C7 splash guards
Old Feb 21, 2014 | 12:43 PM
  #81
ATX-C7's Avatar
ATX-C7
Great pics--thank you! Easy to see size on red--cannot even really notice them
Does something that small really help--I assume most are getting Xpel behind tires and on full rocker panel?
Old Feb 21, 2014 | 12:50 PM
  #82
Dan M 1945's Avatar
Dan M 1945
Originally Posted by Rich427
I have been trying to get this information. Are you sure they do not require drilling? If not, I am ready to place my order.
Put them on my new 7....dealer offered to install....the orig piece on the car pops out and the new ones pop in.....you cannot tell they did not come from the factory....very
happy...
Old Feb 21, 2014 | 12:52 PM
  #83
Supersonic 427's Avatar
Supersonic 427
They are very subtle, gives a little flare to the wheel well. About an inch at it's widest section, just enough so the tire does not protrude. I think they will help some.
I have to laugh, I installed these a couple of days ago and today I notice a small chip in the windshield. If you drive them... you can't keep them perfect!
Old Feb 21, 2014 | 06:12 PM
  #84
aforand's Avatar
aforand
I just did mine and could not believe how quick & easy it was. Also they are so subtle you wonder just how effective they will be. But I went ahead and installed aftermarket wheels a half inch wider and these should be perfect to pick up the extra road muck.
Old Feb 21, 2014 | 08:00 PM
  #85
Whataguy's Avatar
Whataguy
Ok, I admit it, I am physically/mentally challenged as a Mod handyman.
This is the simplest Mod I've done for two Corvettes, but I made it as hard as installing a camshaft. So that I can save some of you some time and embarrassment, here's my recommendations for the Challenged Handyman:
1) Read the frickin label on the inside of the new/old guards, it TELLS you where they go
2) On the front set, the tab in the center needs to slide into the artificial turf panel, not on the outside
3) On the front, the screw tab at the bottom goes on the OUTSIDE of the painted fender panel
4) On the back, the screw tab at the bottom goes on the INSIDE of the painted fender panel
5) It's a 7mm socket, trust me
6) If you still screw it up, don't worry, everything pops out and you can redo it.
7) Do NOT consume large quantities of scotch prior to installation.
Hopefully this helps other idiots like me.
Old Feb 21, 2014 | 08:03 PM
  #86
mike1952's Avatar
mike1952
St. Jude Donor '04-'05-'06-'07-'11-'12-'13
Okay I think I see the problem......too much Cutty! ;-)
Mike
Old Feb 22, 2014 | 07:55 AM
  #87
PUGPROUD's Avatar
PUGPROUD
Please don't tell us you are a heart surgeon..........just kidding !
Old Mar 12, 2014 | 04:36 PM
  #88
TEXHAWK0's Avatar
TEXHAWK0
Did anyone take any photos of what the stock panel looks like?
Old Mar 12, 2014 | 04:43 PM
  #89
RCB1234's Avatar
RCB1234
I have purchased them for my C7. Will be installing this weekend. They appear to be very easy to install. I agree subtle and should look good adding just a little more protection.
AW Z51 7speed.
Old Mar 12, 2014 | 05:13 PM
  #90
beepster's Avatar
beepster
Old Mar 12, 2014 | 06:05 PM
  #91
SRQStingray's Avatar
SRQStingray
Originally Posted by rcallen484
If like the C6, they will require drilling for the rears but not the fronts. Simple, yet drilling nonetheless. If they don't,
No drilling and easy install. Got them from Gene Cully very quickly. Takes 20 minutes to install all 4.
Old Mar 12, 2014 | 06:07 PM
  #92
Glen e's Avatar
Glen e
Old Mar 12, 2014 | 06:11 PM
  #93
ATX-C7's Avatar
ATX-C7
Anyone have the GM part number?
Old Mar 12, 2014 | 07:01 PM
  #94
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
See post 43
Old Mar 12, 2014 | 07:10 PM
  #95
ATX-C7's Avatar
ATX-C7
Originally Posted by eboggs_jkvl
See post 43
Gracias...
Old Mar 12, 2014 | 09:23 PM
  #96
JOHNGFLYER's Avatar
JOHNGFLYER
7mm socket only tool required?
Old Mar 13, 2014 | 10:23 AM
  #97
WILSON1776's Avatar
WILSON1776
Veteran: Marine Corps
Subscribed.....
To C7 splash guards
Old Mar 13, 2014 | 10:51 AM
  #98
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
A 7mm socket and a towel to sit on! You don’t have to remove a wheel or jack up the car. Very simple install. Even if you are not a DIY person put a several page picture "how to" in the following PDF: http://www.netwelding.com/Splash_Guard.pdf
It even shows what the bottom screws look like so you don’t get the wrong one (as I did!) Don’t even need the plastic wedges, once the bottom screw is out you can pull off with your hands. Could also put tape on a screw driver tip if needed.
Old Mar 13, 2014 | 11:01 AM
  #99
eboggs_jkvl
Moderator emeritus
Car ordered this AM. Splash Guards ordered right after.
Elmer
Old Mar 13, 2014 | 05:40 PM
  #100
Highway 61's Avatar
Highway 61
From: Between Forest Lake and White Bear Lake in the Land of 10,000+ lakes
22935635 = Front
22935639 = Rear
