Soler Prf. Throttle Controllers for C6 available now
Old Aug 20, 2021 | 11:36 AM
  #61
Mike@SolerEngr's Avatar
Mike@SolerEngr
Supporting Vendor
The pedals sensor's output is very different in the 05's and so is what the 05's ECM expects to receive from the pedal/controller, in both magnitude and direction. It is a matter of "is" or "isn't", there's no "close" or "maybe". We've been there done that. We have not stopped, we simply have this as a backburner project. Glad you brought this up again, we'll take another hack at it.
__________________
Soler Performance LLC
support@solerengineering.com
www.solerengineering.com
(251) 468-9786
Old Aug 20, 2021 | 11:48 AM
  #62
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Originally Posted by grpweld
Sure wish Mike would build 1 for the 05's. Pedal commander swore up and down that it would work for the 05's Mine came yesterday & before installing I googled it again specifically for the 05 and saw some very negative comments. So I called P.C. again & pushed the issue with the ecu differences between the 05 and the 06-13 & they admitted that it is hit or miss as to weather it will work at all with a 05. I don't know if I want to go to all the trouble of pulling the drivers seat ,Knee booster to try this as I just don't see how it could possibly work
I didn't have to pull the knee bolster nor the drivers seat to access the drivers pedal - if you have issues getting to the actual harness clip, I would suggest pulling the pedal itself by unbolting it and working on it like that instead -
Since you have the P/C you might as well give it a try and see what happens, if it doesn't work then maybe you can send it back and S/P will have their completed by then -
Thanks,Matt
Old Aug 20, 2021 | 02:37 PM
  #63
grpweld's Avatar
grpweld
Mike if all my throttle opening rates (HPTuners) are set at 100% is it even possible to quicken the opening rate past that?
Old Aug 20, 2021 | 05:47 PM
  #64
grpweld's Avatar
grpweld
Thanks,Matt
I tried it Matt, threw a code right away, now that I need to return it no body is answering the phone. Probably just taking a long weekend
Old Aug 21, 2021 | 11:05 AM
  #65
Mike@SolerEngr
Supporting Vendor
No, but even if you could it wouldn't matter. The throttle body doesn't need to be fully open until rpm>3000.
Old Nov 10, 2024 | 07:42 PM
  #66
Spark2005C6's Avatar
Spark2005C6
Mike, Looking to see if still looked at as a backburner project being 2024? A few of my buddies just added these to their C8’s so they got me thinking. Your website doesn’t show anything yet for the 05’ so I figured I’d find something here.
