C7 interior expectations.
Old Mar 23, 2012 | 03:59 PM
  #181
Notch's Avatar
Notch
Originally Posted by goatts
The 911 costs twice as much as the vette so I guess it does have a nicer interior.
There is not a direct correlation between the 911's MSRP and the quality of the interior.
Old Mar 23, 2012 | 04:08 PM
  #182
jackhall99's Avatar
jackhall99
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Maybe not a DIRECT correlation, but when the entry Carrera starts at $80,000 MSRP compared to the Corvette's $49,600, the interior can and should be of better quality.
Old Mar 23, 2012 | 04:31 PM
  #183
Notch's Avatar
Notch
So just what is the correlation? Using your "MSRP-to-interior quality" concept, the Lotus Exige S 260, with an MSRP of about $75,000, should have a better quality interior than the $49,000 Vette. I'll let you decide...
Exige S 260 interior:
Lotus Exige S 260 Coupe $74,950
Old Mar 23, 2012 | 04:50 PM
  #184
jackhall99's Avatar
jackhall99
So just what is the correlation? Using your "MSRP-to-interior quality" concept, the Lotus Exige S 260, with an MSRP of about $75,000, should have a better quality interior than the $49,000 Vette. I'll let you decide.....
What is YOUR point?
YOU stated there is not a direct correlation between the 911's MSRP and the quality of the interior, compared to the Corvette. In my opinion, they are competitors and can/should be compared, $ for $.
The Lotus is an entirely different animal, and folks who go that route are generally not in the market for the 'vette or Carerra.
Old Mar 23, 2012 | 04:59 PM
  #185
goatts's Avatar
goatts
I could say the sky is blue and Notch would argue about it...
Old Mar 23, 2012 | 05:06 PM
  #186
Notch's Avatar
Notch
What is YOUR point?
That there is no "MSRP-to-interior quality" formula.
Two entirely different concepts; MSRP-to-interior quality, and "competitors".
And I did not draw any correlation between the 911's interior quality/MSRP as compared to the Vette. As a matter of fact, I have said that there is no correlation between MSRP and interior quality, using the Exige as an example. Your premise is that there is a correlation between MSRP and interior quality, and I'm saying there isn't. A clear distinction.
Old Mar 23, 2012 | 05:07 PM
  #187
Notch's Avatar
Notch
I certainly wouldn't.
But I will discuss MSRP vs interior quality.
Old Mar 23, 2012 | 05:08 PM
  #188
Telepierre's Avatar
Telepierre
My head hurts.
Old Mar 23, 2012 | 05:11 PM
  #189
Telepierre's Avatar
Telepierre
How about causality? Is there causality between interior quality and MSRP?
Old Mar 23, 2012 | 05:13 PM
  #190
jackhall99's Avatar
jackhall99
The comment was made earlier about the Corvette's interior compared to the 911, and the cost relationship between the two. Then you jumped in tossing hand-grenades.
I agree with goatts: you would argue black vs. white.
Old Mar 23, 2012 | 05:15 PM
  #191
Notch's Avatar
Notch
I don't think so.
What's your opinion?
Old Mar 23, 2012 | 05:21 PM
  #192
Telepierre's Avatar
Telepierre
I don't think so.
Well - if "stuff" costs X and "better stuff" costs Y and Y > X THEN
If MSRP = cost + profit (if profit > 0) THEN
for profit X = profit Y
MSRP (X) < MSRP (Y)
or no?
Old Mar 23, 2012 | 05:23 PM
  #193
Notch's Avatar
Notch
You have to read my posts at face value.
And there have been no grenades thrown. People here opine that the more expensive 911 should have a nice interior because of it's MSRP, but fail to offer any specifics regarding the correlation between the two.
As for Porsche, a large portion of the MSRP reflects what the car can command from the market; there is a significant profit margin dialed into the MSRP. Many people here confuse the profit margin with cost of materials.
Old Mar 23, 2012 | 05:34 PM
  #194
Telepierre's Avatar
Telepierre
Logical and to your point Porsche commands higher margins on lower volumes and corvette does the opposite somewhat. There is however no refuting that it costs more to interior a Porsche than to interior a Corvette. I say this based on the fact that interiors are still relatively hand craft intensive to apply maybe less so to build components wise.
Old Mar 23, 2012 | 05:45 PM
  #195
Notch's Avatar
Notch
MSRP (X) < MSRP (Y)
or no?
No. The issues are:
1. How much more does stuff Y cost than stuff X?
2. Does "stuff" alone define a "higher quality interior"? Or does design, fit, finish, art, durability and ergonimics also play a role in quality?
A manufacturer (Porsche for example), may be able to design and build an interior that costs them the same as it costs GM to design and build the same interior, but Porsche would be able to charge much more for it (profit margin) than GM. Or it may cost Porsche 5% more in design and manufacturing investments for their interiors versus GM, but Porsche can charge (and get) 20% more (profit margin) for it than GM. Some here attribute the entire 20% to the cost of actually designing and building the interior, when (in the case that I offered) it would in fact only be a 5% difference. I've made up the numbers but the concept and ratios apply regardless of the actual values. The Lotus S 260 is a perfect example of how you can not assign an "interior quality" based on an MSRP.
Old Mar 23, 2012 | 06:00 PM
  #196
goatts's Avatar
goatts
Ok. In general, high end cars will all have expensive interiors. But the track versions of these cars will be stripped to save weight. Less is more. Porsche and Ferrari both do it (RS has pull strap on door and Ferrari removes the carpet). The Lotus you refer to is a track oriented car. I should not be having to explain this to you.
Old Mar 23, 2012 | 06:06 PM
  #197
Notch's Avatar
Notch
You know how much it cost Porsche to build the interior on the 991?
And the RS is a perfect example of a "high end" car (high MSRP) that has a lower quality interior; meaning that, like the Lotus example, one can not draw interior conclusions based on MSRP.
To C7 interior expectations.
Old Mar 23, 2012 | 06:27 PM
  #198
jackhall99's Avatar
jackhall99
As goatts posted earlier, you'll argue just to argue.
What Porsche takes out of the RS in interior appointments is put back in, plus a lot more, by their Renn Sport treatment. You certainly knew that, but if you didn't, maybe you do now.
Old Mar 23, 2012 | 06:37 PM
  #199
Telepierre's Avatar
Telepierre
I was trying to apply well accepted conventions to make sense and rationalize the argument - otherwise we get lost in the world of hypotheticals and there seems to be too many here:
Turns out that by virtue of better materials volume discounts corvette probably has the upper hand here so I seriously doubt that Porsche has an hypotethical superior interior formula. If interior replacement and option costs are an objective indication of where Porsches stands than it is fair to assume there is no magic/hypotetical here: material + labor (labor being almost equal) leads to higher interior costs for Porsche.
incremental ROI...go it, but I don't see were we are going with this higher profit margin theory.. there comes a point were the higher margins hits volume and we already said that corvette prices and builds for volume which keeps costs down...at parity of outcome (design, fit, finish, art, durability and ergonimics).
I agree with you that there is a wide band of parameters leading to an MSRP. This withstanding and with replacement costs in hand, it is hard for me to see that Porsche pays less for interiors and charges more...
Old Mar 23, 2012 | 07:04 PM
  #200
jb_va2001's Avatar
jb_va2001
DC Area Events Coordinator
Actually, the 911 costs twice as much as some Corvettes. Here lies the problem, Corvettes go out the door from $45K to $135K. The buyer of a $50K Corvette will accept things someone spending $100K won't. And interior compromises appears to be high on the unacceptable list.
Cheers,
JB
