C7 Weight Issues
Old Jan 26, 2013 | 04:27 PM
  #81
JoesC5's Avatar
JoesC5
Originally Posted by Torch Z
You cannot win an argument with logic so you resort to insults?
I am quite confident of grasping your point -- interestingly, your own data (which may not be 100% correct based on good analysis by other thoughtful posters, but let's assume it is) illustrates MY point which is correct -- but you clearly did not get. Look at the data in bold red. Is it not obvious from that that as the LT1 sweeps from 4K to 5K that the average HP for the LT1 is very close? (Given that the LT1 is, apparently, 40HP GREATER @ 4K RPM and only 10 HP less @ 5K RPM). Accordingly, it would be very surprising if the LT1 would not stay with the LS7 thru 5K RPM. Further, the 365 HP for the LT1 @ 6500RPM is meaningless in your example becuase by then the LT1 driver would have shifted and put the engine in a more favorable part of the torque curve where the horsepower delta would have been reduced a bit.
So let's state this in a clear way as illustrated by your own data:
1K => 4K RPM LT1 > LS7
4K => 5K RPM LT1 ~ LS7
5K => 7K RPM LS7 >> LT1
So, your LS7 will own the 5K to 7K range, but if the C7 LT1 driver knows when and how to shift they will reduce the advantage somewhat. Meanwhile, they may even own you a bit in the very common street range of 3K => 5K RPM. And none of your bluster or insults means a thing becuase neither of us has seen the final stats on this yet -- when we do, I guarantee you I will know exactly the point at which the LS7 is superior.
Seriously -- what % of the time do you run your Z over 5K RPM? I mean, except for your Talladega triumph...
Actually I spend very little time above 5000 RPM with my Z06. I seldom go above 2,000 RPM in normal driving as the LS7's torque is great enough so I can shift early and not bog the engine and still accelerate quite briskly.
That's the whole 100% point of the VVT on the LT1. It was not designed as high RPM high horsepower engine at the sacrifice of low RPM torque.
Tell me. Why does a 1964 327ci Corvette with 350 lbs-ft of torque have 365 horsepower yet the same displacement engine with 360 lbs-ft of torque only have 300 horsepower?
With your beliefs of how engine operate, the 327 ci engine with 360 lbs-ft of torque should have 375 horsepower, not 300 horsepower. Correct? Then what about that other 1964 Corvette engine with 350 lbs-ft of torque and 375 HP?
Explain why three engines with the same displacement range from 300 horsepower to 365 horsepower to 375 horsepower yet their maximum torque only ranges from 350 lbs-ft to 360 lbs-ft, and....surprise...surprise...the engine with the greatest amount of torque has the lowest horsepower. I know the answer...do you?
Old Jan 26, 2013 | 04:32 PM
  #82
sam90lx's Avatar
sam90lx
Originally Posted by rcallen484
No matter the final weight, we know that it is 136 lbs less than it would have been with a steel frame and old body weight. To my thinking that pays off to the tune of 136 lbs.
This is true but it picked up more weight in other areas, may be a wash on the weight.
Old Jan 26, 2013 | 04:50 PM
  #83
JoesC5's Avatar
JoesC5
Jawnathin -- my point was not about PEAK HP for the LS6 @ 6300 RPM, nor the 55 ft/lb extra torque the LS7 delivers. It was the way JoesC5's initial post made it seem as though the LT1 simply dies after 4K RPM (it does not, with fairly flat torque through at least 4500 RPM and peak HP @ 5900 RPM) and that the LS7's 55 ft/lb torque advantage is constant from 6300 RPM => 4K RPM (it is not; it grows more gradually). Simply meaning that peak numbers do not tell the whole story.
Lost in all this is that we all agree with what the Chevy folks are suggesting -- that the performance numbers for the C7 base should fall neatly between the C6 GS and the Z06. My provocative thought is: don't be shocked if the C7 winds up VERY close to the Z06 (especially if they were a bit conservative with the 450/450 estimate). Then again, if the C7 really does weigh 3300 lb, the Z06 should remain significantly superior
I never said, not did I imply, that the LT1 simply dies after 4,000 RPM. What I did say, is that the torque doesn't continue to climb and then I does drop off quite rapidly at the top end compared to the LS7. The LT1 is not designed to move enough air in the upper RPM range to go above approximately 450 HP. Without increasing the amount of air, the engine can't produce more horsepower. Why should the LT1 produce 500 HP at 5,900 RPM when it can't move anymore air then the LS3 with it's 436 HP at 5,900 RPM?
Old Jan 26, 2013 | 04:58 PM
  #84
Rapid Fred's Avatar
Rapid Fred
Yes -- HP is a function of torque and RPM. High torque at high RPM gets higher HP than high torque at low RPM. Similarly, a low RPM "torque monster" (think diesels at the extremes) which dies at higher RPMs will not have high HP ratings -- but could actually be pretty fun to drive on the street. Clearly, the LS7 is a "peakier" engine than the LT1 will be. I was actually surprised to see that the LT1 may well deliver a tad more HP as it moves up the curve through 4K revs -- and may be "reasonably" close until 5K. If so, a lot of C7 owners will be very pleased at the car's performance.
So, you went into some insulting diatribe about what I do and don't know simply because your original oversimplified (not an insult; a fact) post neglected to look at the FULL torque curve for both engines in question BETWEEN 4K and 7K. Which is all I pointed out in my original post.
Then, you pulled out more detail on the torque curves and (inadvertantly, I assume) proved my point!
Read my original post again, and again, and again so you may gain understanding, grasshopper.
Old Jan 26, 2013 | 05:03 PM
  #85
Rapid Fred's Avatar
Rapid Fred
Go back to your original smackdown of my post. You did not say it, but you clearly implied it by going right to the 6300 peak of the LS7. I, for example, neither said NOR implied the LT1 will produce 500 HP at 5,900 RPM. GM is not claiming it; why would I go there? Oh, and it might be moving a bit more air since the last time I checked 450 > 436
Back to the OP's issue -- all this will be moot if in fact the C7 is as much heavier than the C6 Z as it looks like it will be...
Old Jan 26, 2013 | 06:00 PM
  #86
Caddylac10's Avatar
Caddylac10
The C7's ability to launch has just as much to do with its ability to squat and hook up as it does power.
The C7 has launch control and I'm sure it's a better system than the one the C6 has.
The C7 could have the same power as the C6 and sprint better if it hooks up more effectively.
Good drivers in the C6 were getting 4.1 give or take a tenth. Is it really hard to believe that a car with more power and torque and a better chassis can hit 3.9 or better?
The numbers haven't been released so the C7 may very well hit 3.8, but it's at least 3.9 as of now.
Z06 owners need to stop scratching their heads. It's 2013. A sub 4 second 0 - 60 time ins't that difficult for a car of the C7's caliber. Forget comparing Z06 and C7 dyno numbers.
Old Jan 26, 2013 | 06:04 PM
  #87
2006c6keller's Avatar
2006c6keller
Default Various car weight notations!
As of late, the last year or so, I have closely looked at the ET's AND the WEIGHT of the car to make my impressions.
Even the type of platform: RWD; AWD; front, mid or rear engine. It is interesting to note the ET's compared to the xWD setup, engine setup, etc (substitute R or A for "x" for type of wheel drive). In looking at ALL of the different exotics, you begin to recogonize the limits of all types of cars.
HP/TQ, tires, and type of platform (front, mid, rear engine and xWD) make the determination of ET's and their limits to each type of setup. GM must make radical changes to their platform in the near future because these limits are being rapidly approached. HP/TQ, weight, and design are big factors in determining the agility and straight line responses, but they all have physics limitations.
This C7 is beginning to approach limits and GM is realizing this in trying to reach their targeted numbers, a real challenge at this level of competition. We will just have to wait and see. I don't see much radical weight reduction at this point, GM has been chopping and the gains now are small.
Old Jan 26, 2013 | 08:00 PM
  #88
Shrike6's Avatar
Shrike6
Somba master
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
Well, they started off badly by making it BIGGER. Then added the AFM, which necessitated the extra weight of the steel torque tube, exhaust flap, and more insulation....
Old Jan 26, 2013 | 08:07 PM
  #89
GordyRay's Avatar
GordyRay
VETERAN
Default C7 performance still in testing...allot can change over 7 months
I have a distant family member (cousin) that works for GM and was able to see several C7 mules test at the proving grounds. Once the C7 started matching the times on the track to the C6 Z06 times is when Ed Welburn accepted the "stingray" name plate. My cousin still maintains that the C7 has more hp/tq than the estimated 450 number that is being used. He also said that from the beginning of the project that one of the priority issues was weight reduction. Tadge hammered everyone on the requirement/need to find the best ability to drive the car fast on a track with better precision and steering feel. Obviously weight, balance & suspension was key and this is a significant improvement over the C6.
The C7 is only going to get better. By summer we will all want one.
Cheers, Way to go GM. The C7 looks awesome in Cyber Gray and RED.
Old Jan 26, 2013 | 08:24 PM
  #90
Kozzzz's Avatar
Kozzzz
Amazing how many people have opinions on the C7's final weight and power when they don't know either number. Have faith guys; would it make ANY sense for GM to bring out a new Corvette that was slower than the previous Corvette of equivalent trim level?
Old Jan 26, 2013 | 10:13 PM
  #91
glass slipper's Avatar
glass slipper
You have this backwards...squatting means less traction/hook up. All Corvettes since the C4 have rear suspensions with anti-squat geometry. If squatting was a good thing, they would've stuck with the de Dion rear suspension from the C2/C3. Lol
Old Jan 26, 2013 | 11:22 PM
  #92
2006c6keller
Default How GM tamed the ZR1 rear end wheel hop.
On the powerful ZR1, "squat" is back in and was used to tame the rear end on the ZR1. The biggest thing that the "squat" does is to LESSEN wheel hop on the powerful ZR1. GM did several things to lessen this disasterious effects of wheel hop which broke or destroyed rear ends. It programed the magnetic ride suspension (MRS) computers to cause "squat" down to lessen the wheel hop on WOT. In addition, different sized diameter half shafts were also installed on each side to prevent harmonics. The result was the controlling of the rear end and prevented 638HP from destroying the differential, etc.
Old Jan 27, 2013 | 07:31 AM
  #93
glass slipper
Anti-squat is built in to the rear suspension geometry, GM didn't change the lower control arm attachment points for the ZR1 so it's exactly the same as the other models. They actually tuned squat out with the MSR by having the rear shocks go to the full stiff position when a launch is detected...you are wrong on both counts. You are correct about the different size axles to prevent the natural harmonics from forming.
Squat on launch is bad for traction on any car. The 4-link drag race rear suspension has two jobs...prevent squat and transfer weight to the rear. Squat on a road race car at any time is a bad thing since the main task of the driver is to not upset the chassis...anti-squat geometry in the rear suspension relieves the driver of that task, weight transfer still has to be managed by the driver.
Old Jan 27, 2013 | 08:35 AM
  #94
b4i4getit's Avatar
b4i4getit
Great post and let me add something .
I don't undertstand why some of you take every word spouted from GM as the unvarnished truth. If they were to announce right now that the C7 is slower than the C6 there would be an uprising from the Corvette faithful which would make the tailight issue seem like small potatoes. It is not a given that each succeeding generation of Corvette will be faster than the previous. There are diminishing returns. At some point you are not going to get much better in flat out acceleration unless you strap a rocket motor onto these cars. Every spec GM has mentioned so far is not cast in stone. Until the first production C7 is out there and there is some real world testing with it all numbers quoted are just marketing spin. That is what the word prelminary specification means.
Old Jan 27, 2013 | 10:10 AM
  #95
glass slipper
How do you know the LT1 torque curve drops off quite rapidly on the top end? How do you know the LT1 doesn't move enough air in the upper RPM range to make over 450 HP? How do you know it's impossible to increase HP without increasing the amount of air? How do you know the LT1 can't move any more air than the LS3? The answers to all 4 questions is obvious and the same...you don't know. I'm going to trust the GM engineers over you, I have a clue how they've accomplished all of the above but wouldn't begin to spout my theories as absolute truth. This isn't the '60s, theories that worked on 327s have no place in today's engine technology. Unless you're somebody really special and have inside info from GM, you may want to hedge your bets above. If that is inside info, you may want to tone it down a little before you get a knock on your door from GM.
Old Jan 27, 2013 | 11:46 AM
  #96
C7/Z06 Man's Avatar
C7/Z06 Man
Unlike man's law, the law of physic's cannot be bend or broken.
My understanding is that the C7 LT1 engine has more compression than the LS3; all things being equal that means more power for the LT1. Oh, and lets not forget the electric steering which also adds to the power output that I said the Corvette would/should have months ago and should of had years ago. A lot on here boo-hooed that and said no way in a sports car!
Old Jan 27, 2013 | 12:31 PM
  #97
JoesC5's Avatar
JoesC5
So, when GM dropped the compression ratio from 10.9:1 on the LS2 to 10.7:1 on the LS3, the horsepower dropped from 400 all the way down to 436? Or did other factors come into play, such as larger displacement, high flow heads, larger intake valves, high flow intake manifold and new exhaust manifolds?
To C7 Weight Issues
Old Jan 27, 2013 | 12:49 PM
  #98
C7/Z06 Man's Avatar
C7/Z06 Man
Did you not read: all things being equal?
The point of my post is that the compression ratio of the LT1 also adds to it's higher output.
Old Jan 27, 2013 | 12:57 PM
  #99
JoesC5's Avatar
JoesC5
Do you believe that all things are equal between the LS3 and the LT1 other then the bump in compression?
I don't believe they are equal, so your assumption that the horsepower will automatically increase on the LT1 because of a bump in compression isn't correct. To many differences between the two engines that have to be taken into consideration.
Old Jan 27, 2013 | 01:00 PM
  #100
PCMusicGuy's Avatar
PCMusicGuy
To the OP, what you say may very well be true. I don't believe for a second that the C7 will weigh less than the C6 at comparable trim levels. That said, I'm sure the car will still be fantastic.
