CEL after can install????
Old Apr 14, 2024 | 08:45 PM
Cautionarytale's Avatar
Cautionarytale
Default CEL after can install????
Just had a cam done by a relatively highly recommended shop. Car drove fine for 2 days, I have been babying it. 2 days after driving and I’m at a red light, feel a thud like someone hit me, look down and have a check engine light. Start driving some and car won’t shift into second, can’t go above 30mph of course on the busiest of roads. Check the codes and have P0700, P219A and P0716. Am I SOL? Anyone else had this happen?
Old Apr 14, 2024 | 09:11 PM
jamieo's Avatar
jamieo
Those p07xx codes indicate an issue with the transmission position sensor.The other codes shows afr issues with bank 1.If you have a scanner look at the shifter position sensor data.
Old Apr 14, 2024 | 10:08 PM
Cautionarytale
This isn’t a high quality scanner it’s an old SCT I use to check codes
Old Apr 15, 2024 | 09:49 AM
Jfryjfry's Avatar
Jfryjfry
Sounds like it’s not a “cam swap then cel” but more of a “thud then cel.”
probably related to the cam swap but maybe not.
pull a valve cover or two and see if anything stands out before running it anymore.
Old Apr 17, 2024 | 08:48 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Believe it or not the thud is by design. It's indicative of an invalid torque signal to the transmission and when it happens it maxes out the line pressure as a way to let you know something is wrong.
Although it's likely just a coincidence that it happened right after the cam it might be possible something in your tune got changed incorrectly.
To CEL after can install????
