Issues with C7 Trunk
Old Oct 6, 2013 | 07:35 AM
GE-Moe's Avatar
GE-Moe
Default Issues with C7 Trunk
We got our C7 early on Monday. One thing noticed was trunk doesn't close properly, had to close it several times before it would actually close flush. Seems to latch but the trunk light would still stay on and if you drive, it will say trunk still open. I talked with dealer and he mentioned the blue one he has also has the same issue.
Anyone else on this forum deal with trunk issue?
Old Oct 6, 2013 | 07:44 AM
66dreams's Avatar
66dreams
I noticed the same thing on 2 C7s. It needs a good push to lock down and doesn't seems to have the pull down feature as the C6. I'm going to check the online manual.
Old Oct 6, 2013 | 07:46 AM
GE-Moe's Avatar
GE-Moe
Do you also notice on the right side of the trunk you can kinda push down on the corner as if it's popped up or something and not flush?
Old Oct 6, 2013 | 07:49 AM
George36's Avatar
George36
Same issue here. I thought it would be easier to close with the new technology they supposedly used with metal taking on different properties when electric current is applied. It's good with the windows open, but when they are closed, you really have to slam it, to close it.
Another bug to get worked out.
Old Oct 6, 2013 | 07:52 AM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
Oh dear. Mine works fine. I would hate to think others do not.
Old Oct 6, 2013 | 08:00 AM
DanTheFireman's Avatar
DanTheFireman
Mine closes fine, flush all around. You still have to close all the way manually, one of the things that was improved in '09 on the Z06 was auto closing and it's a pretty nice feature we should all have. The hatch closes fine with the windows open but the "vent" doesn't do what it's supposed to.
Old Oct 6, 2013 | 08:03 AM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
I think i heard something about them getting rid of the auto closer because of weight reduction. I personally would rather the added weight.
Old Oct 6, 2013 | 08:24 AM
vetehead's Avatar
vetehead
same here!....I also thought the vent was suppose to take care of the air pressure problem!
Ron
Old Oct 6, 2013 | 08:34 AM
Menesenha's Avatar
Menesenha
Agreed, my white one is the same way. Rather an annoyance to close the trunk and then have to press down on it fairly firmly to get it to latch all the way, especially if there's any dirt on my hands I can't see (heaven forbid) and it dirties up the white.
Old Oct 6, 2013 | 08:39 AM
c54u's Avatar
c54u
Can you try closing the hatch with the car door open or window down a bit? Do you get the same results?
Old Oct 6, 2013 | 08:49 AM
George36's Avatar
George36
Much easier when the window or car door are open.
Old Oct 6, 2013 | 09:40 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
I thought the "memory metal" latch device was used to open a vent that let the air out so it closed easier.
Old Oct 6, 2013 | 09:50 AM
Brett Hunter's Avatar
Brett Hunter
I noticed this while watching an NCM delivery. The guy from the NCM tried to close the hatch at least three times before finally giving up and pushing down on the hatch. He even looked inside thinking something might be blocking it from latching.
Old Oct 6, 2013 | 09:51 AM
trivette's Avatar
trivette
I just got mine on Friday and have experienced the same problem with closing the hatch. So much for the new technology... I figured the new metal feature they touted would have an issue eventually, but not right out of the gate! I guess I'll just slam it like on my '05 when the windows are up. Mine was one of the Nashville cars, #307, and obviously this wasn't the reason for the delay...or they couldn't come up with a fix.
george vee's Avatar
george vee
2015 C7 of the Year Finalist
I slam mine a bit harder and it closes.
Old Oct 6, 2013 | 09:54 AM
DoTheyMakeOtherCars?'s Avatar
St. Jude Donor '06
Mine closes fine. The car is very air tight. They taught me at the museum that you need to take your palm in the center and really slam it. You also might try opening a door or window before you close it.
GE-Moe's Avatar
GE-Moe
Yes I do the same also, but it's very odd that it needs to be done that way.
To Issues with C7 Trunk
Old Oct 6, 2013 | 10:12 AM
lastcowboy's Avatar
lastcowboy
yep sure will be nice when it's rainning or snowing and you have to get in the car open the windows so you can close the trunk after you put something in it .
kind of reminds me of the 05's roofs blowing off LOL . it's sounding like the same old GM ,sale them and worry about it later ....
Old Oct 6, 2013 | 10:13 AM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
Mine closes flush and even the entire way around too. I did notice last night when closing the trunk with the doors closed that it took a decent push. The only thing I don't like about that is the hand/finger prints it leaves. Call me picky.
S.
Old Oct 6, 2013 | 10:15 AM
mjw930's Avatar
mjw930
SLAM IT! Wow, that seems like bad advice. For the past 30 years I've used what is considered to be the proper way to close the hoods on my Porsche's and other sports cars to prevent damage to the hood / bonnet, lower the hood until it catches on the safely latch then use the palm of your hand directly over the latch and push down with just enough force to close the latch. It's basically the same as the auto close feature on the C6 except your palm is the auto closer.
You've got a composite hatch with a heavy piece of glass mounted in the middle of it. What do you think the result of "slamming" this shut hundreds of times will do to that structure over the life of it?
