Range Technology 8.4
Old Sep 18, 2017 | 10:58 AM
  #41
50th year's Avatar
50th year
2017 C7 of Year Finalist
Over the last week I have emailed range questions about 8.4 and have not received an answer. In the past they were quick to respond. I don't believe they have the answers yet.
Old Sep 18, 2017 | 11:01 AM
  #42
mountainears's Avatar
mountainears
In the 4-5 months I've been involved with them with this beta program their response is very hit and miss. Sometimes, very quick, others they never respond. Mostly it is slow to never....
Old Sep 18, 2017 | 11:25 AM
  #43
50th year's Avatar
50th year
Are you still using 8.3? Has there been any improvement over earlier versions? I guess I will just buy 8.4 and use the switch. I was hoping for plug and play
Old Sep 18, 2017 | 11:29 AM
  #44
mountainears
As soon as it threw the code, I pulled it. I don't drive my car daily and am not going to put up with CEL's. I'm in the camp that wants it fixed, I don't want to install a switch. I drive a lot in manual mode so I'm not as concerned but would like to see them fix this so I'll keep putting pressure on that way.
Old Sep 19, 2017 | 04:13 PM
  #45
2 seats's Avatar
2 seats
how does this switch work? I just bout a used one for a 2016 a8. Should I use send it to range for a update as I know nothing about this used one off eBay?
thanks
Old Sep 19, 2017 | 04:39 PM
  #46
joemessman's Avatar
joemessman
thanks
Try it first. If it works reliably just keep using it. No CEL codes are good. I originally got a used one from a forum member. It was version 7.8 I believe. Got a CEL after a while and stuck in 3rd gear. Sent it in for flash update to 8.1 and it has been golden.
Old Sep 19, 2017 | 04:44 PM
  #47
2 seats's Avatar
2 seats
[QUOTE=joemessman;1595600409]Try it first. If it works reliably just keep using it. No CEL codes are good. I originally got a used one from a forum member. It was version 7.8 I believe. Got a CEL after a while and stuck in 3rd gear. Sent it in for flash update to 8.1 and it has been golden.[/QUOTE
gotcha. Funny the ones that say for a Corvette are $188 the others are $134. Same part number. 🤔
Old Sep 19, 2017 | 04:52 PM
  #48
joemessman's Avatar
joemessman
[QUOTE=2 seats;1595600436]
I guess that is what is commonly refered to as the Corvette tax.
Old Sep 19, 2017 | 05:03 PM
  #49
2 seats's Avatar
2 seats
Originally Posted by Jaylars
I just lay it over the steering column and let it hang to the right. The switch has a flat cable and is the perfect length, keeping the Range module out of the way of everything. A small strip of Velcro should keep it secured. Currently I do not use anything to secure it.
how does this work? Installation etc??
Old Sep 19, 2017 | 05:52 PM
  #50
bbrown450's Avatar
bbrown450
Why don't they go ahead and build that in already !!
Originally Posted by rmorin1249
Crap, I was hoping for good news. I guess 8.4 is what will be on mine when it comes back. Time will tell. Do you leave yours plugged in and turned on when you start your car?
Old Oct 5, 2017 | 05:14 PM
  #51
50th year's Avatar
50th year
I decided to go a head and buy version 8.4 I am using it with on off switch. I have to say driving without that constant v8 to v4 stuff is a dream. It actually drives like a normal v8 trans. Sure you can just drive in manual mode and at times I do. Still its nice to have the auto option it you want it. mountainears are you still beta testing for range? It would be nice if they got it together and I could forget the switch
Old Oct 5, 2017 | 05:23 PM
  #52
mountainears
They have yet to respond to the last failures, which is not unusual. Usually I'll report and hear nothing for a long time, then all the sudden I'll hear there is a new one they are shipping me.
Old Oct 5, 2017 | 06:22 PM
  #53
Maxie2U's Avatar
Maxie2U
Is version 8.4 causing code errors/limp mode/check engine light problems with 2016 base Stingrays?
Old Oct 5, 2017 | 06:48 PM
  #54
2 seats's Avatar
2 seats
mine is doing great with the range. I bought a 6 month old used one,so I don’t know if it’s 8.4 or not. I have a 16
Old Oct 5, 2017 | 07:01 PM
  #55
50th year's Avatar
50th year
I would check with range. 16 may be good to go. It seems the 17 has had the problems.
Old Oct 5, 2017 | 09:21 PM
  #56
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
I have been driving with V8.4 for a couple weeks. Have tried starting the car with the Range on to see if it generates a CEL. So far, so good. No CELs. Car drives and tranny shifts fine.
Old Oct 6, 2017 | 08:16 AM
  #57
Thunder22's Avatar
Thunder22
What year is your car though?
To Range Technology 8.4
Old Oct 7, 2017 | 07:36 AM
  #58
Thunder22's Avatar
Thunder22
bump
Old Oct 7, 2017 | 08:20 AM
  #59
50th year's Avatar
50th year
Thunder
His stats show he has a 16
Old Oct 7, 2017 | 12:17 PM
  #60
Thunder22's Avatar
Thunder22
Originally Posted by 50th year
Thunder
Thanks, that was dumb of me, I should have looked.
