View Poll Results: A8 Transmission, TC Failures / Non Failures
Torque converter failure 2015
8.36%
Torque converter failure 2016
4.18%
Torque converter failure 2017
2.09%
Transmission failure 2015
3.13%
Transmission failure 2016
0.52%
Transmission failure 2017
0.78%
No failure 2015
26.37%
No failure 2016
39.43%
No failure 2017
22.19%
Multiple Choice Poll. Voters: 383. You may not vote on this poll
A8 Failures
Old Jan 6, 2017 | 09:17 PM
  #141
Dif's Avatar
Dif
2016 Z51 Coupe with A8
Build date October 2015 and brought it home 10-22-15.
Just turned 6500 miles yesterday and no problem so far.
Old Jan 6, 2017 | 09:32 PM
  #142
h3mpking's Avatar
h3mpking
Originally Posted by OnPoint
I'm not bashing the C7 - in fact you'll look far and wide in an effort to find more of a Corvette homer than me, and you won't find him.
That said - these cars still being delivered with improperly filled rear differentials, and A8 transmissions that aren't ready for prime time, is simply inexcusable at this stage of the model's production run. It's not a great thing for a first model year - it's unacceptable at this stage of the model run (and ironically, the first model year A6 is robust).
I think the Corvette community will ultimately be fine - we are (most of us) hooked on these rigs. But I feel bad for those who have to go through this. And I feel even worse for those conquest buyers who bought a Corvette for the first time and are having to go through this. The rest of us have been around these cars long enough to know they are normally well built and pretty damned robust. What a way to lose future sales with the first time buyers (many of whom are young as well).
GM needs to get a handle on this, like yesterday.
Couldn't agree more. It has to be a quality of build issue on the converters or something because there are guys out there with some serious horsepower beating these things up with the factory torque converter and transmission. One guy I know of has over 20 thousand miles on the original converter and transmission with an F1R Procharger that beats the heck out of the car and participates in various speed events. In contrast though, Some like we have seen on this thread recently are getting their 2 week old car's torque converter replaced. Seems like the design could be robust, GM just has to figure out what the heck the problem is in the build. Will be curious to find out, if we ever do. I know I will continue to beat up on mine as often as I can.
Old Jan 6, 2017 | 10:56 PM
  #143
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by jagamajajaran
With 172 voters so far, it looks like we have a 91.86% forum rate of no failure.
Just sent you a p/m. Mike
Old Jan 6, 2017 | 11:15 PM
  #144
Foosh's Avatar
Foosh
Originally Posted by michelve
i have 20K miles failed twice and still failing ... lemon law coming next ....
That's exactly what would worry me so much about this situation. One failure I could stomach, but what's to keep the replacement from failing, since they are still failing in new cars?
Regardless of whether the failure rate in this poll is accurate or not, even 5% is indicative of a very big problem when it's the same system failing. Even a 5% warranty return rate for all systems combined would be a cause for concern for most car manufacturers.
Old Jan 7, 2017 | 12:48 AM
  #145
Rich Farr's Avatar
Rich Farr
Default 24 of 90 2015's With Failure?
If I am reading this poll correctly 24 of 90 model 2015's have had torque converter or transmission failure. Considering the low mileage on some vehicles there could be a huge percentage at 60,000 miles.
Old Jan 7, 2017 | 12:52 AM
  #146
owc6's Avatar
owc6
I've asked this before, but : Do Corvettes have torque converters or torque tubes?
Old Jan 7, 2017 | 12:59 AM
  #147
Foosh's Avatar
Foosh
The poll numbers add up to more than 100% because some have owned more than one C7 and voted multiple times. Some votes are also of questionable validity.
However, the current poll reported failure rate for all model years is at 17.49%, and even if it were half that, it would be a huge number considering that probably no C7 in the sample is close to 60K miles.
Automatic C7s have both. Similarly, manual C7s have both a clutch and and a torque tube.
Old Jan 7, 2017 | 01:00 AM
  #148
Joy c7's Avatar
Joy c7
Both, Tube is like a drive shaft.
Old Jan 7, 2017 | 01:03 AM
  #149
h3mpking's Avatar
h3mpking
However, the current failure rate for all model years is at 17.49%, and even if it were half that, it would be a huge number considering that probably no C7 in the sample is close to 60K miles.
I don't necessarily think that more mileage means more failures. We are seeing some in the 20K mile range with no issues. I think if you've made it to a certain point, the failures causing what is happening now will not rear it head hopefully. Not to say that new issues will not arise.
Old Jan 7, 2017 | 01:06 AM
  #150
owc6's Avatar
owc6
Can anyone show a diagram (probably exploded) that shows both? I thought it only had the torque tube.
Anyway, which (if applicable) is the actual problem child?
With clear labels, please.
Old Jan 7, 2017 | 01:09 AM
  #151
Foosh's Avatar
Foosh
Well, that's a positive way of looking at it. Hope you're right.
Correct. The torque tube has the drive shaft inside, and is also a major structural component of the chassis.
Here's a picture, but I don't feel like going in and adding labels at this late hour.
The trannies of both auto and manual are located in the rear for weight balance reasons as they were in the C6. The automatic transmission torque converter is inside the transmission case. The torque tube connects the engine to the transmission, and it's clear in the picture what that is.
The torque converter is the main "problem child," and I've heard of no torque tube replacements in all these discussions about A8 problems. If torque tubes were issues, we'd be hearing of replacements in M7s too.
Last edited by Foosh; Jan 9, 2017 at 10:31 AM. Reason: Moderator guidance aside, how does one use the multi-quote button, if you're answering posts at different times.
Old Jan 7, 2017 | 09:47 AM
  #152
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
What bothers me is that we are still seeing an issue with low fluid levels in the diff. Why in the hell isn't it a part of the dealer PDI to check it ? Or, before the component is installed at BG.
Old Jan 7, 2017 | 10:27 AM
  #153
joemessman's Avatar
joemessman
^^^ I can tell you why. It is an indication of poor quality control when a significant component or fluid is not installed to proper specifications. Especially fluid levels when it is a comparatively simple system to check. Obviously the person responsible for filling the fluid to proper level did incorrectly and the QC department failed to check the level. I can't imagine that fluid levels are not on a QC check list.
Last edited by Steve Garrett; Jan 7, 2017 at 03:38 PM. Reason: No need to re-quote the previous post, especially if you're the next person posting.
Old Jan 7, 2017 | 12:37 PM
  #154
E.T.D. Corvettes's Avatar
E.T.D. Corvettes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
The differential is filled by the supplier with extremely tight parameters. Mass flow sensors control the amount of fluid in each and every fill to exact specifications. The same kind of processes are used in the Performance Build Center. I have seen these processes and they are incredibly precise. All of these components are traceable as to the exact amount of fluid that was filled in each component when there is a warranty claim.
The bigger issue has to do with how everyone tests to see if they have enough differential fluid or not. Mass to volume is what is important in these cases. A properly filled differential is not necessarily one that allows a little to seep from the fill hole when you are filling it up, though some service departments would say it's full based on this. There can also be residual fluid in the various differentials that was not drained, and a "full" differential could wind up being an overfilled differential. I think the bigger issue has to do with various service departments and how they check, evaluate, and fill our Corvette differentials. I know in other matters with our Corvettes, the level of knowledge and expertise is all over the chart depending on the dealership.
Old Jan 7, 2017 | 01:21 PM
  #155
767guy's Avatar
767guy
That sounds like a good explanation, perhaps.
However , there have been forum members starting with the 2014 MY that have posted here they had " service rear axle " DIC messages and if I remember correctly they posted that the result was the service department had to add fluid as it was found to be low ???
Old Jan 7, 2017 | 01:27 PM
  #156
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
Jeremy, I absolutely agree with you. The lack of knowledge at some Chevrolet/GM dealers about the C7 has been well documented on this forum. I maintain that GM restrict the sale and servicing of Corvettes to only those dealers that can demonstrate competence on a recurring basis. At this point in time it is a crapshoot when you take your can in for service.
Old Jan 7, 2017 | 01:33 PM
  #157
Foosh's Avatar
Foosh
There was a problem w/ differential fluid being under-filled early in the 2014 MY, for both manual and automatic. GM quickly sent out a bulletin to customers directing them to return them to the dealerships for a check. That problem hasn't recurred since.
Diff fluid level has nothing to do w/ the A8 issues.
To A8 Failures
Old Jan 7, 2017 | 01:51 PM
  #158
rmorin1249's Avatar
rmorin1249
Based on the TSBs issued by GM on the A8 tranny, the issue is supposed to be one or more of these:
Lack of O ring
Defective TC (may be related to the O ring)
Defective stator support
There could be other issues as well that GM has not addressed yet.
I am curious to understand the nature of the issues being experienced by owners of cars other than the Corvette that use the same transmission but in a different installation in the vehicle.
Old Jan 7, 2017 | 03:30 PM
  #159
Ernest_T's Avatar
Ernest_T
^^^It's the same in the Silverado. Delayed engagement, rough shifts, and shuddering.
Last edited by Steve Garrett; Jan 7, 2017 at 03:36 PM. Reason: No need to re-quote the previous post, especially if you're the next person posting.
Old Jan 7, 2017 | 03:45 PM
  #160
Steve Garrett's Avatar
Steve Garrett
CORVETTE TODAY Show Host
CORVETTE TODAY Host
St. Jude Donor'15
Steven, can you change someones vote? Someone voted for the 2017 TC failure, and after looking at his recent posts, he has stated that he has a 2016 C7 that had issues. Not a huge deal and 1 will not skew anything as this is far from scientific, just fun data to look at.
No, unfortunately the software does not allow this.
