C7 Weight Issues
Old Jan 27, 2013 | 05:09 PM
  #101
Racer X's Avatar
Racer X
Originally Posted by JoesC5
I never said, not did I imply, that the LT1 simply dies after 4,000 RPM. What I did say, is that the torque doesn't continue to climb and then I does drop off quite rapidly at the top end compared to the LS7. The LT1 is not designed to move enough air in the upper RPM range to go above approximately 450 HP. Without increasing the amount of air, the engine can't produce more horsepower. Why should the LT1 produce 500 HP at 5,900 RPM when it can't move anymore air then the LS3 with it's 436 HP at 5,900 RPM?
The clue GM gave us about the ability of the LT1 to move more air than the LS#\3 is that both the heads and the exhaust are said to to have higher flow rates thaqnthe base LS3. The base LT1 exhaust was stated to flow 13% more than the Base LS3 exhaust. That implies that they expect the base engine to produce up to 485HP in the lifetime of that exhaust part number. The dual mode performance exhaust is stated to flow up to 26% more than the base exhaust. So it could conceivably support 549 HP at the level of restriction that GM finds acceptable.
Those are the hints that GM gives us. Why would they produce parts that have this much flow if they did not intent to use it in some part of the production life cycle of the exhaust system?
Old Jan 27, 2013 | 07:14 PM
  #102
Kappa's Avatar
Kappa
Originally Posted by GordyRay
I have a distant family member (cousin) that works for GM and was able to see several C7 mules test at the proving grounds. Once the C7 started matching the times on the track to the C6 Z06 times is when Ed Welburn accepted the "stingray" name plate. My cousin still maintains that the C7 has more hp/tq than the estimated 450 number that is being used. He also said that from the beginning of the project that one of the priority issues was weight reduction. Tadge hammered everyone on the requirement/need to find the best ability to drive the car fast on a track with better precision and steering feel. Obviously weight, balance & suspension was key and this is a significant improvement over the C6.
The C7 is only going to get better. By summer we will all want one.
Cheers, Way to go GM. The C7 looks awesome in Cyber Gray and RED.
Interesting. I guess we'll see soon enough. I think the C7 Z51 is going to be a very quick car around the track even going off the limited info we have now.
The C7 should be able to take on the C6 and C6 GS with ease by the end of its development. A similar thing happen with the Porsche guys with the 997 GTS and 991S. The 991 with its superior tech and design ended up being a good amount better in every performance metric even though prelim numbers suggested otherwise.
Old Jan 29, 2013 | 01:23 AM
  #103
VETTEMANN's Avatar
VETTEMANN
'Distant Family Member' ...try March C&D Magazine And that's not even what they said. They were talking about the new brakes on the Z51 package as allowing 'some competitive times' at VIR.
Had nothing to do with weight reduction - the C7 is heavier.
Had nothing to do with power - the C7 has less that the C6Z06
Had nothing to do with cornering - the C7 is good with just over 1G, but not as good as the C6Z06
Old Jan 29, 2013 | 03:47 AM
  #104
lt4obsesses's Avatar
lt4obsesses
Originally Posted by DREAMERAK
GM also said it would be faster than a Grand Sport which they list as 3.95 sec. Don't forget the Z06 like torque, under 4 sec no problem imo.
They wouldn't have said it if they hadn't already done it with the car. 0-60 in under 4 seconds, they tried it and done it. Beat the Grandsport track times at the proving grounds, tried it, done it. There is absolutely no way, they're going to make these claims at the reveal, in front of thousands of viewers, unless they know first hand that it is, indeed, true.
Old Jan 29, 2013 | 05:12 AM
  #105
Raitzi's Avatar
Raitzi
When you estimate first journalists get to drive the car?
Old Jan 29, 2013 | 10:32 AM
  #106
lt4obsesses
Well, they won't be actually building the car until June, and GM estimates in the dealerships perhaps September. So maybe late summer, early fall?
Old Jan 29, 2013 | 10:56 AM
  #107
rad928music's Avatar
rad928music
Car seems kinda heavy.
Yes I know all those Air bags and Options.
My C4 86 wieghs in at 3080 with:
Iron Block
Iron Heads
Steal Frame connectors
Way more Sub assemblies
Spare tire & jack
Yeah I no its old Tech but its over 200lbs lighter than C7.
I think they could shed some weight with options.
Delete: 19" 20" wheels
Delete: Electric seats
Delete: thick Insolation
Old Jan 29, 2013 | 12:27 PM
  #108
Rapid Fred's Avatar
Rapid Fred
Iron Block
Iron Heads
Spare tire & jack
Oh boy have you just reopened a can of worms. I'd love to see an analysis showing exactly what items, and how many lbs. for each, offset the 200lbs lower starting point in your C4 PLUS the lighter aluminum frame, engine block and heads, CF body panels, no spare and jack, etc. We can surmise it is airbags all over the place, passenger compartment reinforcements in doors and A-pillars, extra sound insulation, interior coverings, steel torque tube, much bigger brakes, and other items. Problem is, we're all conjecturing and nobody really knows except the C7 team.
The comparison would be very interesting. I hold to the belief that GM could have made a great Vette sticking to a no-compromise "it will be less than 3K lbs" mandate even given the safety and usable space requirements. But, they had their reasons not to...and they are smart people.
Old Jan 29, 2013 | 12:51 PM
  #109
tuxnharley's Avatar
tuxnharley
Did he giggle when you asked if the horsepower is going to be 450?
one giggle=460 HP
two giggles=470 HP
three giggles=490 HP
four giggles=500 HP.
I'm letting you in on this secret code that is only known to engineers, so don't be spilling the beans, Okay?
I think there's a problem with your methodology, Joe. Your giggles per horsepower ratio is not linear - you have most at 10 HP per giggle, yet have included a 20 HP spike at 3 giggles. We all know that has to be wrong, as good engineers like Tadge only engage in linear giggling!
Old Jan 29, 2013 | 01:00 PM
  #110
Kappa's Avatar
Kappa
Iron Block
Iron Heads
Spare tire & jack
Let's put your C4 to some crash tests.
I'd like to also point out that the C5 chassis was 4 times as stiff as the C4, and the C7 is 50% stiffer than the C6 chassis.
It's really not comparable.
Old Jan 29, 2013 | 02:11 PM
  #111
Rapid Fred's Avatar
Rapid Fred
But apparently the C7 chassis is still LIGHTER! Certainly 99 lbs. less than the C6. And, as I remember, the C5 chassis was not materially heavier than the C4 even with all the stiffness.
Where, specifically, is the extra weight? And, how much? You don't know, and I don't know. I just don't want to let the C7 team off quite that easy. They could have made a tremendous statement by designing to a 3K limit and sticking to it. But, it seems they chose not to. Not that the C7 will be a Sherman tank or anything, but I can't help but be disappointed.
Old Jan 29, 2013 | 02:15 PM
  #112
tuxnharley's Avatar
tuxnharley
Well, it'll still be lighter than a comparable 911!
Old Jan 29, 2013 | 02:42 PM
  #113
Hemi Dave's Avatar
Hemi Dave
one giggle=460 HP
two giggles=470 HP
giggle, giggle,giggle, giggle.......and when I said E85? He giggled 5 more times
Old Jan 29, 2013 | 02:43 PM
  #114
HumanWiki's Avatar
HumanWiki
St. Jude Donor '13-'14
Pssssh... Try coming from a 5th gen Camaro with a PD Blower on it...
Old Jan 29, 2013 | 03:23 PM
  #115
Kappa's Avatar
Kappa
3000lb for a base, non-exotic RWD V8 sportscar is ridiculous IMO. Don't know where people were getting that.
You look at the as-tested weights(not curb weights) for most sportscars these days and its rare to see anything under 3300lb. Cars like the 458 are weighing in a 3400lb even with all of the technology Ferrari used on that car.
In a C/D test a few months ago, the C6 Z06/Z07 came in at 3259lb and the 991 Carrera S was at 3265lb. That's about as light as you are going to get for an all-around $50K+ 400+hp sportscar IMO. The C7 should be of a similar weight.
Old Jan 29, 2013 | 03:45 PM
  #116
Davy_Baby9's Avatar
Davy_Baby9
Originally Posted by arkus
I thought the C7 was going to be a super light weight car with a smaller engine .
This didn't happen so to have better performance than the C6 , they need more hp which they did .
The High output model , if weighed the same as the ZR1 needs more Hp than 638 .
DO you guys really think GM will exceed 638 hp? We know they can but will they ?
Old Jan 29, 2013 | 05:08 PM
  #117
theseal's Avatar
theseal
I see where you are coming from, and it is true that most modern cars have gotten extremely fat. But the 3000 is not ridiculous; the fact that these cars weigh more than that is ridiculous.
that weight is almost ALL modules, wiring, sound deadening, and NVH crap.
a miata passes modern legal requirements at 2100. The iron motor and diff in that car, and spindles, control arms, etc., are all almost as heavy as the vette's higher horsepower stuff. the body and unibody are ALL steel.
a modern corvette should not weigh much more than 2500, if properly executed, and still be every bit as comfortable and useful as vettes have been all their model lives.
To C7 Weight Issues
Old Jan 29, 2013 | 05:51 PM
  #118
Rapid Fred's Avatar
Rapid Fred
Not ridiculous -- just a challenge that the Vette team decided not to embrace. First, drop the 180 lbs for the driver which is in the test weights, and that Carrera S CURB WEIGHT (which is what we're comparing in this thread) is a bit below 3100 lbs. Same with the Z06. That is the "competition." I don't care about the 458. So, we're talking 100 stinkin' lbs. less than the Z06 -- and we've got narrower wheels and tires, CF body parts, less glass in the hatch, titanium seats. Why not lop a few inches off the thing? WHATEVER IT TAKES.
Water under the bridge, at this point.
This does not mean the C7 will be a bad or uncompetitive car. Actually, it should be pretty awesome. But, perhaps I'm over-influenced by the Steve Jobs bio that I am in the middle of. He defined what he wanted, and basically took no prisoners in making sure Apple delivered. I guess I was hoping for the same single-minded obsession with weight on the C7. IDK what would have been sacrificed to get there, but that's not my problem
Old Jan 29, 2013 | 06:01 PM
  #119
Racer X's Avatar
Racer X
The 2013 Miata shows a curb weight of 2480.
The 2005 Lotus Elise had a curb weight or around 1980 pounds on the Sport package. The size difference between an Elise and a Corvette is huge. The level of interior trim was almost non-existent. Sound deadening? what is that? The Lotus did not meet certain crash standards at that time (low speed without damage) and needed exemptions.
The 2013 Evora S has a curb weight of over 3150 pounds.
In order to get a complete roadworthy, and comfortable ( to the majority of potential buyers) is going to take a significantly smaller car to get to 2500 pound curb weight, or even a dry weight.
The Hennessey Venom GT(built off of an Elise chassis with a custom rear subframe) has a curb weight of 2743 pounds. You could probably drop a few pounds by doing without the supercharger. Still you would not have a car as comfortable and the ability to carry stuff like the Corvette.
Now while you and I could live with something like an Elise as a daily driver (I did) most people would not (witness Lotus sales).
I will be stunned if the base C7 Corvette comes out heavier than the C6 as intimated by GM executives so far. Especially with all the weight savings mentioned.
Old Jan 29, 2013 | 07:17 PM
  #120
b4i4getit's Avatar
b4i4getit
You are a bit naive. They can say whatever they want within reason at the reveal. Some people will believe it like it is fact. The engineering team knows full well that they have a few months to tweak things. They can take some weight out, tune the engine, etc to get to the performance they want. All the information put out so far has been quoted as preliminary information. They could not very well reveal the car as being of lesser performance.
