cold winter storage
Old Feb 8, 2014 | 04:06 PM
Achmed's Avatar
Achmed
Default cold winter storage
I recall reading that the C7 shouldn't be driven in the cold because the tires can crack, what about when you're just storing it? I have a garage but it isn't heated, although I could plug in a heater if needed, due to temperatures well below the freezing point. Is it necessary?
Old Feb 8, 2014 | 05:29 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
The MYTH about the tires cracking is pure
Think about it for a minute. If it were true about the tires cracking at cold temperatures, GM couldn't ship a single one during the winter, let alone dealers having them on their lots.
Ignore it, you'll be fine
Old Feb 8, 2014 | 08:36 PM
Achmed's Avatar
Achmed
Cool, what about driving it in the cold? Is there risk of cracking if its driven in the cold versus only being stored in the cold?
Old Feb 8, 2014 | 08:44 PM
icntdrv55's Avatar
icntdrv55
Lots of folks posting on CF about using their cars in winter. You DO have to be cognizant of the reduced traction that your performance tires will provide during colder temps, especially when the temp drops below 40 deg F.
Old Feb 8, 2014 | 08:49 PM
Mecholova's Avatar
Mecholova
They won't crack. There's a recommendation not to drive in temps below 40 due to traction loss.
Someone read about warnings on another tire on another car and jumped to the claim they were the same.
Old Feb 8, 2014 | 08:54 PM
C7Joy's Avatar
C7Joy
I don't believe the cracking story for a second. Can you imagine the tire companies constant fear of being litigated out of business if that were true? I the main tire concern is that of traction on cold pavement or snowy pavement. I have A/S tires on my C6 but I will not knowingly head out in a snow storm.
Old Feb 8, 2014 | 10:01 PM
LT1xL82's Avatar
LT1xL82
The cracking of tires story is not so far fetched. Some tires are known to have this issue. For example the tires on the new Z28. I suspect this will also be an issue for the Cup tires planned to be used on the Z07 optioned C7 Z06.
Old Feb 8, 2014 | 10:22 PM
HummelS's Avatar
HummelS
If you read the owner's manual, you'll understand that lawyers, not engineers, wrote a good percent of it: "Don't do this, you could be injured; don't do that, you could be killed." Ad infinitum...
I will say that the summer tires are pretty treacherous in cold weather, and that it's pretty easy to have the car get away from you with cold tires if you aren't careful.
Old Feb 8, 2014 | 10:52 PM
Questar's Avatar
Questar
This is an issue with the ZL1 Camaro tires... Not only was I sent a written notification from GM! They also telephoned me and asked me to listen to a recorded warning about the tire issue, then they asked you to confirm that you had heard the recorded warning. Essentially they said don't use the tires in cold weather (below x degrees) and if you drive the car in cold weather they recommended installing alternate "winter" tires. They also recommended having the tires inspected if the car was stored for the winter in cold environment.
I saw pictures of the cracking that was reportedly experienced by some owners (in the Camaro ZL1 Forum).
But... This was specific to the 2013 ZL1 Camaro tires which was a different manufacturer and a year older production. I'm not even sure if this is an issue for current production. My ZL1 has had no tire cracking so far but I didn't expose it to cold weather.
Old Feb 8, 2014 | 11:08 PM
Sidepiper's Avatar
Sidepiper
I have put 3k miles on my C7 in the past two months and we have had one of the coldest, pothole filled winter ever. No problems with cracking and only one incident with losing traction for a split second on dry pavement. This is a year round car if you have common sense!!!
Old Feb 13, 2014 | 03:11 AM
Achmed's Avatar
Achmed
I think you guys just haven't experienced what a "real" winter is like
As I learned tonight my C7's tires are cracked, and they haven't even left the dealer's lot yet. The salesperson himself showed me the cracks and said that once it warms up and I can drive it, I am to come back and claim 4 new tires under warranty.
And get this, he said that of the 34 C7's they had allocated for 2014, ALL 34 had cracked tires once they were unloaded.
He explained that storing in the cold itself won't crack the tires if the car is kept still, but once the tires turn in the cold they will crack if its cold enough. I'm starting to think that I should maybe just run a heater in my garage next winter even though the tires won't be turning, just in case.
That's 126 tires that Sherwood Park Chevrolet will be replacing this spring under warranty lol.
Old Feb 13, 2014 | 05:03 AM
Hard to believe that GM would put tires on a vehicle that will crack in cold weather. And then have to replace them under warranty. Real bright move.
Old Feb 13, 2014 | 06:54 AM
LIStingray's Avatar
LIStingray
Isn't Sherwood Park in Alberta, Canada, and hasn't it been -30F for several days this winter? If so, I am not surprised to hear about the cracking, as that is far colder than any summer compound tires would be designed for.
Old Feb 13, 2014 | 08:03 AM
C8Jake's Avatar
C8Jake
GM SERVICE BULLETIN #04-03-10-013
WARNING
If temps drop below 20°F/−7°C, don't move a '14 Corvette
CRACKED TIRES SHOULD BE REPLACED IMMEDIATELY
Should GM risk shipping cars in these temps?
Warning isn't noted in the C7 owner's manual.
Old Feb 13, 2014 | 09:35 AM
shagsc7's Avatar
shagsc7
Drive with care and enjoy your new ride!!!! Of course if you drive like a newbie and let it rip then you will end up with a busted up C7....
Old Feb 13, 2014 | 04:06 PM
Achmed's Avatar
Achmed
Originally Posted by C7Jake
Pure
They have 5 in the showroom, 4 of which have visible cracks. My car was not in the showroom and had visible cracks too. So 34 out of 34 was a slight exaggeration but I'm pretty confident about 25-30 out of their 34 have cracked tires that will need replacing under warranty.
The sales rep there told me that GM may now only send C7's to our city in the spring to reduce their warranty costs.
Old Feb 13, 2014 | 04:08 PM
Achmed's Avatar
Achmed
I'm not sure what -30F farenheight translates to as we use Celcius up here. But yeah the winters are definitely colder than 99% of dealerships that receive C7's.
Even though C7Jake is in Windsor their winters are not nearly as harsh as here.
To cold winter storage
Old Feb 13, 2014 | 04:40 PM
C8Jake's Avatar
C8Jake
Windsor's had a very cold/snowy winter...no cracks in my tires. I drove it home 500km on a very cold day. How about some detailed pics of these alleged "cracks".
Old Feb 13, 2014 | 05:06 PM
Achmed's Avatar
Achmed
LOL so you actually think I'm lying that my own C7 has cracked tires?!
I've been to the GTA many times and no the winters are not even comparable to here.
Old Feb 13, 2014 | 05:09 PM
C8Jake's Avatar
C8Jake
You actually think I'm lying that my own C7 has cracked tires?
Pics to confirm
