2005 manual column lock - Tip and Fix
Old Jun 8, 2020 | 01:18 PM
ssg10587's Avatar
ssg10587
Default 2005 manual column lock - Tip and Fix
Just my experience to hopefully help some others. Tried repairing this using the bypass found on ebay here: https://www.ebay.com/itm/2005-Corvet...kAAOxynapRhGu6
Had no luck so tried resetting the battery and still no luck. Still was getting "Service Column Lock". From reading here it sounds like the lock uses a voltage check and since these cars seem to always have something wrong if the battery is dead, I went and checked and sure enough the battery had a bad cell. Bought a new one, charged it up, started it with original column lock and good. Then set up bypass and good as well.
Hope this helps! Chalk this one up to another bad battery. Glad I installed the bypass though.
Lot of good discussion here with Dano: https://www.corvetteforum.com/forums...lumn-lock.html
Old Jun 8, 2020 | 11:47 PM
Dano523's Avatar
Dano523
Steering column lock gears tend to bind up in a few years, and why the elimitor worked very well to at least get that out of the system. The SCLM last longer, but since they have manual relays in, only a mater of time until they go out as well. So 2005 M6 owners got to play the what is going to go wrong game just way to much with both the motor gears, and the module itself.
Now its really a mixed blessing that GM no longer has the SCLM to replace bad ones, since they now finally came out with a BCM firmware re-flash that take both the steering lock, and the SCLM out of play once for for all (not longer need to by a eliminator).
If you want the dealer to do this, it around $450 since they pull the steering wheel/column locking ring so the motor can never lock up the wheel once it and the module is flashed out, but if you know someone with a tech II (or just want to by a VX GM Nano so you do have a tech II device your self for around $100) and already have steering lock out of play, then TDS subscrption is only $40 for a 2 years to reflash the BCM yourself.
https://www.corvetteforum.com/forums...ogramming.html
Old Jun 9, 2020 | 10:30 AM
ssg10587's Avatar
ssg10587
Thanks Dano! Honestly just spent a bunch getting the harmonic balancer issue fixed so using the bypass for now and will go from there. Asked around and no luck for the tech 2. Wish I knew someone with one so I could permanently fix this.
Link is bookmarked! Sounds like $140 for the nano and subscription so I definitely may.
EDIT: If you wouldn't mind confirming:
Need:
Amazon Amazon
https://www.amazon.com/Sabrent-Converter-Prolific-Chipset-CB-DB9P/dp/B00IDSM6BW/ref=sr_1_3?crid=3UU6B7E7ODXBR&dchild=1&keywords=rs232+to+usb&qid=1591713652&sprefix=rs232%2Cautomotive%2C178&sr=8-3 https://www.amazon.com/Sabrent-Converter-Prolific-Chipset-CB-DB9P/dp/B00IDSM6BW/ref=sr_1_3?crid=3UU6B7E7ODXBR&dchild=1&keywords=rs232+to+usb&qid=1591713652&sprefix=rs232%2Cautomotive%2C178&sr=8-3
- Looks like maybe dont need this with the nano? Looks like nano comes with connection cable for laptop to nano and then nano goes in obd2 connector.
https://www.acdelcotds.com/subscriptions# - Vehicle programming subscription
Follow your instructions in post 3
Old Jun 9, 2020 | 04:32 PM
Dano523's Avatar
Dano523
Just need the nano, and it will come with it own USB cable. When you get it, PM your phone number so I can talk you through setting it up correctly on your lap top.
Amazon Amazon
Yes on TDS 2 years for $40 as well and same thing with a quick phone call, so you load all the needed driver when loading the TDS on line software on your machine the first time as well.
Old Oct 16, 2022 | 06:05 PM
digimc's Avatar
digimc
SSG, if I may ask, did you program the BCM yourself with the VXDIAG? I'm looking to do this now myself. I realize this thread is two years old but, it seems like navigating the Tech2 and knockoffs to achieve programming is a minefield. I have spent many hours over the past week trying to ferret out the exact process via endless searches with the result being only a cursory view. I'm a computer guy and it is frustrating no end. It is certainly less expensive to simply have a dealership do the flash for $100 - $200. But, then I wouldn't own the equipment for the next challenge.
Old Oct 22, 2022 | 06:25 PM
Dano523's Avatar
Dano523
VX manager and the tech2wincrack that comes with it, is all that is needed.
Your going to be using TDS software with the nano, to reflash the BCM.
So with nano in hand, install VX Manager on the laptop. Now connect the nano to the lap top, update the nano firmware by clicking on that icon in VX manager, then click on license icon to up date it too. Leave the Nano connected to the machine, VX manger still open, then go to the white disc tech2 win folder that came with the Nano, and click on Autoinstall, exe to install Tech2win to your machine. Once its installed, go back to VX manager, click on the Diag tab on top, then go to apps and install T2W/GDS2, Pass through, SGM rds apps.
Now go to A/c Delco to buy a 24 month subscription for SPS for $42.
Once you have the subscription and logged on, will select SPS.
The first time around for SPS, it will load the needed TDS software on to your machine, then quit you out of SPS.
You will go back into TDS again once you have Java set up, and this time with the TDS software up and running, going to get a pop up box that will ask you if you want to load drivers, including the Wrapper driver. Install all three drivers from that pop up list.
For the Nano device with SPS, use the Diag driver from the list.
Now will connect the nano that is already connected to the laptop when you started SPS, to the car, and will click to scan the car to pull the vin.
Double check to make sure that the vin is correct, since clicking next is going to lock your account to that Vin number for the subscription.
A few clicks later in TDS SPS, will come to the module list, select BCM, then going to see only 1 firmware file in the list to select, which is the one you want to flash it. SPS will walk your through the rest of the BCM flashing.
Old Oct 23, 2022 | 02:06 PM
digimc's Avatar
digimc
Thank you very much Dano! You are a prince among men for the time you devote to help us little people! :-)
To 2005 manual column lock - Tip and Fix
