Harmonic Balancer
Old Nov 3, 2019 | 10:25 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Originally Posted by tcole826
Hey guys. Wanted to update. Got the old Pulley off. Now to start putting back to together. Quick question - the new crank shaft seal - do i need to prep it with anything? oil on the outside? or just push up there and seat? Seems like some guys use a small bit of Black RTV on the outside.
They make an installation tool that will snsure proper installation and no damage - not expensive and worth the $$ or you can rent one -
No need to use RTV around the seal for installastion
Thanks,Matt
Old Nov 4, 2019 | 08:56 AM
irok's Avatar
irok
You can use clean engine oil on the outside circumference only of the seal as stated in your factory service manual or take a chance doing it other ways.Its a big job if you have to replace that $10. seal again.Good luck with it
Old Nov 9, 2019 | 04:49 PM
tcole826's Avatar
tcole826
Hello, Just a quick update.... It's a big job. Haha. The Rack\Water pump\pulley all back on the car. I'll be honest, fighting with the lines back into the pump. They are in, just getting them down and tight - there's ZIPPO for room down there. Breaked for today before i "blew a gasket". I think i might go get some crows feet, that might help.
