Windshield Washer pump inoperable
Old Apr 11, 2022 | 08:20 PM
  #41
FX VETTE's Avatar
FX VETTE
Originally Posted by the blur
4999 miles, dead pump. Dealer wants $560 !! I literally told them where to go.
pretty sure I paid less than $40 for the pump & grommet.
Edit - Actually, I just checked and it was under $30 for both, including shipping.
Old Apr 11, 2022 | 09:58 PM
  #42
ICONIC7's Avatar
ICONIC7
2025 C7 of the Year Finalist - Modified
2023 C7 of the Year Finalist - Modified
I just had my dealer replace mine a few weeks ago because I don't have the tools to do it myself. Cost me $350 and I thought that was ridiculous.
Old Apr 11, 2022 | 11:03 PM
  #43
nwalker's Avatar
nwalker
Default That’s theft!
When I bought my 2016 with 5K miles on it, in 2018, the washer pump was inoperative.
I didn’t want anyone messing with my car, even though it was still under warranty. The pump (genuine GM) cost a little over $20.00 and it took less than hour to replace. There are videos online. All you have to do is pull the left front wheel and loosen the back half of the wheel liner. You don’t have to completely remove it.
Old Jun 5, 2022 | 11:45 PM
  #44
FX VETTE's Avatar
FX VETTE
As a follow-up. Today I switched out my wheels/tires to put some more miles on the OEM wheels/tires. Took this opportunity to swap out the old pump and grommet. Thanks to this forum advice it went flawless and I’m back in business. Thank you once again CF contributors.
Old Oct 8, 2022 | 11:32 AM
  #45
Sslangs's Avatar
Sslangs
3rd Gear
Does any one have a link to the part to order it?
Old Oct 8, 2022 | 11:34 AM
  #46
RonC7's Avatar
RonC7
See post #38 above. If I recall correctly it is a generic GM part and widely available at auto parts stores.
Ron
Old Oct 8, 2022 | 11:45 AM
  #47
nwalker's Avatar
nwalker
Default Wiper Pump
This number is what I used:
23131659
Old Oct 8, 2022 | 12:08 PM
  #48
Sslangs's Avatar
Sslangs
3rd Gear
OK, thank you for the quick response. Looks like the driver front wheel needs to be removed. Where is a good lift point for the jack.
Old Oct 8, 2022 | 05:52 PM
  #49
ICONIC7's Avatar
ICONIC7
Here you go.
https://www.corvetteforum.com/forums...ing-up-c7.html
Old Oct 8, 2022 | 06:19 PM
  #50
nwalker's Avatar
nwalker
Default Jack point
I always jack mine on the puck. I have snap-in pucks that I permanently leave in.
Old Oct 10, 2022 | 09:44 PM
  #51
Sslangs's Avatar
Sslangs
3rd Gear
Thank you for quick replies. Im going to tackle it later this week. This is one of my first posts, sounds like you have a good group of folks around here.
Old Oct 11, 2022 | 09:09 AM
  #52
Har-ray's Avatar
Har-ray
We have windshield washers?
I keep Meguire’s Ultra Detailer on my windshield and have only used my blades 3 times in 6 yrs. / 70k mi.
Old Oct 31, 2022 | 09:54 AM
  #53
RichRu's Avatar
RichRu
8th Gear
Does anyone know the fuse number on a 2016 zo6 for the windshield fluid pump?
Old Oct 31, 2022 | 12:30 PM
  #54
RonC7's Avatar
RonC7
Look in your owner's manual. If you don't have one, thee is a link in C7 General / Sticky Threads to a PDF version.
There is also a fuse schedule inside the fuse box cover under the hood or near the rear fuse box.
Ron
Old Oct 31, 2022 | 12:48 PM
  #55
RichRu's Avatar
RichRu
8th Gear
Ron
hi Ron, it doesn’t show it in my Manuel, nor if it’s in the front or back of car..
Old Oct 31, 2022 | 12:52 PM
  #56
RichRu's Avatar
RichRu
8th Gear
Not yet,I’d like to check the fuse, but it’s not listed in Manuel
Old Oct 31, 2022 | 01:12 PM
  #57
RonC7's Avatar
RonC7
OK, then it is probably powered through the BCM. I guess you can check those fuses.
The pump appears easy to plug up. It may just need to be cleaned out per one of the posts above.
Ron
To Windshield Washer pump inoperable
Old Oct 31, 2022 | 01:51 PM
  #58
RichRu's Avatar
RichRu
8th Gear
I’m not that smart,what’s a bpm?
Old Oct 31, 2022 | 01:52 PM
  #59
RichRu's Avatar
RichRu
8th Gear
Bcm?
Old Oct 31, 2022 | 01:56 PM
  #60
RonC7's Avatar
RonC7
BCM (Body Control Module).
But check the front fuse box for a fuse labelled WASHER PUMP (#86 for 2019). 2016 will be a different number, same location.
Ron
