There was a video posted here of the workers making C7's a few weeks ago, and I noticed that some of them were actually working, while others were just having casual conversations while parts past them down the line. It was obvious that they weren't talking business.
My 2nd observation was that 85% of the workers on the video were morbidly obese!
VetJazz by his name obviously has not held a job that contributed gainfully to society nor spent time in uniform defending the country he so willingly takes liberties in. Don't let his ignorance rile you Luvlake. Probably still lives in mama's basement. Something to be said for Israel and their mandatory service. Should be done here, BTW.
I used to be a robot paint process engineer and later on as a paint manager. I even painted parts for the Corvette. I'd like to share some of my experiences.
First I'd like to say not all fenders are equal, each part has it's own unique characteristics that have to be figured out.
It's been my experience that most paint issues aren't usually caused by robotics. I'm not saying there can't be poor programming or an issue can't be mitigated by superior programming just that the robot is generally not the root cause.
The reason is launching new parts and paints (color and/or new vendor) must go through an intensive validation process. In other words it doesn't go live unless it meets all the specs. The GM spec book on paint quality is literally a 3 inch binder and yes we go through the whole thing.
The most likely root cause really depends on the nature of the defect. For example let's go with paint runs. This is a common issue. Unfortunately even this example isn't simple. Since there are several types. Runs, sags, cascade sags, base drag, hanging drip, fat edge, etc. Each type has their own potential list of root causes.
I could easily list 20 things that can cause a run and some are definitely programming but the top causes are:
Paint viscosity
Solvent blend
Humidity
Temperature (ambient, part, paint, oven, flash off zones, the list goes on)
Racking (position, grounding, part density etc)
You'll notice the top 4 are a usually responses to changes in weather. The original processes are generally created, validated and optimized in the spring/summer. Then winter hits. Now the problem isn't the season, that can be compensated for, as much as the transition. Hot afternoon, freezing night, wet morning... Radical shifts require changes and that doesn't happen automatically; it takes a human to figure it out, sometimes by trial and error. Painting is as much of an art as a science.
With that said, there is no excuse for poor paint quality to escape the plant. All these issues should be internal and the customer should not have to experience them. This too is also something the plant will get better at. The car is new, they don't know where to focus their energy so they spend it initially on looking everywhere. Once they get familiar with common issues, QC will be more successful at finding them.
I know it sucks to get a poor paint job and I feel your pain, not only as customer but also as someone who poured his blood, sweat and tear into giving the customer the best paint job possible.
It's courageous of you to stick your neck out like that for something that's obviously not your responsibility. Methinks there's some dork on that team that doesn't apply the instructions, if he's ever read them. Sure, he's a riot at the employee parties. So he's not even suspected. But anyway, if the culprit is really the weather, I guess we should expect the same frequency of defects from cars built in Germany or Sweden. Because it's not exactly tropical out there. How do their cars compare?
Well.....you do have to admit that it isn't unreasonable to think a $60K+ vehicle's paint would at least not be orange peeled.
And every single C7 I've seen is
That's a real interesting line of thought, considering the only way to not have orange peel is to wetsand the car by hand, then buff it. Unless you had an instant drying clear, orange peel is going to happen. The good thing is it gives you good clear coat thickness for longevity. A panel with less orange peel = less clear mil thickness, in some cases...
If you want no orange peel, you need to pay a lot more than 60 grand on a car that outperforms cars that cost 90 grand.
I've never seen any orange peel on mine. What part should I look at?
It's not so much the climate of the country than dramatic sudden shifts in weather. I don't know about German or Swedish weather but I had the same issue in Korea. I had to deal with the heat in Mexico but we used summer versus winter solvent blends for that.
Weather is just one of many potential causes. I bring it up because we are shifting from summer to fall and that transition is tough to deal with. Leading into winter or summer is easier, leading into spring is also rough.
The reason I suspect weather is because those defects tend to be random and short term. They come out of nowhere and disappear just as quickly. Far more difficult to catch from a QC perspective.
If it truly is automation, it would be repeatable. By that I mean every car with that color, in that place will have a run of that size. Fairly easy to catch and contain.
There's no way to know unless you work at the plant, all we see is escape. Without knowing what percentage have issues I couldn't even give an educated guess.
As defects go, heavy paint is the best one to get as it is usually repairable with the right equipment and skill set. Some defects like the "dimples" in another thread are so bad that you have to sand to substrate and repaint the panel.
I would advise everyone to do a very detailed inspection before taking delivery... If we, as customers, didn't accept this poor workmanship, GM would be forced to step up their QC.
Don't be so quick to take them! Look them over very close and turn them down for defects like I've been reading about!
just few cars turned down would get huge attention!
Orange peel is one thing, many people deal with it because as an industry the change from oil based paints to water based paints has led to lots and lots of issues with peel. That change was for environmental issues. Water based paint is also lighter to a degree, so it helps reduce weight, however slight.
The issue that the OP had was with a paint run. This is a quality issue, one that should have been caught by QC, and also one that is avoidable as the guy who posted the informative post about how a "HUMAN" has to account for differences in conditions. In the end paint defects such as peel, are pretty much here to stay. Paint defects like runs and stripes are QC misses and should be fixed by GM free of charge as it is a miss.
People should get upset about this kind of thing, I know that I would have been pissed if my Scion FR-S had runs in the paint, the orange peel was tolerable for a $26k car. For a car that can exceed $75k you better be pissed about bad paint. Too many people buy cars without any actual "love" for the car. People have lost that romance with the automobile that America was originally renowned for. Too many just buy them to get from point A to point B and will drive their investments through machine washes to get the dirt off them.
I am 33 and I "love" my cars, I spend hours upon hours detailing, wrenching, modding, etc. So yes, poor paint quality is enough to ignite a fury within me. I am looking forward to getting a Vette sooner or later (Competition Seats be damned!) and I have started putting aside money for quite a bit of paint rework as I can notice the difference between a good paint job and a crappy one. So to the OP you have every right to be pissed, and i blame the laziness of my own generation for letting poor quality become "acceptable" as it's just too much work to fight for what you really want.
Interesting why other clear coats have no orange peel!
Good grief... If you put this car in moth ***** and are lucky enough that it becomes a classic in 30 or 40 years the last thing an appraiser will look at is the paint job. Yes, it matters especially for an individual finding his car with a run in the door. This is not a issue an appraiser will follow or care about in a 25 to 100,000 years. It might actually be a benefit to have a "flawed car" when all is said and done.
Paste waxed my C7 by hand today. No runs or flaws. I did in my garage with fluorescent lights and even got on my back to check the button of the doors and undercarriage. No problems.
Looks great.
Hey OP:
Southeast Asia AirCav 7/1 , 1970/71 "Welcome Home"
Southwest Asia SAC KC-10s 1990/91 Desert Strom
What is so bad, all the people on here that see this as
perfectly acceptable. You pay a premium price and they
do not care if get cut rate work. This is what the liberal
mind has created. All these Liberal supporters fall right
in and bash all the ones that expect better.
The C7 I have on order, is a little under $80k after taxes. I will not accept orange peel at all. That will be the very first area of my inspection, the paint. My salesman/dealership claims the complaints about the paint is way over rated. Supposedly, out of the 6 they sold, only one had a paint issue on the rear driver side quarter panel by the wheel. About 7" x 13" area had orange peel, but the rest of the car and the other 5 was perfect. I will be my own judge/inspector
I've had orange peel on our S600 Mercedes which stickered for $126K and have it on my Porsche with a sticker of $128K. You're going to have it on your Corvette too just like I had on the three that I had.
Orange peel is from the government forced environmental friendly water based paints they now use.
To the smart a.. who thought I never been to a 3rd world country, I spent 18 months in Southeast Asia, Philippines and Vietnam, 66 & 67' probably before you were born. As result of that paid vacation and agent orange exposure I now have Parkinson's , Prostate cancer and skin cancer. Freedom is precious, I grew up in a time that America was a Creditor nation and the envy of the world. When I said we have lot we didn't have to worry about being shot in school and a mans word was his bond. Yes I have seen how people live in a 3rd world country, have you?
luvlake, you're seeing another thing I notice with what's going on with the younger generation.
Not all, but a lot of them look down on older people now.
I remember when we looked up to older people.
Granted, .. being older does not automatically demand respect.
But the number of comments seen on this forum and in this country now a days seems to be another trend of our culture.
If they only knew ......
All I can say is these younger people should be so lucky to live long enough to get old and then the shoe will be on the other foot.
And I can only guess if they do, they'll be getting misunderstood and hammered on, way more for being old than we do now
Best of luck with the C7 and hope you enjoy it to it's fullest
