanced Auto Parts.
Deserver lifetime support!
Old Dec 7, 2018 | 08:39 AM
Sox-Fan's Avatar
Sox-Fan
You had to replace the power steering pump on a 2017? Out of your pocket? Color me as.... skeptical.
Old Dec 7, 2018 | 12:30 PM
timd38's Avatar
timd38
Not sure I know the answer to your pressure question, but I my bet is that it produces far more pressure at higher RPM than is needed, so if you do track day, you are driving the car at higher RPM, creating more pressure and that pressure translates to heat. Just my opinion based on logic.
The early short one was routed in a way that caused it to fail. Don't know the reason. If you buy a replacement they are all the long ones, at least they were when I went to buy one, that was the driver behind me making one.
