They win
Old May 19, 2015 | 11:07 AM
TEXHAWK0's Avatar
TEXHAWK0
I used my thigh to contour my front plate!
Also, if you trim the aero plate down to the size of the plate, it increases the air flow and eliminates the painting problem.
Old May 19, 2015 | 11:10 AM
billythekid310's Avatar
billythekid310
I am so thankful for the southeastern states. 'Murica
Old May 19, 2015 | 11:17 AM
Algiers's Avatar
Algiers
Originally Posted by NSC5
I am afraid the trend it towards more front plate enforcement instead of doing away with plates but it would sure be nice if IL would drop the front plate requirement.
The aero mount looks better than any of the alternatives I have seen but I am getting a Z06 and I don't like the amount of air it blocks. At this point the Top Flight Reproductions low profile mount is at the top of my list since it only covers about half as much of the grill space.
I think I might try out the Top Flight too. I'm still using my dealer plates since I can't quite bring myself to do it.
Old May 19, 2015 | 11:25 AM
Ernest_T's Avatar
Ernest_T
More and more law enforcement agencies are buying scanner software to read tags so front place enforcement in states with two plates is going to get worse. Once they scan your plate they have access to a bunch of information about you and your vehicle.
Old May 19, 2015 | 11:48 AM
JJoeG's Avatar
JJoeG
Looks good!
Old May 19, 2015 | 12:00 PM
W88fixer's Avatar
W88fixer
I have the Top Flight Reproductions plate carrier. Think it is about the best solution. It still leaves air flow into the radiator area.
Having said that, I’d certainly welcome TX eliminating the front tag. Don
Old May 19, 2015 | 01:38 PM
Horsefly's Avatar
Horsefly
Default Plate on a Z06 Grill........
Which reminds me that I need to pick up a set of white colored screw caps for the bottom screws.
Hard to see, but there is a hole in the center of the plate for a front cam.
Old May 19, 2015 | 01:57 PM
Elegant1's Avatar
Elegant1
Originally Posted by AFVETTE
Oh well. But at least the AEROBRACKET makes it easy to be legal and it really doesn't look that bad.
At least our plates are cheap and flimsy and bend real easy.
Old May 19, 2015 | 03:09 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
I cut the aeroplate down. I think the plate looks better floating in front of the grill without those plastic chunks to each side. Opens up 25% more grill for airflow to the radiator also.
Old May 19, 2015 | 06:38 PM
DAFFYDRUNK's Avatar
DAFFYDRUNK
Hidden front cam idea is cool. As far as bolts, I had some paint sitting around so I threw a few coats of satin black on em. Could paint em white in a pinch.
Old May 19, 2015 | 08:55 PM
T2BLUETWO's Avatar
T2BLUETWO
Originally Posted by Patman
I hope this means you're keeping the car now and not trading it for a Tesla!
I work with him and I work on him keeping his Vette everyday!
T2
Old May 20, 2015 | 01:14 PM
C Moe's Avatar
C Moe
CorvetteForum Editor
Default Front Page News!
some good solutions here, thought we'd open it up to the front page to see if we can't get some more...
https://www.corvetteforum.com/articl...late-solution/
Old May 20, 2015 | 02:09 PM
  #33
Galveston3's Avatar
Galveston3
Screw that noise. I'm an AF retiree and would rather just take my other car on the base. Frankly, there's nothing on any installation that I need anymore unless I lose my ID Card.......
Old May 20, 2015 | 02:21 PM
  #34
Elegant1's Avatar
Elegant1
Now you need to get the painted C/F bent plate frame to complete the look. The frame is really well made.
Old May 20, 2015 | 02:27 PM
  #35
slesher's Avatar
slesher
Interesting. That looks great.
Where did you pick up the painted frame?
Old May 20, 2015 | 02:28 PM
  #36
Z06 RB's Avatar
Z06 RB
As someone said here a few years ago "I would rather have a hot tar enema than put a plate on the front of my Corvette".
Just in case I have a removable bracket with plate on it in the trunk if I get stopped. I took it off for a car show and forgot to put it back on.
The one I have on my C6Z is from Top Flight Reproductions.
Old May 20, 2015 | 02:37 PM
  #37
AFVETTE's Avatar
AFVETTE
GM PARTS DIRECT sell's the CF painted AEROBRACKET for $116
http://www.gmpartsdirect.com/results...umber=22979545
To They win
Old May 20, 2015 | 02:43 PM
  #38
dprestidge's Avatar
dprestidge
That looks great. Where did you get the covers for the screws?
Got them at Pep Boys. Most auto supply stores even Walmart. I painted them CF also.
Old May 20, 2015 | 02:50 PM
  #39
Elegant1's Avatar
Elegant1
http://www.ebay.com/itm/331209659437?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old May 20, 2015 | 02:53 PM
  #40
bluevette2001's Avatar
bluevette2001
This plate debate is really getting quite OLD. If your state requires one, put it on-SIMPLE, how often do you really look at it anyway and it's good for catching bugs/rocks.
