Soler Prf. Throttle Controllers for C6 available now
Old Feb 27, 2020 | 07:27 PM
Mike@SolerEngr's Avatar
Mike@SolerEngr
Supporting Vendor
Default Soler Prf. Throttle Controllers for C6 available now
Hello folks, we have been very successful with the LT1/LT4/LT5 engines (many reviews here) and want to extend that to the LS3/LS7/LS9. We are happy to announce that our throttle controllers are now available for the C6 (2006-2013).
Lots of fun for only $75 and 15min DIY here:https://www.solerengineering.com/store/se0869-tc
Instructions attached.
__________________
Soler Performance LLC
support@solerengineering.com
(251) 468-9786
Last edited by Mike@SolerEngr; Mar 5, 2020 at 03:08 PM. Reason: added instructions
Old Feb 29, 2020 | 05:56 PM
Mike@SolerEngr
Supporting Vendor
A little bump, so you guys don't miss on this supereffective inexpensive mod.
Old Feb 29, 2020 | 09:52 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Please explain why this is only available for the 09-13 yet the Vitesee works with 06-13. Thanks.
Old Mar 1, 2020 | 05:23 PM
Mike@SolerEngr
Supporting Vendor
Being tested right now by members, if everything goes well, they'll be out in a week or two. We decided to separate the tests into two groups 2005-2008 and 2009-2013 due to the known small differences.
Old Mar 1, 2020 | 06:13 PM
2008 Corvette
You will find that it will not work on the 2005.
Old Mar 5, 2020 | 03:07 PM
Mike@SolerEngr
Supporting Vendor
Okay, now available for 2006-2013 too after being successfully tested. 2005's remains a mystery but we'll get to it.
Old Mar 5, 2020 | 03:09 PM
Mike@SolerEngr
Supporting Vendor
We just finished testing them, so, yes they work on 2006-2013 C6's.
Old Mar 6, 2020 | 08:33 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
As you probably know, the 2005 has a different ECM.
Old Mar 6, 2020 | 10:58 AM
apessusn's Avatar
apessusn
Just ordered for my 2008 A6 vert. Can't wait to feel the difference in throttle response. I added a pedal commander to my 16 F150 and it made a huge difference.
Old Mar 6, 2020 | 12:48 PM
jamieo's Avatar
jamieo
Has anyone used these on a car that has already been tuned?Just wondering if there would be improvement on what has already been changed with the tune.
Old Mar 10, 2020 | 09:30 AM
apessusn's Avatar
apessusn
Woke up early to install the throttle controller. Just a heads up that the directions provided are not for 2008 C6. I you-tubed and found a video explaining how to install.
Quick directions: Push seat all the way back and tilt up steering wheel. Not much room under there. Remove the plastic cover that is held on by 3 plastic clips. Use a 13mm and take off the 2 bolts holding the gas pedal. The top one is somewhat hidden. That allows you to remove the clip and connection. Then just clip in the throttle controller. Put the gas pedal back on, run your wire and follow the setup directions.
I haven't had a chance to drive with it, but will as soon as this lousy rain stops.
The packaging was top notch, and it arrived very quickly. Can't wait to see the increased throttle response.
Please keep me in the loop when you have the throttle bodies available.
Thanks, Alex
Old Mar 13, 2020 | 08:30 AM
chevy406's Avatar
chevy406
You can not increase throttle response tables using HP Tuners starting with the Gen IV cars. Anything more than 3 or 4% increase to the factory throttle calibration will set "Reduced Power". So to answer your question, I'm sure this product will work well with a car that also has a custom ECM calibration.
Old Jun 3, 2020 | 09:50 PM
jimijam's Avatar
jimijam
I had been running mine on SP 4. Earlier today, while popping around a soccer mom in a tahoe that was blocking my view, I puckered up for a second. Checked the controller. Yeah, somehow I got on LU 5. Money and time well spent.
Old Jun 4, 2020 | 08:18 AM
cdm747's Avatar
cdm747
St. Jude Donor '17-'18-'19-'20-'21-'22
I put one on my 06 Vert with LS2. Huge difference in throttle response even in the Comfort Mode. I leave mine set at CF5 for normal driving and it feels great.
Old Jun 4, 2020 | 09:49 AM
PushrodV8's Avatar
PushrodV8
Where are you guys sticking the controller? On the dash someplace high or low?
And did you have any trouble getting the sticky back to adhere to the dash?
Thanks!
Old Jun 4, 2020 | 02:47 PM
Nutzz's Avatar
Nutzz
Does anyone make one of these for the '05?
Old Jun 4, 2020 | 06:56 PM
jimijam's Avatar
jimijam
I haven't stuck mine yet. I just tucked the wire under the center console and then threw it in the ashtray along with the M2M remote. One of these days, I'll mount them both somewhere.
To Soler Prf. Throttle Controllers for C6 available now
Old Jun 4, 2020 | 09:00 PM
NYC6's Avatar
NYC6
What would this do for a Centri equipped A6 car? With the Vortech it would be nice to have a better bottom end till it spools up.
Old Jun 4, 2020 | 09:36 PM
Mike@SolerEngr
Supporting Vendor
It controls the relationship between pedal input and throttle opening. You have 37 choices of those, they will feel great regardless of setup. I think you may benefit also from our throttle bodies, we Modify both the silver blade C6 2005-2008 and the gold blade C6 2009-2013. We took them from 90mm to 95mm at WOT, in between they are shaped so your manifold pressurizes quicker for a better bottom end.
If you get a TB we can give you a really good deal on a TC.
Old Jun 4, 2020 | 10:27 PM
NYC6's Avatar
NYC6
Thanks, not ready to make the jump for a TB but seriously considering the TC.
