Convertible Sub Section
Old Mar 28, 2018 | 05:02 PM
  #501
owc6's Avatar
owc6
Originally Posted by GTFD2
Open the trunk with the key. Close it and see if it resets. If not open the trunk again with the key and disconnect the battery for about a minute. Reconnect and it should be reset.
You will have to reindex the windows for the top to cycle after disconnecting the battery.
Old Mar 29, 2018 | 07:29 PM
  #502
2L8ULUZ's Avatar
2L8ULUZ
Default Top maintanance needed?
Does the power top require any kind of maintanance? Are there area's that need lubrication on occasion? Just curious.
Old Mar 30, 2018 | 01:04 PM
  #503
Rebel Yell's Avatar
Rebel Yell
I owned my previous 2007 Vert for 10 years, and never did a thing. It still worked fine the day I traded. But, a little lube wouldn't hurt a thing. That is if you can get to any of the mechanisms. I've never looked.
Old Mar 30, 2018 | 01:10 PM
  #504
F4 Phantom's Avatar
F4 Phantom
Do you guys use any kind of conditioner on your top? I just clean mine with water, no soap. Somebody at the gym today mentioned 303.
Old Mar 30, 2018 | 02:09 PM
  #505
2L8ULUZ's Avatar
2L8ULUZ
I haven't looked either but I'm thinking that everything is sealed or unaccessable to get any lube to.
Old Mar 31, 2018 | 12:36 AM
  #506
SilverGhost's Avatar
SilverGhost
Raggtopp 2141
https://www.corvetteforum.com/forums...intenance.html
Old Apr 1, 2018 | 03:21 PM
  #507
B-17/B-25 CC's Avatar
B-17/B-25 CC
Default 2016 z-51 a8
My 2016 Z-51 purchased Jan 20th. Have driven one road trip to the hill country west of Austin to look at the bluebonnets.
Old Apr 3, 2018 | 06:58 PM
  #508
firehawk44's Avatar
firehawk44
My 2014 Stingray. Replaced engine in 2016 w/13,500 miles. Still under warranty so no costs to me. Going 45 mph when the car just shutdown on way to 4th of July BBQ. Service Manager said piston had exploded and there was a hole in the cylinder. Removed right valve cover and intake valve spring broke and intake valve gone. GM authorized complete replacement and engine sent to Bowling Green to determine cause (never learned the cause but I'm not a fast driver! Just drive to and from golf course everyday. Once I got it up to 80 though!). Service manager did an excellent job replacing the engine (took about 3 weeks). No issues since replacement. See a lot of thumbs up, SmartPhones taking pictures, and smiles. The mechanics of raising and lowering the top is absolutely awesome and draws a lot of attention too! One trip from DC area to Connecticut and back. Otherwise, just drive around town and to/from the golf course (weather permitting).
Old Apr 3, 2018 | 10:36 PM
  #509
Always Red Dave's Avatar
Always Red Dave
^^^Glad things worked out for you and seemed like you took it with a grain of salt. Your Stingray looks great and hope it is good to you for now on and especially this July 4th!
Old Apr 4, 2018 | 08:53 AM
  #510
TOY 15's Avatar
TOY 15
Default Wind noise/convertible top shake
anybody else worried about driving with top up and window(s) open?
I look in my rearview mirror and see the lower bottom edge of top where it meets the deck shaking hard
Will this eventually mean possible gaps? water/rain leaking into cabin?
Old Apr 4, 2018 | 12:30 PM
  #511
lennykoll's Avatar
lennykoll
Originally Posted by SilverGhost
This is what I posted in the C6 topic thread SilverGhost posted above......LK
Great thread and information..... I did find this video from Autogeek on applying RaggTopp cleaner/protectant so thought I would share.... they do not mask windows etc. but several points on prep and application are good to know (e.g. make certain top is TOTALLY DRY before applying protectant, using "blotting" vs. wiping)....lots of other videos on the topic will/should also appear on the right!!
RAGGTOPP™ Convertible Top Fabric Protectant Hints
* Clean as directed with RAGGTOPP™ Convertible Top Fabric & Vinyl Cleaner and allow to thoroughly dry.
* Shake well, product must always be well mixed.
* Spray lightly using gentle sweeping motions 18 to 24 inches from fabric top.
* Allow top to dry 10 to 15 minutes between coats. The sun will speed up the drying allowing you to apply additional applications.
* Once dry to the touch apply additional coat. (Two or three coats are recommended on first application.)
* Allow 24 hours for the micro-bonding process to set.
* IMMEDIATELY wipe over spray from glass automotive/truck finish with a microfiber towel.
* Reapply several times per year as needed maximum UV protection as well as stain and water repellency.
LK
Old Apr 4, 2018 | 05:56 PM
  #512
DALE#3's Avatar
DALE#3
Your Convertible Top Maintence.This is your Owner's Manual Information
Old Apr 4, 2018 | 06:02 PM
  #513
pkincy's Avatar
pkincy
Originally Posted by 2k07z06
anybody know how to reset the warning for the trunk being open? Can't put the top down with out getting rid of the warning. Checked the truck several times and it is closed, can't open the trunk with the FOB either.
Help would be appreciated
2014 3 LT Vert
My 2016 had a recall to fix that problem. Just a reflash of the appropriate computer. Even after that I have had a similar problem and I opened the truck with the key and it has worked well since then.
Old Apr 6, 2018 | 10:53 AM
  #514
ousooner's Avatar
ousooner
Cruising
Old Apr 6, 2018 | 12:37 PM
  #515
formula32paul's Avatar
formula32paul
Ousooner, Nice Ride
Old Apr 6, 2018 | 05:34 PM
  #516
Always Red Dave
Originally Posted by ousooner
Is this a real picture or a painting! Looks Perfect!!
Old Apr 6, 2018 | 05:39 PM
  #517
Rebel Yell's Avatar
Rebel Yell
Toy, I would get the car to the dealer PDQ. My 03/16 build '16's top is as solid as a rock with the windows down. Good luck.
To Convertible Sub Section
Old Apr 7, 2018 | 06:41 PM
  #518
JonMN's Avatar
JonMN
Still waiting for decent weather in MN. But I am getting ready. For those that might need a cooler . . . the Yeti Hopper Flip 12 is a perfect fit. I went soft-sided to reduce the possibility of damage. LINK
Old Apr 7, 2018 | 06:57 PM
  #519
owc6's Avatar
owc6
Damage to what? The contents?
Old Apr 7, 2018 | 06:59 PM
  #520
owc6's Avatar
owc6
What is under your partition?
