No Performance Timer on 2016
Old Jul 30, 2015 | 01:35 AM
joe285's Avatar
joe285
Default 2016 Performance Timer
Unless I'm doing something wrong, I don't believe I have the performance timer on my 2016. I've scrolled through all the options in the performance menu and don't see it. I have the lap timer but not the 0-60 performance timer. Can other 2016 owners check and see if you've got the performance timer? Did GM remove it on the 2016s?
Old Jul 30, 2015 | 06:41 AM
Boucherman's Avatar
Boucherman
Default Z51?
It MIGHT be available only on a Z51, or a 2LT, 3LT. What trim level do you have??
Old Jul 30, 2015 | 09:22 AM
joe285's Avatar
joe285
I have a Z51, 1LT
Old Jul 30, 2015 | 10:49 AM
C7s's Avatar
C7s
Hopefully its there. Why would they remove it?
Old Jul 30, 2015 | 11:05 AM
C7s's Avatar
C7s
I looked in 2016 manual and it states it has it.
Performance Timer : Press p
when Performance Timer is
displayed to enter the menu. Press
p while Set Start Speed is
highlighted then use w or x to
enter the start speed. Press SEL to
save it. Press p while Set End
Speed is highlighted then use w or
x to enter the end speed. Press
SEL to save it. After the start and
end speeds have been entered,
press o to set the Sport display to
the set speeds and the performance
timer is ready to use. On the next
acceleration, the performance time
will record the time. To reset the
timer, highlight Reset on the
performance timer menu and
press SEL.
Old Jul 30, 2015 | 11:16 AM
joe285's Avatar
joe285
See this thread as well:
http://www.stingrayforums.com/forum/...ne-2016-s.html
Maybe it's only on 3LTs or cars with PDR now?
Old Aug 23, 2015 | 12:42 AM
kevincol's Avatar
kevincol
Default No Performance Timer on 2016
I had been trying to figure out where my performance timer was. I went to my buddies house as I know he had it on his 2014 Z51. It was in the performance menu, just like the manual states. However, mine skips over the performance and lap timer.
Any ideas how to get to it to show up as an option under the performance menu? Did they take it off for 2016's?
Below is his:
Mine never will show that on the scroll, it skips the highlighted two options below. Manual says it should. The term "performance timer" only shows up on p.100 also.
Old Aug 23, 2015 | 05:00 AM
four0nefive's Avatar
four0nefive
Is your car a Z51? Maybe the performance timer is only available on the Z51 and Z06.
Old Aug 23, 2015 | 06:27 AM
CaryBob's Avatar
CaryBob
I have a vague memory that it was posted earlier that the performance timer was eliminated for the 2016 model year. Several 2016 owners have made that comment, but apparently it is still in the owners manual?
Old Aug 23, 2015 | 08:59 AM
Streetrod782's Avatar
Streetrod782
Wow that would really suck if they eliminated that for 16!
Old Aug 23, 2015 | 09:17 AM
Larry/car's Avatar
Larry/car
Probably a legal safety issue. Let's face it, you are actually racing against your self. Lawyers recomend against potential hazards that could fuel legal action against the company.
Old Aug 23, 2015 | 09:23 AM
C7s's Avatar
C7s
I opened a case with Chevy CS. Dealer is investigating. I recommend doing so if enough people complain they may reprogram it back since it is in the manual. It's way more useful then the lap timer they replaced it with!
Old Aug 23, 2015 | 09:49 AM
kevincol's Avatar
kevincol
So, it isn't just me that is seeing this... sigh. I was hoping there was some special button.
Please let me know what the dealer says.
Old Aug 23, 2015 | 09:50 AM
kevincol's Avatar
kevincol
Yes, Z51, but my buddies is a '14 Z51 (i.e. the picture above with the timer showing).
Old Aug 23, 2015 | 09:53 AM
kevincol's Avatar
kevincol
Maybe, but usually lawyers don't let things go for two full years before "becoming aware of it".... They typically are very proactive on eliminating risk. I'm pretty they would have thought of this back on the '14.
Is it gone on your '16 also?
Old Aug 23, 2015 | 09:56 AM
kevincol's Avatar
kevincol
I've been on this forum about every day since I placed my order back in May. I never remember seeing a thread like that. If you come across it, please forward. I would love to see the resolution.
Old Aug 23, 2015 | 10:00 AM
Thomasmoto's Avatar
Thomasmoto
Well if its gone from the DIC is the 1/4 mile timer still in the PDR?
To No Performance Timer on 2016
Old Aug 23, 2015 | 10:04 AM
Boiler_81's Avatar
Boiler_81
https://www.corvetteforum.com/forums...nce-timer.html
Old Aug 23, 2015 | 10:08 AM
defaria's Avatar
defaria
Stop treating us as babies! The Telsa has a 17" monitor in it with access to youtube! It is assumed that you're smart enough not to watch videos while driving.
Old Aug 23, 2015 | 10:10 AM
RC000E's Avatar
RC000E
Well, that'd be mighty gay if its removed
